Kavvz Posted September 18, 2011 Posted September 18, 2011 (edited) i use it about 2-3 times an year.... you don't really need a mechanic to use this cos you're supposed to add this...top up the tank and run until the product slowly cleans your entire fuel system. however...in my experience...this alone wont keep your throttle body and injectors clean... I do throttle body clean up and manual injector clean up when necessary despite using this product. but then again...they advise to use it every service so maybe that's the reason i needed direct intervention also...there's another product by wurth where you spray-in the injector cleaner straight into the throttle body. possibly that's the one your mechanic wanted cos you need to remove the air intake to access the throttle body opening to use this +1. I use a similar product by STP and I use it every other service. Its pretty straight forward, just tip the entire contents of the bottle into a full or nearly full tank of fuel as per the directions on the bottle. Don't try concentrating it as over concentrating the product by adding it to a smaller amount of fuel may damage your seals and your catalytic convertor. Edited September 18, 2011 by Kavvz Quote
luckey007 Posted September 19, 2011 Posted September 19, 2011 Machan I bought a big mac meal from McDonalds and I don't know how to use it. Please tell me what to do. Open the box, remove the foil, put the contents inside the box in to the mouth, then pump full cup of beverage. Dispose of the empty box and the foil in a responsible manner. Make sure you put to the correct opening. 2 Quote
VVTi Posted September 19, 2011 Posted September 19, 2011 Machan I bought a big mac meal from McDonalds and I don't know how to use it. Please tell me what to do. Seriously mate! Ha ha ha ha. One of these days, someone will come and ask, I bought a Condom. How do I use it? ROFL. 1 Quote
shanX Posted September 19, 2011 Posted September 19, 2011 (edited) ripper, where can i get a manual injector clean up done? any recomended places? In Kandy? There's a place in Penideniya, Peradeniya *just noticed that it was an old post Edited September 19, 2011 by shanX Quote
Gyiman Posted September 20, 2011 Posted September 20, 2011 Where's the car tuning place in Thalangama? Can someone PM me? Quote
Sylvi Posted September 20, 2011 Posted September 20, 2011 Members, Can any member give what are the solvents the injector cleaners are mixed with. I have read in foreign motor forums they have mostly kerosine and (IPA) alcohol. Sylvi Wijesinghe. Quote
Kavvz Posted September 21, 2011 Posted September 21, 2011 (edited) Members, Can any member give what are the solvents the injector cleaners are mixed with. I have read in foreign motor forums they have mostly kerosine and (IPA) alcohol. Sylvi Wijesinghe. Didn't google this up until you mentioned it but yes; based on the chemical mix listed the stuff I use does seem to have some kerosene in it... Edited September 21, 2011 by Kavvz Quote
Sifaan Posted September 21, 2011 Posted September 21, 2011 Where's the car tuning place in Thalangama? Can someone PM me? www.asnulanka.com Quote
