Best Headlight bulbs for Kia Picanto 2005?
I have a Kia Pincanto 2005 car, planning to change my headlight bulbs due to low performance.
Please suggest the best bulb to get the maximum performance?
Irosh
15 answers to this question
HID or filament bulbs?
If its HID, pls search the forum. Its been discussed a zillion times.
If its filament bulbs, look for GE, Hella, philips or a similar brand. Its normal for a car's headlight to lose brightness over the years as the electrics get worn and lenses get discoloured. You may not see the original performance even if you change bulbs.
Sorry bro, I'm not good in car stuff. Don't know whether its HID or filament. I have heard about Osram LED bulbs. Any idea?
I will post a pic of my headlight later today.
Checked, its H4 55W Halogen bulb (made in Germany). I went to Auto Pal and Pet#o, they said, can't install H4 LED bulbs due to less space. But they said can modify the headlight cup accordingly.
Then I found a guy n ######.lk (in Negambo) selling OSRAM H4 Night Breaker Unlimited bulbs. The cost is Rs. 5500 with 3 months warranty.
Pls advise me on this as I have never replaced headlight bulbs before. Are there any cheap bulbs in the market with same performance?
And, are there any shops near Colombo selling OSRAM H4 bulbs?
Cops have started to have a ball with LEDs now
If you want a cheap simple new bulb, you can buy Koito bulbs locally, oem for Japs
or If you want brighter All the Osram bulbs can be bought online on all the popular stores.
Lighting performance = more cost
Do search the forum, we have a lot of topics on Osram bulbs with photos.
Do you mean less space behind the headlight or the bulb doesn't fit into the holder?
Either way do not modify your headlamp for some bulb.
Like Tiv mentioned the price varies according to the performance and quality
Hi Guys,
Well, first I said seems good, but seems not very good. There is a slight different but not as expected.
Guys please suggest me a good H4 Head Light bulb. The height of the bulb should be similar to H4 Halogen. And there is a very limited space in the housing (back) so difficult to fix a bulb with Heat sink.
Help....
I fitted my Starlet with Osram Nightbreaker Laser bulbs recently, and they work well for me. My Axio Hybrid has Nightbreaker Ultras (one generation earlier) in all 4 lights and they've been fine thus far, especially the high beam, which in concert with the lows will force even the most determined high beam user to revert to dipped beams. I'd suggest staying away from HID and LED retrofits as they're not regulated and more often than not just blind oncoming cars.
Just curious,
Whats the low and high beam type on Axio Hybrid?
And did you mean Unlimited or is there a Nightbreaker Ultra as well?
Edited by Magnum
26 minutes ago, Magnum said:
Just curious,
Yes Nightbreaker Unlimited's sorry. Mine are HB3/9006 for high beam, H11 for low.
2 hours ago, Magnum said:
I have Osram Nightbreaker Unlimited as well for high beam and fog lamp. I'm happy with its performance
Magnum, From where did you buy Osram Nightbreaker Unlimited bulbs?
Edited by Anuz91
You can get genuine stuff from https://www.powerbulbs.com if ur not sure about eBay sellers. They got free shipping from UK to SL with 25% off these days. I got "Philips X-treme Vision +130" since I like the yellowish 3600k colour. Huge difference from stock bulbs. There's also the new "OSRAM Night Breaker Laser" if you like 4000k white like the pic from @Magnum.
Edited by c1nder
That's a legit site. I only came across it after I bought both pair. They also give warranty if I'm not wrong
I like the standard yellow as well. But the problem is Osram doesn't make any performance bulb with that kelvin, also the Xtremevision available for HB3/HB4 are the old 100% bulbs.
Even Nightbreaker Laser hasn't yet come out as HB3/HB4.
Btw there is a Russian guy on YouTube who does bulb comparisons using a light meter. You can check out his videos before purchasing
