Engine oil for Toyota AE110 | Please share your idea
virajh
  On 8/15/2019 at 9:21 PM, Twin Turbo said:
Hi, for a car more than 2 decades old, yes , use a 40 weight oil and keep the oil level in check and topped up,..
And change your air filter.
Expand
Hello,
Currently use 10W-40 Mobil supper semi synthetic oil. but now recently noted oil level deceasing issue.
Thanks for sharing your advice with here
  On 8/15/2019 at 12:04 PM, virajh said:
Thank you so much for your quick words,
Actually my car made in 1998 and currently use Mobil 2000 10W,40W semi synthetic oil  , car did around  190K.
Budget is ok for me , highly appreciated if you could suggest a good en
Expand
I replied to you on the other thread.....That seems fine for a vehicle with that much high mileage....why do you not like the oil you are using ?
Finally...please do not go around asking the same question on multiple threads....
Discussion from other thread :(I will be deleting the posts on the other thread):
  On 8/15/2019 at 11:24 AM, virajh said:
Dear iRage,
Could you please share the experience of your 110 car engine oil. it will more helpful for me.
Expand
I have never owned a 110 on a long term basis. But then again, type of engine oil is very subjective as what works for my engine might not be the best thing for your engine. A "not so worn out" engine would do quite well with a thinner oil and if a heavier oil is needed it would purely for heat absorption in a high temp environment like Colombo. On the other hand, if the engine is somewhat worn out, one might be tempted to use a thicker oil anyway in the interest of maintaining oil pressure and such.
As for whether you should use synthetic or mineral oils...again...that is also subjective as it depends on your vehicle usage and conditions and budget.
  On 8/15/2019 at 2:42 PM, Devinda_Z said:
What is the mileage like on your AE110?
What oil are you currently using?
Expand
Currently using
Expand
one of my friend told me recommended viscosity is 10W-30. actually i have no idea of current engine oils brands. that why i'm searching this on AL to get an idea for me. also i think this will helpful for others too.
I'm New to AL and thank for your support...
  On 8/16/2019 at 6:36 AM, virajh said:
Currently using
Expand
If the engine is relatively unworn...then yes a lighter oil would work....but then if the engine is worn with age..a heavier oil would be better....
As for brands...
Mobil, Castrol, LiquiMoly, (do we still have the proper Penzoil ?)...etc...
  On 8/16/2019 at 3:23 AM, virajh said:
Hello,
Expand
The brand, type and viscosity of the oil you currently use sounds fine but i'd be more concerned about the oil level decreasing....
Any noticeable leaks? Any residue under the car when parked overnight?
How much oil do you top up and how often (in terms of km's run between top ups?)
Expand
still no leak founded,  oil level is between High and low ( half level), top ups in nearly 3 months ago.
Thanks for your support.
