So we all know there are websites which we can enter the VIN number of the vehicle and get part numbers (Eg: https://partsouq.com/) but did you know that Mitsubishi has their own proprietary E-catalog software which includes all the part numbers, descriptions and illustrations applicable to their export market vehicles? It's far easier to find part numbers using this software compared to any website out there, and there is a wealth of other information about any part which could be immensely helpful.
Here are some screenshots:
Enter the VIN:
Search for the part you want! You don't even have to know the exact name it's called, eg: if you're looking for the power steering belt just search for "belt".
And you'll be presented with a list of "belts" applicable to your vehicle.
Double click on the P/S belt option, and you'll get the part number:
And an illustration of the part
Pretty cool, right? You can click on any illustrated part (click the reference number) and get all the information you need about that part.
Installation info:
The application must be installed in the C:/ drive
Run the installer
Click on the “ Extract ” button
Run the "install.bat" file in the installation directory (C:/MMC/ASA). This will copy the ASAMAIN.ini file to the C:/WINDOWS directory.
Make sure that the installer copied the ASAMAIN.ini file to the C:/WINDOWS directory. If the ASAMAIN.ini file is not in the C:/WINDOWS directory , you must manually copy it there from the C:/MMC/ASA folder.
Run the application from the desktop
Click OK
Download link:
https://mega.nz/file/DkEyVaRY#TAb_D4ijRRGxNfHkxxtyMdV_kd1kgUVEuUOeSIXd9sc
Edited by Hyaenidae
  • Like 3
  • Thanks 3
Good info! Thanks for sharing mate. ?
I just remembered that I had a CD ages ago for the Lancer CS where it had Technical bulletins and videos of how to conduct diagnostics - sort of like training videos from Mitsubishi. It was given to me by a trusty automotive engineer who had ties with Mitsubishi. It was probably for internal use only (just like this software is I'm sure).
Edited by Davy
Indeed this is immensely useful. Mitsubishi has really thought this through.
2 hours ago, Hyaenidae said:
crazy how?  ?
Crazy as in very enthusiastic bunch. I'm impressed really! That's what the "more power to y'all" meant. Hope you didn't take it as Angoda patient crazy?
Yeah I'm still learning the ropes too, found out that you can find which models share the same part, should be useful when hunting for used parts... for example, the outer door handle:
IKR? They should distribute this software along with the owners manual.
I knew it was a compliment :D You are too much of a car nut to call me Angoda patient crazy for unearthing a treasure trove like this ?
