Hi all,
I noticed today after about 250Km run. (Very Heavy footed) the radiator fan kept running after ignition off for about 2 min and there was a whirring sound for another 15-30 sec. It's my Mazda.
Is it normal cos it has not done that before and non of my previous cars or my  Vezel has done that.
Thnx
I saw in  some forums that the sound is due to injector self cleaning. I do not know what that is though.
i don't think it's a worn bearing cos it's clocked only 10,000Km
45 minutes ago, Twin Turbo said:
This is worse than the guy who complained of smoke comming from a pipe at the back of his car,...:D:D:D
Really? How so?
@Quiet, You may want to refer your owner's manual with regard to the whirring sound. Is this whirring sound coming from the engine as well?
1 hour ago, Davy said:
Really? How so?
Oh well the manual says radiator fan working after ignition off is normal.  I can't find any info about the other sound. There are few posts in the net about the same sound I guess.
I ll ask agents next time I go there what that is.
sorry guys, not a vehicle expert ?
if you are unable to help OP, please just back-off.
Dont be, this is 100% valid question and more members will refer this latter. so please try to report back whatever the information you have once you solved this problem.
4 hours ago, Davy said:
Really? How so?
The vehice is being driven in a hot climate, I would not be fazed by it but just check the coolant level in the expansion tank.then move to further checks in-depth,...
:closedeyes:
p.S.  Most of our drivers don't look at the temp gauge even when the engine is steaming ,..!
Edited by Twin Turbo
:closedeyes:
While the fans running for longer is normal when the coolant has reached a certain temperature, the concern here is about a whirring sound which I think is perfectly okay to be concerned about, because sounds emitted before or after a vehicle is switched on/off is not really identical on every car.
