virajh Posted August 15, 2019 Share Posted August 15, 2019 I would like share & get your ideas, experience regarding to engine oil for 'AE110' , For my , Year 1998 Engine Oil : Mobil 2000 10W,40W Quote Link to comment Share on other sites More sharing options...
Devinda_Z Posted August 15, 2019 Share Posted August 15, 2019 What is the mileage like on your AE110? What oil are you currently using? Quote Link to comment Share on other sites More sharing options...
Twin Turbo Posted August 15, 2019 Share Posted August 15, 2019 Hi, for a car more than 2 decades old, yes , use a 40 weight oil and keep the oil level in check and topped up,.. And change your air filter. 1 Quote Link to comment Share on other sites More sharing options...
virajh Posted August 16, 2019 Author Share Posted August 16, 2019 On 8/15/2019 at 2:42 PM, Devinda_Z said: What is the mileage like on your AE110? What oil are you currently using? Expand Millage around 190K Engine oil brand: mobil super 2000 Quote Link to comment Share on other sites More sharing options...
virajh Posted August 16, 2019 Author Share Posted August 16, 2019 On 8/15/2019 at 9:21 PM, Twin Turbo said: Hi, for a car more than 2 decades old, yes , use a 40 weight oil and keep the oil level in check and topped up,.. And change your air filter. Expand Hello, Currently use 10W-40 Mobil supper semi synthetic oil. but now recently noted oil level deceasing issue. Thanks for sharing your advice with here Quote Link to comment Share on other sites More sharing options...
iRage Posted August 16, 2019 Share Posted August 16, 2019 On 8/15/2019 at 12:04 PM, virajh said: Thank you so much for your quick words, Actually my car made in 1998 and currently use Mobil 2000 10W,40W semi synthetic oil , car did around 190K. Budget is ok for me , highly appreciated if you could suggest a good en Expand I replied to you on the other thread.....That seems fine for a vehicle with that much high mileage....why do you not like the oil you are using ? Finally...please do not go around asking the same question on multiple threads.... 1 Quote Link to comment Share on other sites More sharing options...
iRage Posted August 16, 2019 Share Posted August 16, 2019 Discussion from other thread :(I will be deleting the posts on the other thread): On 8/15/2019 at 11:24 AM, virajh said: Dear iRage, Could you please share the experience of your 110 car engine oil. it will more helpful for me. Expand I have never owned a 110 on a long term basis. But then again, type of engine oil is very subjective as what works for my engine might not be the best thing for your engine. A "not so worn out" engine would do quite well with a thinner oil and if a heavier oil is needed it would purely for heat absorption in a high temp environment like Colombo. On the other hand, if the engine is somewhat worn out, one might be tempted to use a thicker oil anyway in the interest of maintaining oil pressure and such. As for whether you should use synthetic or mineral oils...again...that is also subjective as it depends on your vehicle usage and conditions and budget. ======= Thank you so much for your quick words, Actually my car made in 1998 and currently use Mobil 2000 10W,40W semi synthetic oil , car did around 190K. Budget is ok for me , highly appreciated if you could suggest a good en 1 Quote Link to comment Share on other sites More sharing options...
virajh Posted August 16, 2019 Author Share Posted August 16, 2019 On 8/15/2019 at 2:42 PM, Devinda_Z said: What is the mileage like on your AE110? What oil are you currently using? Expand Currently using On 8/16/2019 at 5:43 AM, iRage said: I replied to you on the other thread.....That seems fine for a vehicle with that much high mileage....why do you not like the oil you are using ? Finally...please do not go around asking the same question on multiple threads.... Expand one of my friend told me recommended viscosity is 10W-30. actually i have no idea of current engine oils brands. that why i'm searching this on AL to get an idea for me. also i think this will helpful for others too. I'm New to AL and thank for your support... Quote Link to comment Share on other sites More sharing options...
iRage Posted August 16, 2019 Share Posted August 16, 2019 On 8/16/2019 at 6:36 AM, virajh said: Currently using one of my friend told me recommended viscosity is 10W-30. actually i have no idea of current engine oils brands. that why i'm searching this on AL to get an idea for me. also i think this will helpful for others too. I'm New to AL and thank for your support... Expand If the engine is relatively unworn...then yes a lighter oil would work....but then if the engine is worn with age..a heavier oil would be better.... As for brands... Mobil, Castrol, LiquiMoly, (do we still have the proper Penzoil ?)...etc... 1 Quote Link to comment Share on other sites More sharing options...
Devinda_Z Posted August 16, 2019 Share Posted August 16, 2019 I'd say a 40 viscosity semi synthetic but again knowing the mileage would help! 1 Quote Link to comment Share on other sites More sharing options...
Devinda_Z Posted August 16, 2019 Share Posted August 16, 2019 On 8/16/2019 at 3:23 AM, virajh said: Hello, Currently use 10W-40 Mobil supper semi synthetic oil. but now recently noted oil level deceasing issue. Thanks for sharing your advice with here Expand The brand, type and viscosity of the oil you currently use sounds fine but i'd be more concerned about the oil level decreasing.... Any noticeable leaks? Any residue under the car when parked overnight? How much oil do you top up and how often (in terms of km's run between top ups?) Quote Link to comment Share on other sites More sharing options...
virajh Posted August 21, 2019 Author Share Posted August 21, 2019 On 8/16/2019 at 4:49 PM, Devinda_Z said: The brand, type and viscosity of the oil you currently use sounds fine but i'd be more concerned about the oil level decreasing.... Any noticeable leaks? Any residue under the car when parked overnight? How much oil do you top up and how often (in terms of km's run between top ups?) Expand still no leak founded, oil level is between High and low ( half level), top ups in nearly 3 months ago. Thanks for your support. Quote Link to comment Share on other sites More sharing options...
