need to know more info specs and user comments on the 94 vista petrol model,
appreciate your feedback and comments...thanks
Our company ran a couple of SV40's (1996/7 models Camry).
To put it in one line its ... Carina 212 comfort and economy for AE 100 money.
I have a friend who gets about 9/10km/l driving mostly in Colombo off peak on a Camry manual 1.8 litre. Auto should do 7-8 with careful driving.
While the Camry parts are still available (body and trim)...the Vista was a little rarer. I suggest a jaunt down Delkanda just to check.
Anything in particular you need to know?
Only thing though is that most of these cars are quite hacked by now. Have it checked before picking it up.
  • 11 years later...
Guys, are there any other cars that use the same engine and suspension parts as the vista sv40? also how much does a 2litre petrol SV41 do on fuel actually? The auto transmission. Will it do at least 7 ? Also whats the difference between the SV40 and the SV41?
Edited by PreseaLover
https://www.amayama.com/en/catalogs/toyota/vista/4-sedan-right-v40-1994-2449/1/5
Once you click on a part it will tell you what other cars that part came in and where it fit, go crazy 😛
S means it has a Toyota S engine.
SV40 -> 1.8L 4S-FE engine. Came in most 1.8L Petrol Toyotas of the period. Carina, Corona/Caldina
SV41 -> 2.0L 3S-FE. Carina/Corona/Celica/Noah+TwonAce+LiteAce/RAV4,etc....
Are you looking a the hardtop or the sedan ?
ah right. whats the difference between the hardtop and the sedan?
hardtop has frameless doors....sedan normal doors....
slight differences in the lights and body trim and grade levels..
ahhh im looking for the hardtop :) very hard to find petrol vistas in sri lanka noh
Yes...it was something that carried on from the V30 series onwards. Back then the import duty was not too bad that these cars were affordable for most. The popularity grew more as government permits were introduced (most of which had a capacity limit of 2000cc for diesel cars). So for those who wanted a nicer car than the usual Corolla/Sunny/Lancer/Carina/Corona/Bluebird..the prime choices were the Vista/Camry (where the diesel was better vlaue for money).
