when I close the other 3 doors it sounds German & beautiful. When I close the driver's door it sounds like old car that's the problem..it vitz 2006
Edited by nish1
Your Vitz speaks German? Japanese cross breeding..!!
i think what he has mentioned is other 3 doors sounds nice when closing and the driver side door sounds bulky. btwn, i do have the same problem. :/ my one is a 2008 swift.
First thing to check are the door pins. THen check the beadings. But then since both cars are fairly new, will need to check more closely.
This is what happens when Japanese cars try to behave like Germans.... :)
Your door needs to be adjusted or the door pins need to be replaced. Basically your door has come down a bit now hitting on the latch a bit hence the noise. Also the door locks become a bit noisier over time with wear and tear. Maybe a bit of WD40 might help. Why in the world do you think its the beading ? You should never replace an original beading unless you have no other choice because the replacements are never as good!
