December 22, 20187 yr Has anyone used a portable jump starter? I have seen plenty of them availabe online to purchase starting from Rs.6000.00. Do you recommend using them?
December 22, 20187 yr Yea they work about 3 - 4 times on a diesel, petrol can go more, but avoid ene charge vehicles like wagon R etc
December 22, 20187 yr Author Thank you tiv. No harm on using them on a full hybrid then. Any recommended brands? ย ย ย
December 22, 20187 yr I don't know any proper brands, mostly generic Chinese ones but they work, good for an emergencyย
December 22, 20187 yr 4 hours ago, d.malan9 said: Has anyone used a portable jump starter? I have seen plenty of them availabe online to purchase starting from Rs.6000.00. Do you recommend using them? Bolt power- I am also looking andย have read couple of reviews and supposed to be good.A bit higher onย the pricing side though.
December 23, 20187 yr While I was looking to buy portable jump starters mainly I found 2 type of chargers (There could be more I just did some limited search). One type has capacitors that can use existing charge left on the car battery and gives a boost to start. This one was bit expensive. There was another type that the portable charger has a battery where we need to keep it charged and that battery can give boost to start the car battery. They were cheaper than the capacitor type portable chargers. So personally I use these 2 portable jump starters. (links are only for reference, they were not the exact sellers I bought from)ย AUKEY 18000mAh Jump Starter with 600A Peak DBPOWER 1200A Peak Portable Car Jump Starter ย Here is an example using the "Aukey Jump starter" (Only to show that it works, this video was unplanned and i'm not a professional product reviewer) -ย ย ย
December 24, 20187 yr Author On 12/23/2018 at 9:39 AM, kmeeg said: While I was looking to buy portable jump starters mainly I found 2 type of chargers (There could be more I just did some limited search). One type has capacitors that can use existing charge left on the car battery and gives a boost to start. This one was bit expensive. There was another type that the portable charger has a battery where we need to keep it charged and that battery can give boost to start the car battery. They were cheaper than the capacitor type portable chargers. So personally I use these 2 portable jump starters. (links are only for reference, they were not the exact sellers I bought from)ย AUKEY 18000mAh Jump Starter with 600A Peak DBPOWER 1200A Peak Portable Car Jump Starter ย Here is an example using the "Aukey Jump starter" (Only to show that it works, this video was unplanned and i'm not a professional product reviewer) -ย ย ย Thank you mate for the wonderful explanation.
