Continuous excessive vibration in Drive mode with brake applied
  • Author
On 2/21/2017 at 1:46 PM, Rumesh88 said:
Was your EGR valve inspected/tested during the last tune up?ย
i'm not sure about that? But As I mentioned Dhammika did the tuneup job. He checked all relevant readings for the engine sensors and all. Hopefully he did that too.ย
EGR should be removed from the manifold for inspection. If you were around when the tune up was done you would have noticed him removing the EGR. A stuck EGR may not show up in sensor readings forย this engine.
  • Author
hi guys,
I changed the rear engine mount with the original spare. Everything is very smooth now. Omg I might have done it early. Anyway thanks for all for your thoughts.
  • 4 years later...
