On 6/29/2020 at 4:34 PM, gayanath said:
I haven't your service schedule but Toyota normally recommending 100,000 - 120,000 km ( or 5 - 6 years) intervals for fuel filter replacement. So no point of doing it that much early.
@gayanath Are you sure that Toyota recommends to change the fuel filter at 100, 000 km?
Usually its a lot less. In my Honda the owners manual suggest to replace the fuel filter every 40,000 kms. Usually it is recommended to change between 30 000 - 40 000 miles or every 2 years unless specified in the manual.
Considering the quality of the fuel in here I think the OP should contact Toyota and ask about the interval by specifying the car model.
Below two examples are Asia Pacific schedules (not JDM)
Toyota Yaris (Non-hybrid) - 80,000 km / 4 years
Prius C (Hybrid) - 120,000 km / 6 years
Note: No additional maintenance recommended for Severe conditions (with related to Fuel filter) in both cases
Thanks @gayanath It is certainly an improvement. 100K interval for changing the fuel filter. Then again it make sense since they have two filters and the labor cost of changing the one inside the gas tank would be pretty high.
  • 7 months later...
I visited Laugfs for car service last week, they informed me now they are having 5W 30 full synthetic engine oil where can be run 10K kms, the 4L price also below Rs 5K, considering cost factor + long mileage I shifted to Laugfs oil from Toyota simi Synthetic oil,
can you give me your opinion with this fully synthetic oil and advise did I do wrong thing?
my car details as follows,
Brand : Toyota
Model : Passo
Mileage : 46K Kms
Rgds
  • MADZ changed the title to Use long milage engine oil
2 hours ago, thusharak340 said:
Brand : Toyota
Model : Passo
Mileage : 46K Kms
Rgds
Haven't used the Laugfs brand myself, but generally full synthetic oil is vastly superior to regular mineral oil so: I believe you did the right thing.
Edited by Kavvz
Brand : Toyota
Model : Passo
Mileage : 46K Kms
YOM?
Which is the recommended grade? 5W30 or 0W20?
Anyway, no problem if its cost effective.
On 2/6/2021 at 6:44 AM, iRage said:
As long as the oil is not crap then it is fine.
How is the condition of your engine ?
the mileage is just 46K Kms, it is smooth running engine , noted that synthetic oil is better than semi synthetic
Well..don't jump to conclusions like that...an oil does not become "better" just because it is synthetic.
The advantage of synthetics is that its composition holds up much better and longer, especially under heavy use. This with other additives enables it to be much more efficient with heat dissepation and keeping the engine lubricated in a consistant manner.
A good mineral oil can also do that with the right additives. I seriously doubt you would have instantly noticed any advantage of using synhetic over such a short period of time as opposed to using a good mineral oil, especially if the car has not had any hard use.
1 hour ago, thusharak340 said:
The recommended grade is 5W30
This is the Instruction Manual of Passo (Feb 2010 onward) which recommends) 0W20 as best fuel efficiency and 5W30 also could be used.
