Already posted this in the other thread opened by the OP under the same topic
http://jpnauction.com/month (I actually found this link on AL forums a long long long time ago...)
Gives basic production info...at dealerships Japan their system gives you info on production trim levels etc (thus will only show accessories/options that came out of the manufacturer) to link up to the EPC. However, it doesn't tell you any dealer package trims that might have been stuck on the car.
Edited by iRage
Better not to check this, it gone be lot of disappointment about your car, Sri Lanka its very hard to find a correct G Grade SE Limited Gold badge car, but on the road alll the cars are G grade SE limited, I had a LX LTD with ABS and 2 Air bags, back in 2008 i got the G LTD "Kit" for 120,000/= (4 Doors with doo cards, Seats, carpet, dashboard and all the bits and i got the value of 2 to 250 extra when i sell the car
To be perfectly honest, if the correct "conversion kit" was used, there is absolutely no difference between a factory original and a conversion when it comes to trim level. Because the underlying chassis engine, running gear are all the same. The only possibly exceptions I can think of are ABS and tyre pressure sensors.
Tyre pressure sensor???? never seen on a 110 mate, please explain
Not direct TPS but indirect (based of wheel rotational speed) one as shown in Sampath's post above.
Cool ah, looks like this options they added on facelift model + GT version (as per sampath's image)
Mate Sampath where did you find those old note's mate, you awesome any MM and MINI Cooper catalogs?
Thanks mate.
Particular catalog was Toyota Corolla EE111 issued in April 1998.
http://web-cache.stream.ne.jp/www09/toyota-catalog/pdf/corolla-3/corolla-3_199804.pdf
You may visit below threads.
http://forum.autolanka.com/topic/13377-how-to-download-toyota-jdm-catalogues-around-1997-up-to-date/
http://forum.autolanka.com/topic/13961-car-catalogues-brochures-warning-graphics-heavy/
Sorry, I don't have Mini and MM catalogs .
But you will enjoy this on MM.
http://potteries.mmoc.org.uk/Identify.htm
Edited by Sampath Gunasekera
No, this option is available on Corolla G-Touring also. I have seen on one of my friend's car.
Thank you for the link about MM details and it's gone to "Favorites" on my IE
BZ Touring Wagons are expensive in here also, and Carib (Sprinter) also got the BZ Touring model which is expensive too, no wonder as its got all the bits and pices with Black top engine :)
