May 17, 201412 yr Author Please PM me the price they quated per sqare foot, or the average amount it will cost for a montero 2013 if possible. And if you do the soundproofing please keep us updated. On phone they quoted 1000per sheet but when I visited them price was 2000 I'm still researching as I now found that roof sealing sheets similar to peel and seal (Google it) works a charm at fraction of the cost.
May 18, 201412 yr Author For all those interested I'm testing out those peel and seal stuff. Will report findings in a few days. Put a few strips in the boot. But I want to see if any unusual smells are given out and how effective
May 18, 201412 yr For all those interested I'm testing out those peel and seal stuff. Will report findings in a few days. Put a few strips in the boot. But I want to see if any unusual smells are given out and how effective Before you dive in, look into how reversible it is. As in, how you can effectively take it out completely. That tar like stuff bonds pretty hard and might give you a bigger headache than the one you have now. Due to the harsher heat we have in SL, it might react differently thatn what you may have seen on Youtube, so having a solid exit plan in place is cruicial IMO.
May 18, 201412 yr Author <blockquote class='ipsBlockquote'data-author="Hoonigan" data-cid="261593" data-time="1400396017"><p> <br /> Before you dive in, look into how reversible it is. As in, how you can effectively take it out completely. That tar like stuff bonds pretty hard and might give you a bigger headache than the one you have now. Due to the harsher heat we have in SL, it might react differently thatn what you may have seen on Youtube, so having a solid exit plan in place is cruicial IMO.</p></blockquote> Yes correct. Thats why I pasted only a few small strips. But generally speaking one wouldn't need to take it out if things are going okay. Anyway will report findings in a few days
May 19, 201412 yr The one you get here(for permit) is 2800CC? Nope the 3200cc but the engine is different from the europian and JDM versions due to the low quality fuel we have here.
May 19, 201412 yr On phone they quoted 1000per sheet but when I visited them price was 2000 I'm still researching as I now found that roof sealing sheets similar to peel and seal (Google it) works a charm at fraction of the cost. Thanks, How many sqare feet did they tell would cover you'r car, A rought idea on how much it would be for the montero? And did they say that we could remove it easyly withoud damging the interior or paint.
May 21, 201412 yr Nope the 3200cc but the engine is different from the europian and JDM versions due to the low quality fuel we have here. Is 4M41 right? probably detuned
May 21, 201412 yr Author Thanks,How many sqare feet did they tell would cover you'r car, A rought idea on how much it would be for the montero? And did they say that we could remove it easyly withoud damging the interior or paint. Well roughly per door you may need 3-4 sheets depending on if you want to put it on the inside panel an out. so you can roughly do the math. Didn't ask about removal, generally you wouldn't want to remove once you put it on would you?
May 21, 201412 yr Author I found this for home insulation. http://www.anton.lk/Heat_and_Sound_Insulation/Insulation_and_Packaging/Polar_Insulation Anyone can comment if it'll be any good on cars? will check out their showroom this weekend
May 21, 201412 yr I found this for home insulation. http://www.anton.lk/Heat_and_Sound_Insulation/Insulation_and_Packaging/Polar_InsulationAnyone can comment if it'll be any good on cars? will check out their showroom this weekend This is specifically for heat reduction, so I doubt it will be good at soundproofing.
May 21, 201412 yr Author This is specifically for heat reduction, so I doubt it will be good at soundproofing. As per the site it says it can be used for both. anyway one way to find out i guess if no one has used it before
May 21, 201412 yr I used something similar in my Mini. It's really good at keeping the heat away but never noticed any decrease in sound.
May 21, 201412 yr As per the site it says it can be used for both. anyway one way to find out i guess if no one has used it before This is used for heat reduction and not for sound proofing. There are several types of these which used primarily for reducing the heat such as for ceiling, engine compartment (Mostly on older vehicles)...
May 21, 201412 yr Is 4M41 right? probably detuned yep 4M41, @istowner I don't like it if it sticks like tar to the paint, even tough it may be useful and expensive when it got to go it should go, if not you can't use it in a 10million worth vehicle
September 17, 201412 yr Any new updates? I feel i need to get it done soon comments from any one who has done it
September 17, 201412 yr It's a Toyota IST Toyota IST is generally a noisy car. Get your vehicle checked up by a good mechanic and run it as it is. If those sound proofing methods are good they should be coming as a factory fitted option...
September 17, 201412 yr Toyota IST is generally a noisy car. Get your vehicle checked up by a good mechanic and run it as it is. If those sound proofing methods are good they should be coming as a factory fitted option... In the monty's case they really do come but in trims such as the super exceed which is almost twise as expensive as a normal one which is outrageous. The sound proofing in the GLX is much lower so i decided to get it to a little bit more quiet by using these any experience?
September 17, 201412 yr Any new updates?I feel i need to get it done soon comments from any one who has done it May not be relevant, but recently I opted for a 3M style dust strap carpet (faux) saw a massive reduction in road noise, you maybe missing a layer
September 17, 201412 yr Author Any new updates?I feel i need to get it done soon comments from any one who has done it I started on it but never got to finish the project. If you use the right product there's an improvement but it's a hard job in a sense as it takes a very long time to do it properly. You can outsource it but can be expensive. IST is not a noisy car but if your shocks are bad then yes it can be and tyre condition. You can't do too much on these cars though since hatchbacks are inherently more noisier than a sedan. Having said that you can certainly do reduce it a lot by proper sound damping material however as mentioned before, it will be a hectic job. So depends on how badly you want it . Edited September 17, 201412 yr by istowner
September 17, 201412 yr I started on it but never got to finish the project. If you use the right product there's an improvement but it's a hard job in a sense as it takes a very long time to do it properly. You can outsource it but can be expensive.IST is not a noisy car but if your shocks are bad then yes it can be and tyre condition. You can't do too much on these cars though since hatchbacks are inherently more noisier than a sedan. Having said that you can certainly do reduce it a lot by proper sound damping material however as mentioned before, it will be a hectic job. So depends on how badly you want it . I recently asked from p*tc* L*nk* and they told me it would be around Rs.10 000 for the vehicle, seems good if it really works, that's why i asked if there is some one here who tried it
September 17, 201412 yr Author I recently asked from p*tc* L*nk* and they told me it would be around Rs.10 000 for the vehicle, seems good if it really works, that's why i asked if there is some one here who tried it That's probably just for the doors. You need about 2 sheets per door and a sheet is about 1000 each so price is about right. However i wanted to do the rear boot floor and sides as well which is where the most noise in a hatch comes from. That's the hardest part imo and will cost a lot more.
November 5, 201412 yr Recently found some sound proofing paints and sprays in the internet, wonder how it works, anybody used it, is it available in sri lanka
