How To Remove Sticker Adhesive In Car Paint
dpbatagoda
Do not use Kerosene! Use WD-40 like c1nder suggested. It is a multi-purpose cleaner/solvent which is very popular with anyone who has to get their hands greasy. Buy a can from any reputed hardware shop, and you can use it for other things as well, which you can read on the back of the can, lest I sound like an advertisement.
  On 9/17/2012 at 12:26 PM, dpbatagoda said:
Guys,
I have some sticker glue stuck on my car paint after wedding decoration.
How to remove those?
Is Kerosene good?
'dpbatagoda'
Petrol works very well on sticker glue.
  On 9/18/2012 at 4:05 AM, c1nder said:
It's available at Arpico. Just spray on a cloth and wipe till the adhesive marks go.
Refer to web page you will get all details of WD 40. I will give you under a most important details of the product. Which from the Web.
The long-term active ingredient is a non-volatile, viscous oil which remains on the surface, providing lubrication and protection from moisture.[4] This is diluted with a volatile hydrocarbon to give a low viscosity fluid which can be sprayed and thus penetrate crevices. The volatile hydrocarbon then evaporates, leaving the oil behind. A propellant (originally a low-molecular weight hydrocarbon, now carbon dioxide) provides gas pressure in the can to force the liquid through the spray nozzle, then evaporates away.
These properties make the product useful in both home and commercial fields; lubricating and loosening joints and hinges, removing dirt and residue, and extricating stuck screws and bolts are common usages. The product also may be useful in displacing moisture, as this is its original purpose and design intent.
