November 23, 201511 yr There isnt a separate gearbox. but if I'm not wrong there is some sort of transmission built inside the hybrid motorand it needs transmission oil change too right? Not really, it's supposed to be for the life time of the vehicle. The owner's manual does not indicate transmission fluid changes anywhere. There's almost no oil in it. Check out youtube for videos where they take apart the HSD. Less than half a litre of lube will spill out. The earlier HSDs used a chain, which required lube. But mine uses direct drive all the way, and the majority of the reduction is done by the motors, themselves maintenance free.
November 23, 201511 yr Not really, it's supposed to be for the life time of the vehicle. The owner's manual does not indicate transmission fluid changes anywhere. There's almost no oil in it. Check out youtube for videos where they take apart the HSD. Less than half a litre of lube will spill out. The earlier HSDs used a chain, which required lube. But mine uses direct drive all the way, and the majority of the reduction is done by the motors, themselves maintenance free. That's a great achievement compared to reliability issues of normal Toyota super CVT-i transmissions.
August 19, 201610 yr On 12/04/2016 at 0:07 AM, mat rox said: what about allion 2003 auto ? ย On 19/08/2016 at 3:55 PM, deshan.048518 said: yaris 1000cc auto and manual pls..... Did not you guys search the forum for fuel efficiency ? Following link may help you both. ย Edited June 17, 20179 yr by kusumsiri
August 20, 201610 yr Seems that fuel economy is one of the key concerns lankans have when owning a car. Whilst each person rightfully can haveย concerns on fuel economy, it also shows how pathetic it is to own a car and, once owned then worry about how many km it can run for 1ltr of fuel. I think government should seriously give priority to public transport in all possible modes (road, rail and water). In the meantime, it is good to enjoy theย car ofย your choice,ย and stop worrying aboutย km/ltr mentality. Car pooling with like-minded office colleagues is a good thing to try,ย who may come from the same direction.
August 20, 201610 yr 18 hours ago, deshan.048518 said: toyota yaris 1300cc is there but 1000cc is not there Don't know about yaris 1000 cc. But Vitz 2007 1000 cc (CVT Trans.) 8-10 km/l in colombo city traffic 14-16 km/l in outstation Final averageย 12.0 km/l . (this is perfect figure well measured)
August 20, 201610 yr Model : Toyota Belta Manufactured year : 2007 Engine Capacity : 1300 CC Fuel type : 92ย Octain Transmission Type : CVT Economy : (kmpl) city limits 11ย kmplย (10 in Heavy traffic and 12 in light traffic) Economy : (kmpl) Out stations 16 - 18 kmplย (Best achieved -> 19.2 on the Southern Highway while cruising at 80-90 kmph) Edited August 20, 201610 yr by petrolHead1
August 23, 201610 yr Do u recommend yaris 1300cc manual? is yaris same as belta? but market prices are different on yaris and beltas
August 23, 201610 yr 12 minutes ago, deshan.048518 said: Do u recommend yaris 1300cc manual? is yaris same as belta? but market prices are different on yaris and beltas Yaris is the export model and belta is the JDM. The differences have been discussed before. Do a search.ย
September 5, 201610 yr On 24/11/2011 at 0:49 PM, dinidusoft said: Hi friends, I would like to go with Toyota vehicle fuel economy survey. because it will helpful for all sri lankan or people who is gonna buy Toyota vehicle. Please take few second to serve others while searching. Please add Your Toyota vehicle Model: Toyota Passo Hanaย Manufactured year:2012 Engine Capacity :1000 Fuel type :petrol Transmission Type :CVT auto Economy : (kmpl) city limits 10-14 (kmpl) Out stations 15-18 ย
June 17, 20179 yr Posted by a Guest user Quote Model:ย Platz Manufactured year:ย 2000 Engine Capacity : 1000cc VVTi Fuel type : Petrol 95 Transmission Type :ย Manual Economyย : 12-14ย (kmpl) city limits 15-18(kmpl) Out station 7 ย
May 7, 20215 yr 35 minutes ago, Sameera Withanachchi said: What is the average fuel consumption of Toyota Vitz 2017 Model in Sri Lanka Welcome to the forum @Sameera Withanachchi.ย Did you search the forum for fuel efficiency ? Following links may help you. @Adminย @Davyย @MADZย Is it better to merge this thread with the one above ?
May 7, 20215 yr 8 minutes ago, kusumsiri said: Welcome to the forum @Sameera Withanachchi.ย Did you search the forum for fuel efficiency ? Following links may help you. @Adminย @Davyย @MADZย Is it better to merge this thread with the one above ? OK Thanks a lot, I will check
May 13, 20215 yr Model:ย Vitz Manufactured year: 2017 Engine Capacity : 1000cc Fuel type : Petrol (92) Transmission Type : Automatic(CVT) Economyย : City - 12-14 km/l, Outstation 16-18 km/l, Highway 18 - 23 km/l ย Edited May 13, 20215 yr by nightFury
