June 16, 20179 yr machanla mata thiyenne 2002 Vitz ekak 1000 cc. eke pickup harima adui. wahanayak issara karala yanna hari amarui. Tune up ekak karoth hariyaida? nathnam meka vitz model eke hama wahanayakama (including late models) thiyena prasnayakda?
June 16, 20179 yr Vitz SCP10. From personal experience I can confirm it has quite goodย pulling power particularly below 70kmph speed. Make sure your transmission is in good shape and properly maintained with timely ATF changes and gears change at the proper RPM and load. Getย a scan done to make sure you do not have stored codes. Yes, do a tune up which is usually nothing more than a throttle body and injector clean up, change of plugs, air andย fuel filters, check and change injector washers etc. Check fuel pressure. Also make sure they clean OCV filter (ย VVTi ย will not properly kick inย if OCV filter is blocked) and PCV valve at the tune up. Also if possible clean the cam cover internals too. Hope I covered every bit.
June 16, 20179 yr I think its the same in all 1 liter Vitz. They are noisy as well, also they vibrate like shit!
June 17, 20179 yr 14 hours ago, fiat fan said: I think its the same in all 1 liter Vitz. They are noisy as well, also they vibrate like shit! That doesn't necessarily applies to a 2001 - 2005 SCP10 Vitz. It has a 4 cylinder engine. The ones came after 2004 (KSP90) had a 3 cylinder 1KR engine which had mentioned issues.
June 17, 20179 yr Change the air filter, spark plugs and the ATF. At lest you car should run more efficiently with these changes. TT.
June 17, 20179 yr 12 hours ago, hrm said: That doesn't necessarily applies to a 2001 - 2005 SCP10 Vitz. It has a 4 cylinder engine. The ones came after 2004 (KSP90) had a 3 cylinder 1KR engine which had mentioned issues. Yes I was talking about the new one. We had a 1st gen vitz with the 1.3 engine, that was very good and very fuel efficient. I have heardย the 1 liter in that model was also not good.
