Engines With Dpd Or Dpf - Which Engine Oil To Use ?
  • Replies 54
  • Views 26.2k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • ECM measures the pressures at the inlet and outlet side of DPF.ย  the readings are calibrated in a way to detect if DPF is blocked above a certain percentage,and then the Regene mechanism is activated.
  • I don't think whether you have DPF or not is dependent on the transmission. Every diesel vehicle of this generation will have a DPF. I don't understand how a DPF affects fuel economy as long as its fu
  • taba123, Same here (sorry for the delayed response). I HAVE SOME OR OTHER MISSED YOUR POST ON 14TH.I logged in day before and yesterday, that was very late after coming from some work in late night.
Posted Images
My Hiace has DPF and I use Toyota genuine oil, I didnt know DPF has anything to do with the engine oil. It cleans itself automatically time to time.
However if you use auto diesel it gets clogged up pretty quickly and will have to be replaced.ย
7 hours ago, Daniel061082 said:
the ecm of this car doesent show the amount of ash bloking in the dpf.
ECM measures the pressures at the inlet and outlet side of DPF.ย  the readings are calibrated in a way to detect if DPF is blocked above a certain percentage,and then the Regene mechanism is activated.ย  Instead of regular 2~6 injections during normal drivingย  , REGEN-mode has about 6~9 injections one Piston cycle,but added at the very late phase towards BDC and very short needle opening times(~500uS per Injection) compared to the regular driving(500uS~2.5mS per Injection). So I doubt if it has any big impact on Fuel consumption if the sum of needle open times during REGN mode increases only by about 1mS.
Edited by ajm
On 27.4.2013 at 1:57 PM, Fixzit said:
If they haven't taken off the dpf..I hope they have taken out the the filter inside.. otherwise without a regen cycle it will get blocked and cause you more problems than before. Its better if you can find out what exactly they have done. As for mine I took the whole dpf off and straight-piped it..sensors are still there but the pipe has been designed in a way that all 4 sensors get the right signal so that the ecu doesn't bother running a regen cycle. .
Hey fixzit
Can you explain how to do it or wher to get this pipe?
