Hello... a Newbie here...
Looking to buy a set of tyres in the size 195/45 R16... (For a 2016 Fiesta)
Looks like this size is a bit rare in SL.... looked at a couple of places but wasn't able to find.
I'm looking for something from a mainstream brand... Michelin, Dunlop, Yoko, Bridgestone, Pirelli..etc.
How do I import a set of tyres if I can't find them..... anyone done that before?
Would appreciate if someone could share their experience..
Thank you in advance..
195/50R16 seem to be a factory size for Ford Fiesta.
Thanks @kmeeg
I haven't yet bought the car... thought of doing a bit of due diligence beforehand..
I was thinking of changing the wheel and the tyres to 195/50 R15 (an available size in SL).. this lowers the car by just 5mm.... but the added cost of a  set of alloys is difficult to justify.... plus the OEM wheels look rather nice.
But you are right.. from factory if the tyre size 195/50 R16 is available.. then it should not create any interference when turning the wheels.. hopefully
@NadC I'd advise against changing the tire size simply on account of lack of availability.
I had a Fiesta briefly last year and don't recall there being any shortage of options. I purchased a set of Yokohama BlueEarths from UniMo the agents - speak to Ruwan 77 299 1005 & feel free to mention my name.
Generally as a rule of thumb one must maintain the same rolling radius as illustrated in @kmeeg's visuals https://tiresize.com/calculator/
Also if you just want to get a price indication the following local websites are a good place to do some desk research
https://tyrebass.lk/
https://greasemonkey.lk/
Thanks @kmeeg
Also don't forget that downsizing isn't always possible - you need to consider the the clearance between your brake callipers and the rims, the offset of the new rims etc
Also if you're after a UK made Fiesta the PCD is different to the Thai made Fiesta's 100x4 stud pattern which is commonly available as found on a number of Japanese cars, so changing rims isn't going to be straightforward as you assume
11 minutes ago, NadC said:
Thanks @kmeeg
@NadCif you haven't already bought it search the forum for a post I made on the gearbox.
That new 6 speed dual clutch transmission which Ford uses is a disaster.
They've lot law suits in multiple countries on account of issues or outright gearbox failure.
If you can find a manual, great or worst case the 4 speed auto (not perfect either - has it's inherent flaws but can be fixed/tweaked) - but that wasn't an option on the facelifted Fiestas if I recall.
New tires will be the least of your worries if that DCT packs up!
Thanks @Devinda_Z for your comments.. I'm worried about buying that now.. I will search for the thread on the DCT... I really don't want to have gearbox problems as this will be my daily driver for a while..
That it true. This is my experience with my friends Ford. Utter disaster. (Screenshot from his mail when he got the issue.)
Transmission failure at 45k oh boy! And I thought my experience with Nissan's were bad...So what happened? Did he replace the transmission or was there a fix?
Transmission replaced machan. Ford said they replace transmission for 7 years / (forgot the miles limit) at 0 out of pocket.
If I recall properly, this was a problem specific to 2012 - 2014 models. Later models of Ford Focus comes with a standard auto gearbox (again its 6 speed I think). Manufacturers world over, have given up on DCT now.
If you get a 2011 model Focus it shouldn't be a problem. I've owned one for 9 years now. It's a somewhat boring but reliable car. Not as boring as a premio or Allion of course.
@Devinda_Z didn't your Fiesta come with the same NON-DCT box?
@Crosswind that's correct - i think we both may have had the same 4F27E / FN4A-EL 4 speed conventional automatic
Some of those had that shift flare & various other well documented imperfections that prevented some boxes from being smooth but they worked and parts to repair/improve or even rebuild were plentiful as well as reasonably priced.
