Tire Change Tool Electric Car Truck Scissor Jack Lift Wrench Kit Dc 12V 1 Ton
Am I to understand the point of this post is that you managed to find it all by yourself? If not, I don't see what relevance it has with DIY.
And am I to understand that you are not man enough to use physical force to use the jack? Will it damage your precious fingernails?
Sheeesh.. the Y generation girly men these days.... :)
To think that changing a tyre wasn't a DIY for you until you found this kit is just plain sad.
Even the "finding" is wrong, this particular kit can't even be shipped to Sri Lanka!
you gotta have some pretty loose fitted lugs to remove with a cheap 'non' impact wrench that runs of the 12v socket.
Probably planning to loosen the lugnuts with the same nailpolish remover that he uses to fix his chipped fingernails... there's another DIY 2-in-1 for you :P
Suggestion- get a driver..
'tiv',
Only to drive the car? they very relay agree to do any other work.
Sylvi Wijesinghe.
I mean't atleast have someone who knows to get things write, incase the gizmos fail..
