Crosswind Posted September 29, 2013 Posted September 29, 2013 Hey guys, sorry to be bumping this old thread but I have a question to ask. I own a 1967 Volkswagen beetle and my car has this consistant "whisling" sound from the exhaust, almost similar to a kettle's whisle when its boiling water. What could be the cause of this? I checked many youtube videos and in every video i saw of 67 beetles, the sound is a lot different from the exhaust and there is no "whisle" sound. a lot of people commented that that sound is not normal for a beetle when i asked, then again I thought it cant be because when i took the car to the garage i was told that the noise is perfectly normal and its the "unique" beetle exhaust sound. i have heard the same whisling sound from other beetles aswell, can someone tell if this is a common problem in Sri lankan beetles ? or theres a problem with the engine? exhaust leak? Quote
NZer Posted September 29, 2013 Posted September 29, 2013 Some beetles have this exhaust note and its completely normal. Quote
Komisiripala Posted September 29, 2013 Posted September 29, 2013 It could be a leak through a small aperture, causing a whistle. Dunno whether it's normal but I've been in a few beetles of that era which did do this. The odd note is a vivid memory Quote
GTAm Posted September 30, 2013 Posted September 30, 2013 I always thought that they had a whistling sound..... !? Maybe the VW workers were whistling while they worked on them, the car may have caught the "bug" Quote
Supra_Natural Posted September 30, 2013 Author Posted September 30, 2013 Hey guys, sorry to be bumping this old thread but I have a question to ask.I own a 1967 Volkswagen beetle and my car has this consistant "whisling" sound from the exhaust, almost similar to a kettle's whisle when its boiling water. What could be the cause of this? I checked many youtube videos and in every video i saw of 67 beetles, the sound is a lot different from the exhaust and there is no "whisle" sound. a lot of people commented that that sound is not normal for a beetle when i asked, then again I thought it cant be because when i took the car to the garage i was told that the noise is perfectly normal and its the "unique" beetle exhaust sound. i have heard the same whisling sound from other beetles aswell, can someone tell if this is a common problem in Sri lankan beetles ? or theres a problem with the engine? The whistling exhaust note is normal As far as I know, it's like the car's signature sound.... Quote
ABR Posted September 30, 2013 Posted September 30, 2013 (edited) Thanks for the replies guys.. I recorded a short video of the sound because I'm still not 100% sure about it.. Maybe I'm too obsessed with having everything original with this car.. i just want to be sure theres no problem with it before i can take it out on the roads. edit - link removed Edited October 3, 2013 by ABR Quote
maheshw Posted September 30, 2013 Posted September 30, 2013 well the sound is very closed to original vw sound & i feel its ok.... Quote
Supra_Natural Posted October 1, 2013 Author Posted October 1, 2013 Thanks for the replies guys.. I recorded a short video of the sound because I'm still not 100% sure about it.. Maybe I'm too obsessed with having everything original with this car.. i just want to be sure theres no problem with it before i can take it out on the roads. Actually, you may be onto something... that sound is a bit different from the standard Vee dub motor... I'm not sure what exactly is causing it though, It MIGHT be from the fan, or something from the exhaust as you suspect. Best thing to do is show it to a proper VW mechanic, not a general workshop. Quote
Jaliya48 Posted October 1, 2013 Posted October 1, 2013 (edited) One beetle I traveled in sounded exactly like yours. It was a 2sri example. What is your car's manufacture year and/or registration? Edited October 1, 2013 by Jaliya48 Quote
Komisiripala Posted October 1, 2013 Posted October 1, 2013 that's not the exhaust. some belt maybe? alternator freaking out? definitely a mechanical metal rubbing sound. you can hear the exhaust whistle at the very end when you rev her up. like supra said. i too smell a rat. get it checked out before something catches fire Quote
ABR Posted October 2, 2013 Posted October 2, 2013 thanks for the replies all, getting this sorted out soon.. Quote
ABR Posted October 2, 2013 Posted October 2, 2013 (edited) Took the bug out for a spin, experienced a lot fo misfiring, not sure if its because car is almost out of fuel or what. no problem with the spark plugs, all of them were replaced. Misfiring is similar to this (NOTE - this is not my car) i can upload a vid of the car idling if necessary. how can i fix this problem? any help is appreciated .. Edited October 2, 2013 by ABR Quote
MrCat Posted October 2, 2013 Posted October 2, 2013 Perhaps check the little condenser attached to the coil? Quote
ABR Posted October 2, 2013 Posted October 2, 2013 Perhaps check the little condenser attached to the coil? new aswell, no problem with it. Quote
ABR Posted October 3, 2013 Posted October 3, 2013 (edited) edit - nvm, problem sorted Edited October 4, 2013 by ABR Quote
mnaka Posted October 5, 2013 Posted October 5, 2013 The baffles in the tail pipes makes the whistle sound, typically, only the ones with loose baffles will whistle, original factory tailpipes actually had fiberglass packing inside them and when time goes this packing will get distorted then again the whistle appears, remove your tail pipes and see the sound difference Quote
