This is the place which I usually lookup for tips and to get trusted advices on automotive throughout the years and finally time has come for me to put a major issue which I'm facing now that requires your help greatly...
I have a Toyota Sprinter Marino 1993 model 5A-FE (EFI) which failed 2 emission tests done in DriveGr**n. The attachment has the latest results. The problem is high CO levels in both idle and 2500 RPM. Car normally does around 9km/l city and I thought its normal for a manual Marino.
I have done a Engine tuneup in J*kis 7 months back and they did clean the throttle body, plugs were not replaced but adjusted and they cleaned the injectors just using the carb cleaner ( didn't attached to that measuring machine and checked even thought I was charged for it it seems ) . Small water drips started to appear from the silencer n made me happy so didn't go after it.
Now after like 8000kms when the emission test initially failed I showed my car to a person in Vidyala junction and he figured out that the Overflow to the petrol tank had a blockage and fixed it (some small particle was inside the metal tube near to the tank). No check engine light to show any sensor error. Also he did a self diagnose to identify if there is a sensor issue and non has problems. He checked the spark plugs and said the mixture is rich and the plugs are oki, and checked the throttle body which only had small amount of carbon. So he suggested not to do a full tuneup again. So I went for the test this Saturday and it failed with the below results for the second time.
Guys, What can be the issue here. I have used octane 95, VIC air filter, mobil 40 as well.
I have no option but to take this to a place in Raththanapitiya which has emission equipment and they charge 2500 just to find the fault and asked to come on a weekday which I cannot allocate due to circumstances.
1. Does this sounds as a fault in O2 sensor?
2. Do I need to replace the spark plugs?
3. Can this be a Dalco issue? Or to check the Dalco wiring and adjust Dalco?
Surrounded by various different nice car models in Germany but still fascinated by the Presea, Bluebird U13 and the Mark II.. The first cut is the deepest.. Baby I know, the first cut is the D he he he
djpra123
Dear Experts,
Greatly appreciate your help.
Edited by djpra123Link to comment
28 answers to this question
