BlueRaiden
Everything posted by BlueRaiden
[RECOMMENDATIONS] Willies Automobiles, Kandy
BlueRaiden replied to Jason Bourne's topic in Feedback & Suggestions
Do they undertake repairs as well? Spare parts are very expensive and most probably fakes. Heard both good and bad things about willies on their paint work but not sure about mechanical work. I go to kundasale auto service or excellent auto for mechanical work but there are times i came home disappointed from both places. Suspension of a 141 couldn't be that sophisticated, any greasemonkey would be able to do that with tools. -
I have classics in front and exel gs in rear, allion 260. Ride is not as soft as the oem. Better to go oem.
Medical Ventilator Manufactured by Vega Innovations
BlueRaiden replied to Randy890's topic in General Automotive
Ventilator design is not just a balloon pumping air. Wrong designs will make things worse for the patient.- 6 replies
- vega innovations
- vega
(and 2 more)
Guys did you try using the pioneer menu? I use a 5150BT in my allion. When you turn off audio sources, somewhere in settings, it has steering wheel control configure option. From there, you can attach the functions you want for each key in the steering wheel. I will post some pics later if you want.
When i bought my car also i researched on this. Im not an expert, but my understanding is changing gears often and leaving the car in D while stationary both introduce wear and tear to the system. I have no way to know if my car manual specifies anything because it is in Japanese (Allion 2008). My method is as same as @trinity if the wait is less than 60 seconds leave it in D, if it is more put it in N, engage parking brakes and release service brakes. Over 3 mins stop the engine altogether. It is a good thing that you @Hyaenidae discussed this. I want to know about it as well.
- 30 replies
- 1
- wear and tear
- transmission
(and 4 more)
Try kundasale auto service for mechanical repairs. They are little bit pricey though. But served me well upto this point.
This might be normal. When accelerate from low speeds engine revs up pretty quickly and speed follows gradually. This depends on load slope...etc. More load the higher it takes to acquire speed. But again im not an expert on your model. Better drive a similar specimen and check for yourself.
Here comes the aswaha katawaha. I can feel the R gear engaging in a slope when the cvt has to work against the gravity on my 2008 allion. Also a little jerk on cruising when i put down the accelerator a little after taking off my foot completely off the pedal. Odo is on 95k and maintained from the TL from the start on timely manner. Hope this is the normal behaviour of the cvt.
Buddy you are a lucky person to find a good 1.8. When i was searching i didnt come up with a nicely maintained 1.8. I would have take it in a heartbeat. So dont think 1.5 has better resale value than a 1.8. 1.8 always has the upperhand if it was taken care of properly.
Parking vehicle with front wheels at an angle
BlueRaiden replied to BlueRaiden's question in Mechanical problems
Thanks @ramishkad @ajm. This is what i wanted to know. -
Hello guys....i have two general questions... 1. Is there any mechanical issue\disadvantage if I park my car with front wheels not straight? 2. When the car is stationary, does rotating steering wheel put any additional stresses and wear and tear to steering linkage and EPS system? Thank you.
Spot fuel consumption is only shown when the vehicle is not stationary. Is it the same when the vehicle is moving?
92 is enough. unless you have some deep pockets. Octane type based on engine compression ratio. Higher octanes used on high compression engines to eliminate knock/misfire. Premios and allions use 1NZ-FE engine (1.5) which runs perfectly on 92.
I changed rear shocks of my 2008 allion three weeks ago.Toyota quoted somewhere around 45k (whole kit) for each while the kyb was 16k. Toyota kandy guys said they dont have the shock absorber alone. After changing i feel like the suspension is little bit stiffer but it is tolerable.
Honda Insight 2019 vs Toyota Premio 2019
BlueRaiden replied to tharindub's topic in General Automotive
My one doesn't have 9 leds for the brake lights only 4. Thanks for the info buddy. Didnt know that before. -
Can you explain about it more. Is it specific to 2013 and newer models? I have 2008 allion. It doesn't have passenger air vents. Only front vents for legs and face. -
-Deleted-
You can draw lines on the ground or use a thread to mark out two frames. One close to the car perimeter and the second around half meter away from the first one. (More apart these two, the more accuracy you get.) You can use the overlapping points to calibrate the system. Mind if i ask you where did you get the system fixed? They should be competent enough to do it for you the proper way.
I also recommend you to buy the Toyota from the list. Look for a well maintained car with records. (Preferably service records and import documents as well). Also with no makabass modifications. A basic car is better than one with bells and whistles fitted in srilanka, even for the same price. Look for a specimen with one owner only. It is gonna be a real difficult to find such a vehicle. Also it wont be cheap. (In my case i bought a 2008 allion 2 years ago for more than 1.5 laks above the market price. Made peace with that decision given that i will be using it for the next 6 or 8 years.) It wont have the latest tech but will serve you reliably to get from point a to point b. It is a simple, moderate comfortable vehicle with average fuel economy and space. Typical Toyota feel is there and it is good for long drives. Some guys may not like it much. I bought the car at 80k and added nearly 20k. So far i have done only the routine service, rear shock replacement and one hid bulb replacement. Look out for ac and cvt issues. They are the weakest points in allions and premios. And most jdm cars. Dont buy it for the market value or fuel economy. I have seen the trend where allions and premios loose value now. (All cars depreciate anyway) And if you buy such a car please please maintain it properly. Dont take shortcuts. (Dont take it to other agents like the guy in another thread did ??.) It will be good and cheaper for you in the long run. Toyota 161 axio is also a good choice. but you will loose some space. again the key factor is maintenance.
Check the above thread. It has a place recommended by an AL member Ac compressor solenoid valve can be changed but there is a good chance that all internals are worn out as well. So it might be a waste of money.
I've seen lot of cases where ac compressors were replaced. But i don't know if it is repairable. (or cost effective) TL most certainly dont undertake repairs. They just replace with orginal new parts.
If you dont know the situation of the cvt oil, better do it now and start a record. I changed my cvt oil from TL. And yes they do full service including magnets and oil pan. You should instruct them specifically to do that and also they add some extra cost. Costs are higher now. I did this on September 2017
- 17 replies
- 1
- toyota allion 2006-2009
- allion nzt260
(and 2 more)
Buy car which have low fuel consumption
BlueRaiden replied to Janithapraneeth's topic in General Automotive
Am i the only one seeing a bit of marketing here? Seems like its the newest trend in AL. ??
