Toyota Corolla 141 ABS modulator
effdog
Need to replace the ABS modulator of 2008 toyota corolla 141. But its nowhere to be found. Ive been searching for months now. They have it at Toyota Lanka at a price of 263000lkr.|(Not an option :D) ..if u know any place or anyone who can get me this part..please let me know..big help
Out of curiosity, how was it determined that the ABS module was faulty? Local mechanics love to replace stuff like this when the actual problem is elsewhere like wheel speed sensors.
  On 9/28/2016 at 2:51 AM, effdog said:
  On 9/28/2016 at 2:15 AM, Davy said:
It shows as "open ABS circuit relay" on the scan. I've tested and scanned with over 5 technicians/mecahnics. I did not check with Toyota Lanka, although I think I should do it. I literally searched every where for this. So fed up come to a point I would sell this.
How do you plan on selling it with an ABS warning light, if I may ask :)
@effdog, your quote seems to be messed up, so quoting an old post to respond.
Did any of the 5 mechanics test the ABS relay first? The ABS relay is located in the fuse box under the bonnet. To me it looks like replacing the ABS module without checking anything else isn't a good idea.
here is the exact error. what can u tell me about this? thanks in advance
There are two errors in there. The first one C0273 is the one related to your ABS system. The error is a continuity issue, so you shouldn't blindly replace the ABS module and expect the issue to go away without checking the simple things first.
- The first thing you should check is the ABS relay in the engine bay fuse box.
- Check all wheel speed sensors and continuity from wheel speed sensors to ABS actuator. If you're unable to identify the issue, I suggest taking the car to Toyota Lanka so that they can do a much thorough diagnosis.
The second error is also a continuity issue in the CAN BUS. This may or may not be related to the ABS error, but your wire harnesses definitely have a lose connection. Time to do a thorough clean-up of all the connectors. Do you observe any lack of power or high fuel consumption?
This could actually be a loose connection, I had a similar experience with lights not working, company fixed a new light switch stalk when it did not work only they checked the connections. Since I was present they could not charge for the replacement.
Contact cleaner might do the job
Thank you very much :) ill let u know what happened
thank you for the advice :)
