I Cant Change Gear When The Engin Start
aadl198733
My car is lancer CS1 manual
weekend running car
When i was go to the office I park on the rode(not a in-house parking )
Eventing start the car I cant change gear when the engin start but engin is off its smoothly change
please advice to me
8 answers to this question
Come on dude, at least give a detailed answer without copy pasting my own question to you... If you need people to help you, help people by explaining your situation.
  • Like 5
My first guess is that your clutch slave cylinder (also called the clutch fork) is faulty. This is located in the gearbox and is coupled with the release bearing. It could also be the master cylinder, but the CS is known for slave cylinders giving trouble (as per UniMo) after about 60,000km of running.
Try this:
- Put the car into neutral and start the engine
- Press and release the clutch about 5 - 6 times in a pumping action (fully press and release)
- Press and hold the clutch
- Try shifting into first gear
if it shifts normally, then there is definitely a master/slave cylinder problem. Again, I'm guessing it's the latter. The thing about failing slave cylinders is that the clutch starts to feel a bit too soft. I'm not quite sure why yours is normal. Did you do a brake repair recently? How's the condition and level of your brake fluid?
Are you pressing the clutch to move the gear lever?
Is it a rear wheel drive car? If so, your transmission mounts might be shot.
Edited by terrabytetango
