i use it about 2-3 times an year.... you don't really need a mechanic to use this cos you're supposed to add this...top up the tank and run until the product slowly cleans your entire fuel system.
however...in my experience...this alone wont keep your throttle body and injectors clean...
I do throttle body clean up and manual injector clean up when necessary despite using this product.
but then again...they advise to use it every service so maybe that's the reason i needed direct intervention
also...there's another product by wurth where you spray-in the injector cleaner straight into the throttle body.
possibly that's the one your mechanic wanted cos you need to remove the air intake to access the throttle body opening to use this
+1.
I use a similar product by STP and I use it every other service. Its pretty straight forward, just tip the entire contents of the bottle into a full or nearly full tank of fuel as per the directions on the bottle. Don't try concentrating it as over concentrating the product by adding it to a smaller amount of fuel may damage your seals and your catalytic convertor.
Edited by Kavvz
Machan I bought a big mac meal from McDonalds and I don't know how to use it. Please tell me what to do. ;)
Open the box, remove the foil, put the contents inside the box in to the mouth, then pump full cup of beverage.
Dispose of the empty box and the foil in a responsible manner.
Make sure you put to the correct opening. :)
Seriously mate! Ha ha ha ha. One of these days, someone will come and ask, I bought a Condom. How do I use it?
ROFL.
ripper, where can i get a manual injector clean up done? any recomended places?
In Kandy? There's a place in Penideniya, Peradeniya
*just noticed that it was an old post :blink:
Edited by shanX
Members,
Can any member give what are the solvents the injector cleaners are mixed with.
I have read in foreign motor forums they have mostly kerosine and (IPA) alcohol.
Didn't google this up until you mentioned it but yes; based on the chemical mix listed the stuff I use does seem to have some kerosene in it...
Edited by Kavvz
