matroska Posted July 3 Posted July 3 (edited) Right since Irage answered correctly. I'll take it as the answer. The correct answer is Fiat 1300/1500 (the sedan is called Berlina which means sedan in Italian). The exact image i posted was a 1300 from 1963. The 1300 and 1500 are visually similar. @iRage your turn. Edited July 3 by matroska Quote
Gummybr Posted July 5 Posted July 5 On 7/3/2026 at 9:34 PM, matroska said: Right since Irage answered correctly. I'll take it as the answer. The correct answer is Fiat 1300/1500 (the sedan is called Berlina which means sedan in Italian). The exact image i posted was a 1300 from 1963. The 1300 and 1500 are visually similar. OnlineImage Galleries @iRage your turn. Does look a bit like that old 410 Datsun. Quote
matroska Posted July 6 Posted July 6 19 hours ago, Gummybr said: Does look a bit like that old 410 Datsun. as per nissan - the 410 was designed by pininfarina so probably some italian inspiration there. Quote
matroska Posted July 6 Posted July 6 1 hour ago, iRage said: Sorry for the late posting...here you go... A big cat seems to be involved here. That rear tail lamp suggests that strongly. The front has me slightly wondering so I'm not eXaKtly sure normally I would have been 120-140% sure. 2 Quote
Gummybr Posted July 7 Posted July 7 20 hours ago, matroska said: as per nissan - the 410 was designed by pininfarina so probably some italian inspiration there. Yup it was designed by pinninfarina one of many Jap cars 1 Quote
amsandun Posted July 7 Posted July 7 20 hours ago, matroska said: A big cat seems to be involved here. Only 1 big cat comes into mind related to Automobiles. So solving the riddle in "eXaKtly" gives the answer. 20 hours ago, matroska said: I would have been 120-140% sure And only several minutes later I understood what this meant Quote
matroska Posted July 7 Posted July 7 3 hours ago, amsandun said: Only 1 big cat comes into mind related to Automobiles. So solving the riddle in "eXaKtly" gives the answer. And only several minutes later I understood what this meant I think you've arrived at the same answer as me. I'm not 100% sure though the front had me slightly puzzled. Mention the car you have in mind let's see if it's the correct one when iRage responds. Quote
amsandun Posted July 7 Posted July 7 21 minutes ago, matroska said: Mention the car you have in mind I think it's a Jaguar XK120. The tail light seemed slightly different in the 140 model. Front of both seems similar to me. Quote
iRage Posted July 7 Posted July 7 Yes ! It is a XK120... Not sure who to give it to... @matroska spelled it out (literally) and @amsandun gave out the actual name... The two of you can draw straws 😕 1 Quote
matroska Posted July 7 Posted July 7 54 minutes ago, iRage said: The two of you can draw straws We did and @amsandun won. Over to you sir! Quote
amsandun Posted July 8 Posted July 8 17 hours ago, matroska said: We did and @amsandun won. Over to you sir! It should be you though.. but thank you.. Here's the next one. Saw one of these in Colombo recently, but couldn't take a photo. Could be an easy guess for you experts... Quote
john cooper Posted July 9 Posted July 9 21 hours ago, amsandun said: It should be you though.. but thank you.. Here's the next one. Saw one of these in Colombo recently, but couldn't take a photo. Could be an easy guess for you experts... Not an expert, but I can say this is a Z3 Beamer Quote
amsandun Posted July 9 Posted July 9 1 hour ago, john cooper said: I can say this is a Z3 Beamer See...no clues, straight answer.. you are an expert mate Over to you. Quote
john cooper Posted July 9 Posted July 9 27 minutes ago, amsandun said: See...no clues, straight answer.. you are an expert mate Over to you. I know someone who has a Z3 and a Z4, so I see one or the other each week. Quote
matroska Posted July 10 Posted July 10 22 hours ago, john cooper said: Here it is Well this is tricky - a clue on the country of origin might be helpful Quote
john cooper Posted July 13 Posted July 13 On 7/10/2026 at 3:01 PM, matroska said: Well this is tricky - a clue on the country of origin might be helpful Limited production model, only over 1000 were made to celebrate one of the milestones of the manufacturer I have left a special clue with the posted image, can only be converted if you have seen this car before (A few AI tools failed to guess the model with the image I have used here) 😁 Quote
iRage Posted July 14 Posted July 14 On 7/13/2026 at 12:48 PM, john cooper said: Limited production model, only over 1000 were made to celebrate one of the milestones of the manufacturer I have left a special clue with the posted image, can only be converted if you have seen this car before (A few AI tools failed to guess the model with the image I have used here) 😁 Well...I suppose at times the origin of it all is hidden in plain sight. I think once you figure out which part of the car it is, thing come TO YOu - TA-da !!! Hints help too. Do we have any in SL ? 1 Quote
john cooper Posted July 14 Posted July 14 11 hours ago, iRage said: Well...I suppose at times the origin of it all is hidden in plain sight. I think once you figure out which part of the car it is, thing come TO YOu - TA-da !!! Hints help too. Do we have any in SL ? I don't think any of them are in SL(coz the model looks ancient when you compare it with the rest of the models from that era), but who knows? Might pop up all of a sudden on one of the posts. Hint: This car uses one of the legendary engines, an inline 6 mated with a 4 speed auto box (no mention of a manual version for this specific car) This car was built on a shared platform, and the model of those platform cars I have seen few, used in some diplomatic services and famous among some SL politicians who are eager to maintain their royal crown. Quote
iRage Posted July 15 Posted July 15 (edited) 44 minutes ago, john cooper said: I don't think any of them are in SL(coz the model looks ancient when you compare it with the rest of the models from that era), but who knows? Might pop up all of a sudden on one of the posts. Hint: This car uses one of the legendary engines, an inline 6 mated with a 4 speed auto box (no mention of a manual version for this specific car) This car was built on a shared platform, and the model of those platform cars I have seen few, used in some diplomatic services and famous among some SL politicians who are eager to maintain their royal crown. Nope...it didn't come in a manual...mostly because it was a direct build on the car it shared the platform with. In fact, the design itself is supposed to reflect the first generation of the car it is based on. One of the biggest selling/charm/cool points of the car back then (now granted this is going to give it away in case the mountain load of hints hasn't given it up already) was the suicide doors. Edited July 15 by iRage 1 Quote
matroska Posted July 15 Posted July 15 23 hours ago, iRage said: Well...I suppose at times the origin of it all is hidden in plain sight. I think once you figure out which part of the car it is, thing come TO YOu - TA-da !!! @john cooper had the nerve to lift the first image off wikipedia and post it here and yet it took me this clue to figure out the car. sigh! 2 Quote
john cooper Posted July 16 Posted July 16 On 7/15/2026 at 10:45 PM, matroska said: @john cooper had the nerve to lift the first image off wikipedia and post it here and yet it took me this clue to figure out the car. sigh! Do you want to name it and claim it? Or should I award it to iRage since he picked it up 1st as in most of the cases. 🤔 Quote
matroska Posted July 20 Posted July 20 On 7/17/2026 at 3:46 AM, john cooper said: Do you want to name it and claim it? Or should I award it to iRage since he picked it up 1st as in most of the cases. 🤔 It's been a while so I'll just type the answer and get the ball rolling. But in Reality it was @iRage who got it. The car is the Toyota Origin. 1 Quote
john cooper Posted July 21 Posted July 21 Yeah, that back glass is so retro, reminds me one of the Opel car 🙂 Quote
