sampa Posted January 28, 2013 Share Posted January 28, 2013 Hey guys, I recently did some touch up's in my car. After the paint work I so some small amount of spray paint dots (In sinhala "dalla") scattered around the dashboard. Please let me know how to clean the without damaging the dashboard and the meter panel. Thanks in advance Sampa Quote Link to comment Share on other sites More sharing options...
The Don Posted January 28, 2013 Share Posted January 28, 2013 Whatever you use, don't use thinner or kerosene oil or anything like that! I will wait for experts on the subject to comment. But left up to me, and if the dashboard surface was hard plastic (not leather, fake leather etc) I would use a mild abrasive material like toothpaste! Quote Link to comment Share on other sites More sharing options...
sampa Posted January 28, 2013 Author Share Posted January 28, 2013 thanks for the quick feed back. Quote Link to comment Share on other sites More sharing options...
Komisiripala Posted January 28, 2013 Share Posted January 28, 2013 Davy! Help!! Quote Link to comment Share on other sites More sharing options...
Schiffer Posted January 28, 2013 Share Posted January 28, 2013 i know this is bad advice after what The Don said but ive removed over-spryaed paint from a dashboard using a very little amount of thinner and then applied those dashboard shine thing and cleaned further. Quote Link to comment Share on other sites More sharing options...
Jaliya48 Posted January 28, 2013 Share Posted January 28, 2013 I have the exact same overspray on my dashboard. I tried ammonia based window cleaner and it works, but it takes a lot of effort! I have since resorted to scraping it off using a piece of plastic with a blunt edge. The Don's idea is good, but don't use the 'gel' type toothpaste (Signal is fine). I'm going to use Brasso on it soon to see if it will buff out the overspray, fingers crossed! Quote Link to comment Share on other sites More sharing options...
jdnet Posted January 28, 2013 Share Posted January 28, 2013 use a mild rubbing compound very lightly. Quote Link to comment Share on other sites More sharing options...
Schiffer Posted January 28, 2013 Share Posted January 28, 2013 On 1/28/2013 at 12:35 PM, Jaliya48 said: I have the exact same overspray on my dashboard. I tried ammonia based window cleaner and it works, but it takes a lot of effort! I have since resorted to scraping it off using a piece of plastic with a blunt edge. The Don's idea is good, but don't use the 'gel' type toothpaste (Signal is fine). I'm going to use Brasso on it soon to see if it will buff out the overspray, fingers crossed! mate dont use brasso, it ruin the dash. it will end like like my roof beading before Quote Link to comment Share on other sites More sharing options...
Jaliya48 Posted January 28, 2013 Share Posted January 28, 2013 I didn't mean the vinyl parts of the dash but the trim surrounding the radio etc. These are (were) supposed to be shiny polished black plastic so Brasso will work well here. For the vinyl I'm sticking with a blunt plastic edge. It's a tedious process but at least I won't damage anything. Quote Link to comment Share on other sites More sharing options...
upulhad Posted January 28, 2013 Share Posted January 28, 2013 Iso prpl Alcohol (sergical sprit ) will Nice for you.. its not hurt ur plastic / vinyl /Al surface.. Quote Link to comment Share on other sites More sharing options...
soulja Posted January 28, 2013 Share Posted January 28, 2013 Glass cleaner or thinner diluted with water. Then use the magical peanut butter and will look as good. Hope it helps.. Quote Link to comment Share on other sites More sharing options...
Davy Posted January 29, 2013 Share Posted January 29, 2013 On 1/28/2013 at 5:00 PM, upulhad said: Iso prpl Alcohol (sergical sprit ) will Nice for you.. its not hurt ur plastic / vinyl /Al surface.. I was going to suggest Surgical Spirit because it's safe on most surfaces. But this also would make the dash go dull. You'd have to use some sort of dashboard polish to restore the shine. Do a spot testing first. If your dash has a rough texture, you might have to use an old toothbrush. As for the gauge cluster, use light duty 3M rubbing compound on a microfiber cloth and be really gentle. Quote Link to comment Share on other sites More sharing options...
sampa Posted January 29, 2013 Author Share Posted January 29, 2013 Thanks guys for your comments.. Quote Link to comment Share on other sites More sharing options...
kumaras Posted January 29, 2013 Share Posted January 29, 2013 Sorry bringing another issue .......Actually I wanted to open a thread on somewhat similar type of issue I am having. It is not paint dots but few stain marks/patches on the windows.Tried with glass cleaner, but couldn't get rid of them. I was told (by a painter) that thin sand paper with water will remove these but I was fussing due to fear that it will damage the glass. Can any of above solutions be applied in my case ? pls advise Thanks, Kuma Quote Link to comment Share on other sites More sharing options...
terrabytetango Posted January 29, 2013 Share Posted January 29, 2013 (edited) Surgical spirit might leave a white residue on some surfaces. Don't use Brasso if you dash has a texture, whatever gets in the cracks will show up when it dries, also Brasso is notorious for making matte surfaces shiny. It's fine for the gauge cluster window though, just make sure to use light amounts, if you rub too hard on one spot for too long you run the risk of making that area too concave, and you might start seeing odd reflections. Edited January 29, 2013 by terrabytetango Quote Link to comment Share on other sites More sharing options...
