September 16, 20215 yr On 9/15/2021 at 10:08 AM, PreseaLover said: Yes both are the same. No they are not ! I just found the part in the parts catalog. The front one is just a badge (the badge when new apparently cost like 3500yen). The rear one goes as a door lock assembly (this on the other hand when new costs like 12,000yen).
September 16, 20215 yr 11 minutes ago, iRage said: No they are not ! I just found the part in the parts catalog. The front one is just a badge (the badge when new apparently cost like 3500yen). The rear one goes as a door lock assembly (this on the other hand when new costs like 12,000yen). Jesus F. Christ
September 16, 20215 yr @iRageI can even replace it with this badge right? do you think i can find this from somewhere?
September 16, 20215 yr 27 minutes ago, PreseaLover said: @iRageI can even replace it with this badge right? do you think i can find this from somewhere? This is the same badge that came on the U14 right? Older Bluebirds like the 910 had a rather cool logo with a blue 'bluebird' on a yellow background.
September 16, 20215 yr 8 minutes ago, matroska said: This is the same badge that came on the U14 right? Older Bluebirds like the 910 had a rather cool logo with a blue 'bluebird' on a yellow background. yes
September 16, 20215 yr 2 hours ago, PreseaLover said: @iRageI can even replace it with this badge right? do you think i can find this from somewhere? Anyway I almost forgot I can get this badge made in original condition for just 500 bucks, il proceed with that option
September 17, 20215 yr At cold start when I start the first time it misfires for 2 times and when I accelerate and start again the engines raises and starts and the RPM goes upto 1500 and stays there and doesnt idle. When I switch on AC it still stays at the same position. After sometimes after driving the RPM stick goes to 1000 and act normal. What might be the issue here?
September 20, 20215 yr After having owned 3 different petrol car models now by Nissan (Presea, Cefiro A33, Bluebird U13), I should say there is no difference between the comfort level and pickup between the Cefiro and Bluebird u13. the U13 has the same comfort level and speed. The driving pleasure is more in the U13 though. So according to my perception I would rate the Bluebird U13 as the best, Cefiro comes second and Presea comes third. (This is in terms of comfort and speed and driving pleasure). In terms of fuel economy once again the bluebird U13 petrol does better on fuel, presea is next and cefiro comes third. Edited September 20, 20215 yr by PreseaLover
October 4, 20215 yr Ok Gentlemen. Here's my restored Bluebird ARX Only thing left is now to find a star shaped alloy and il be done.
November 13, 20215 yr Guys I really really need help here please. When I reach the speed of around 70kmh and when the car is in 4th gear, and when I release the leg from the accelerator (withoiut keeping my leg on the brakes) the car vibrates/knocks heavily. And at the same time the RPM meter also fluctuates.. When the speed reduces then the car goes as usual without the vibration and RPM meter becomes normal too. This happens only after driving at the 4th gear for few seconds. Mechanics wouldnt know what to do either because this happens occasionally and they cant get it to happen when test driving. Also the car stops sometimes at low gears during traffic. I have done the following repairs so I dont' know what else to do. 1. Cleaned throttle body 2. Replaced all 4 plugs 3. Cleaned idle valve/AAC valve 4. Replaced all 3 mounts (engine, axle, gearbox) 5. Front Tyres are also new 6. Cleaned intake manifold and Air filter 7. Replaced fuel filter and fuel pump 8. Adjusted distributor Can someone tell me what might be wrong?
November 13, 20215 yr 2 hours ago, PreseaLover said: Guys I really really need help here please. When I reach the speed of around 70kmh and when the car is in 4th gear, and when I release the leg from the accelerator (withoiut keeping my leg on the brakes) the car vibrates/knocks heavily. And at the same time the RPM meter also fluctuates.. When the speed reduces then the car goes as usual without the vibration and RPM meter becomes normal too. This happens only after driving at the 4th gear for few seconds. Mechanics wouldnt know what to do either because this happens occasionally and they cant get it to happen when test driving. Also the car stops sometimes at low gears during traffic. I have done the following repairs so I dont' know what else to do. 1. Cleaned throttle body 2. Replaced all 4 plugs 3. Cleaned idle valve/AAC valve 4. Replaced all 3 mounts (engine, axle, gearbox) 5. Front Tyres are also new 6. Cleaned intake manifold and Air filter 7. Replaced fuel filter and fuel pump 8. Adjusted distributor Can someone tell me what might be wrong? I would definitely check the operation of the Throttle position sensor (Although it's not listed here).
November 13, 20215 yr 2 hours ago, Ruslan said: I would definitely check the operation of the Throttle position sensor (Although it's not listed here). Oh I see. I did all these things at Nissan Ravi btw
November 15, 20215 yr Check you electrical systems (connectors, relays and current) and ECU as well. Maybe rodents have gone inside.
November 15, 20215 yr 42 minutes ago, Gummybr said: Check you electrical systems (connectors, relays and current) and ECU as well. Maybe rodents have gone inside. ECU was also cleaned. connectors also checked
November 18, 20215 yr I replaced all 4 plugs 1 month ago and yesterday 1 plug blew off and had to replace. How does plugs get worn off like that? Didnt even drive 1000kms
November 28, 20215 yr So this is what the car looks like after I fitted the original fog lights from NZ and after I changed the ugly alloy wheels to this 90’s ones. Ah I also changed the rear nissan badge to a black one to better fit the silver colour.
November 29, 20215 yr Car does look so so nice Hope you get the engine ones sorted out soon too. For the absolute pain in #@##$ you are with your indecisive, willy-wolly-ness with cars..I must admit you do do a pretty good job at restoring them. Edited November 29, 20215 yr by iRage
November 29, 20215 yr 1 hour ago, iRage said: Car does look so so nice Hope you get the engine ones sorted out soon too. For the absolute pain in #@##$ you are with your indecisive, willy-wolly-ness with cars..I must admit you do do a pretty good job at restoring them. thanks man
June 10, 20233 yr Guys, I just bought my SU14. But I can't figure out if this is eprice or Le Grand. Also, after reading about your friend's U13 with sunroof, I'm wondering that, can I fit one too? (Cut the hood & etc... 🤔😉)
June 22, 20233 yr On 6/10/2023 at 9:02 PM, wildwise said: Guys, I just bought my SU14. But I can't figure out if this is eprice or Le Grand. Also, after reading about your friend's U13 with sunroof, I'm wondering that, can I fit one too? (Cut the hood & etc... 🤔😉) Changed the idea about sunroof... 😎
