4DR5 Posted December 14, 2015 Share Posted December 14, 2015 Hi, I hope someone can help me out. I have a 2014 Mitsubishi Lance Ex (GLS), and I just noticed that when I press on the brake pedal, while the car is in park (without shifting to any gear), I hear a loud clicking noise. I do not hear any clicking noise at any other time when pressing the brakes. It specifically only clicks when I press the brake pedal while the car is in park and turned on. It seems like the clicking noise is coming from inside the center console or shift. I do not remember ever hearing this clicking noise before, and it's pretty loud and noticeable. Does anyone have an idea if this is normal, or what the issue could be? Thanks 4DR5 Quote Link to comment Share on other sites More sharing options...
Davy Posted December 14, 2015 Share Posted December 14, 2015 I believe this is coming from the shift lever locking mechanism. In order to move the lever out of the "P" position, the ignition should be ON and the brake pedal should be pressed. It is when both these conditions are met that the shifter is unlocked. This is done to prevent damage to the transmission. While there can be a slight click heard from the centre console, a loud noise is not acceptable IMO. My advice is to take your car to a mechanic (or better, UniMo) and have it checked. There is a small spring that keeps the latch in place and it might have come off. 2 Quote Link to comment Share on other sites More sharing options...
Watchman Posted December 14, 2015 Share Posted December 14, 2015 In some (most) cars u cant move the gear out of "P" without pressing the brake. It's to avoid the gear accidentally slipping out of P. So what you maybe hearing is the unlocking. Not sure how "loud" yours is, but it should be fairly low. Quote Link to comment Share on other sites More sharing options...
4DR5 Posted December 14, 2015 Author Share Posted December 14, 2015 hi, sound comes even if you don't shift gear...but every time you press brakes while at the parking mode Quote Link to comment Share on other sites More sharing options...
Davy Posted December 14, 2015 Share Posted December 14, 2015 (edited) On 12/14/2015 at 11:00 AM, 4DR5 said: hi, sound comes even if you don't shift gear...but every time you press brakes while at the parking mode You don't have to shift for the shift lock to engage or disengage. Simply pressing the brake pedal disengages the lock. Letting go of the brake pedal engages the lock, so that the shifter can't be moved out of P. The noise you're hearing is most probably this mechanism switching on and off. EDIT: Just checked the CVT workshop manual for the Lancer EX (shared here. Look for the document named GR00004800-23A.pdf), and it looks like the shift interlock mechanism is operated by a cable (on some vehicles this is operated by a solenoid). The mechanism is pretty straightforward and it might be that yours just needs adjustment. The cable is a spring-adjustable one. Edited December 14, 2015 by Davy 2 Quote Link to comment Share on other sites More sharing options...
terrabytetango Posted December 14, 2015 Share Posted December 14, 2015 I got this sound when I had my Vios. I couldn't press the button on the shifter without pressing the brake pedal, the click is the shifter button unlock mechanism. Quote Link to comment Share on other sites More sharing options...
Ruslan Posted December 14, 2015 Share Posted December 14, 2015 On 12/14/2015 at 3:36 PM, terrabytetango said: I got this sound when I had my Vios. I couldn't press the button on the shifter without pressing the brake pedal, the click is the shifter button unlock mechanism. In Mine too (Vios 2006) apparently it's cable driven. Quote Link to comment Share on other sites More sharing options...
Hoonigan Posted December 15, 2015 Share Posted December 15, 2015 The shifter lock is barely audible normally. 'Loud' is subjective here so it could be nothing out of the ordinary. If it's distinctively 'loud' it's better to get it looked at. Quote Link to comment Share on other sites More sharing options...
amerh82 Posted October 30, 2019 Share Posted October 30, 2019 On 12/14/2015 at 9:44 AM, 4DR5 said: Hi, I hope someone can help me out. I have a 2014 Mitsubishi Lance Ex (GLS), and I just noticed that when I press on the brake pedal, while the car is in park (without shifting to any gear), I hear a loud clicking noise. I do not hear any clicking noise at any other time when pressing the brakes. It specifically only clicks when I press the brake pedal while the car is in park and turned on. It seems like the clicking noise is coming from inside the center console or shift. I do not remember ever hearing this clicking noise before, and it's pretty loud and noticeable. Does anyone have an idea if this is normal, or what the issue could be? Thanks 4DR5 Expand Hi, i change my tires yesterday and the same exact clicking sound came up, i drove my car for 3 years and it was the first time i heard this sound, its a lancer gls 2009, mechanic say its normal, would really like to know how you managed yours, and what do you think of this car in brief, many thanks Quote Link to comment Share on other sites More sharing options...
shakes Posted May 22, 2020 Share Posted May 22, 2020 (edited) i have just experienced same problem ,, knocking sound coming under gear lever cover when i press my brake petal while the car ignition power is on or car idling and gear lever on parking or neutral mode , Audi A4 1.8 T 2013, i have been driving this car for the past 6 years , nver heard tht noise previously Edited May 23, 2020 by shakes Quote Link to comment Share on other sites More sharing options...
Kavvz Posted May 24, 2020 Share Posted May 24, 2020 (edited) On 5/22/2020 at 10:39 PM, shakes said: i have just experienced same problem ,, knocking sound coming under gear lever cover when i press my brake petal while the car ignition power is on or car idling and gear lever on parking or neutral mode , Audi A4 1.8 T 2013, i have been driving this car for the past 6 years , nver heard tht noise previously Expand No big deal, its probably your shifter solenoid engaging (don't think you should hear it in when the shifter is in N though). Read above ?its been explained quite well by multiple members. The reason you are hearing it now in a pronounced manner vs before, is due to wear. Edited May 24, 2020 by Kavvz 1 Quote Link to comment Share on other sites More sharing options...
