Toyota passo vibration problem
GayanSameera
Just bought a toyota passo but when idling the engine vibrates too much and shakes the car. When idle and on 'D' drive, the engine vibrates too much and shakes the car literally. I got the engine mount replaced but the problem is worst. Can you help plz.
Edited by GayanSameera
6 answers to this question
Welcome to the forum and congratulations on the car.
Did you get all engine mounts replaced or just one (because you said "mount")? The are at least 3 mounts holding the engine and transmission in place, and all of them need to be replaced together to avoid premature wear of new mounts due to the inability of older mounts to absorb engine vibration as much.
Also, does your car idle properly at about 700 - 750 RPM? If you don't know the history about when the last tune up was done, it would be good to do one.
Expand
Hey, are you still having this issue? or already found a solution? I'm having the exact same issue with my Passo and found no luck yet. I've been seeking opinions of tech guys but nobody could figure out the real cause. So I'd really appreciate it if you could provide me some information. Thanks.
Expand
If your car had no fault with electronics please read the answer given by @Davy at the top of this tread
regards
JC
Expand
Slight changes in the chassis (i.e. high chances due to heavy accidents) could lead to significant engine vibrations.
If it is a 3-pot engine, it even gets worse.
The topic has been discussed for various other cars in the forum.
Vibration in Vitz
Pls do a search, they might help you!
