FreakSL Posted January 5, 2012 Share Posted January 5, 2012 Hey guys recently i foud to engage it to first gear while driving in low speed, but after i really slow dwn or stop its not hard at all, anyone has the same problem ? any solution ? Quote Link to comment Share on other sites More sharing options...
0 Pericles Posted January 5, 2012 Share Posted January 5, 2012 Thats not a problem, its the way its made. The solution is as you have mentioned, is to stop the car before shifting to first. Quote Link to comment Share on other sites More sharing options...
0 maheshw Posted January 5, 2012 Share Posted January 5, 2012 Correct. you need to reach atleast 5kmph - 10kmph if you need to shift to 1st gear while moving. otherwice you will feel very hard to shift. 1 Quote Link to comment Share on other sites More sharing options...
0 Sylvi Posted January 6, 2012 Share Posted January 6, 2012 On 1/5/2012 at 5:12 AM, FreakSL said: Hey guys recently i foud to engage it to first gear while driving in low speed, but after i really slow dwn or stop its not hard at all, anyone has the same problem ? any solution ? 'FreakSL', What is your car, normally for what reason you want to use 1st gear on a moving vehicle. if you have full synchronized gear box. 1st Gear you can shift at 20 kilometers.If you release the clutch at that speed your engine will speed up and car will act as you step on your brakes. Shifting down gears can be used if brakes fail. Now days drivers do not use gears to slow down the speed of the vehicle they depend on brakes. Drivers use low gears to come down on hills instead of using brakes. Some vehicles have exhaust brake. Sylvi Wijesinghe. Quote Link to comment Share on other sites More sharing options...
0 FreakSL Posted January 19, 2012 Author Share Posted January 19, 2012 On 1/5/2012 at 9:55 AM, maheshw said: Correct. you need to reach atleast 5kmph - 10kmph if you need to shift to 1st gear while moving. otherwice you will feel very hard to shift. but the problem is once i slow down and can't put it to first and it's hard to pick up on 2nd car feels less power Quote Link to comment Share on other sites More sharing options...
0 Gyiman Posted January 19, 2012 Share Posted January 19, 2012 On 1/19/2012 at 8:17 AM, FreakSL said: but the problem is once i slow down and can't put it to first and it's hard to pick up on 2nd car feels less power How slow is slow? Quote Link to comment Share on other sites More sharing options...
0 FreakSL Posted January 20, 2012 Author Share Posted January 20, 2012 around 5-10kmph , its hard to pick up on 2nd and start jerking sometime , also the clutch bites very high, think i need an adjustment to the clucth ? Quote Link to comment Share on other sites More sharing options...
0 Gyiman Posted January 20, 2012 Share Posted January 20, 2012 Ok, that's not exactly 'slow' for most vehicles to be put into first. So as Peri mentioned, its built that way. Get your car tuned first & have a mechanic check the clutch as well. Your probably burning more fuel driving the way it is. 1 Quote Link to comment Share on other sites More sharing options...
0 maheshw Posted January 20, 2012 Share Posted January 20, 2012 Posted Today, 03:47 PM around 5-10kmph , its hard to pick up on 2nd and start jerking sometime , also the clutch bites very high, think i need an adjustment to the clucth ? Sounds like youre having an issue in your clutch for me. better to meet your mechanic. Quote Link to comment Share on other sites More sharing options...
0 derek_wick Posted December 22, 2013 Share Posted December 22, 2013 Heloo !! I recently baught a FB15 manual, and i feel that its hard to shift firts to second and from third to second, when engine warms up(once it runs few kilometrs). Im not used to driving manuals and this is my first vehicle. so im new to vehicles. Is it some thing to do with clutch adjustment Or ? thnx in advance ! Quote Link to comment Share on other sites More sharing options...
0 Komisiripala Posted December 22, 2013 Share Posted December 22, 2013 When was your ATF changed? Quote Link to comment Share on other sites More sharing options...
0 Davy Posted December 22, 2013 Share Posted December 22, 2013 On 12/22/2013 at 8:57 AM, derek_wick said: Heloo !!I recently baught a FB15 manual, and i feel that its hard to shift firts to second and from third to second, when engine warms up(once it runs few kilometrs). Im not used to driving manuals and this is my first vehicle. so im new to vehicles. Is it some thing to do with clutch adjustment Or ? thnx in advance ! Welcome to the forum! Is this a recent development? First check if your transmission oil (gear oil) is okay and is topped up properly. If the oil level has gone down, check if your gear box oil seals are okay. If you haven't done a transmission oil change since you bought the car, I can suggest that you do that first and see if the problem still persists. Quote Link to comment Share on other sites More sharing options...
0 Reckless Posted December 22, 2013 Share Posted December 22, 2013 Also make sure that you press the clutch all the way before changing any gear. Quote Link to comment Share on other sites More sharing options...
0 MV-5 Posted December 22, 2013 Share Posted December 22, 2013 On 12/22/2013 at 2:19 PM, Reckless said: Also make sure that you press the clutch all the way before changing any gear. if there is clutch disengaging problem, then at the very last moment of gear shifting , it will produce a "crrrrrrk" sound. Quote Link to comment Share on other sites More sharing options...
0 derek_wick Posted December 25, 2013 Share Posted December 25, 2013 Merry Christmass & thank you very much !!,, I didnt change gear oil since i baught the car,, i will first change oil and see .. appreciate for the help everyone.. Sorry i took some to reply since i was outstationed .. Quote Link to comment Share on other sites More sharing options...
0 Crosswind Posted December 25, 2013 Share Posted December 25, 2013 Looks like a synchronizer cone is worn out. Quote Link to comment Share on other sites More sharing options...
0 derek_wick Posted December 28, 2013 Share Posted December 28, 2013 friends i did change the transmission oil, but still the problem persists. Its not like totally unchangeable but still,, u feel the difference. I noticed that changing from 3 to 2 at speeds around 20km/h is totally effort less.. thank you Quote Link to comment Share on other sites More sharing options...
0 derek_wick Posted December 30, 2013 Share Posted December 30, 2013 After MV-5 explained i realized,, On 12/22/2013 at 3:28 PM, MV-5 said: if there is clutch disengaging problem, then at the very last moment of gear shifting , it will produce a "crrrrrrk" sound. Every now and then when i do put into reverse gear it makes "crrk" sound and wont engage the gear properly (gear shifter stops halfway). It engages soon after i put into first and then back again to reverse. Is it the synchronize cone issue Or clutch disengagement issue?? If both is it possible for me to replace parts separately? I will need not to replace the whole gear box right? Quote Link to comment Share on other sites More sharing options...
0 MV-5 Posted December 30, 2013 Share Posted December 30, 2013 On 12/30/2013 at 7:21 AM, derek_wick said: After MV-5 explained i realized,,Every now and then when i do put into reverse gear it makes "crrk" sound and wont engage the gear properly (gear shifter stops halfway). It engages soon after i put into first and then back again to reverse. Is it the synchronize cone issue Or clutch disengagement issue?? If both is it possible for me to replace parts separately? I will need not to replace the whole gear box right? if i understood correctly , when you wanted to shift to reverse gear, it will not engage in first attempt. then instead of following your workaround (shift to first and back again to reverse) try to do the following steps. assume that now you have shifted it to reverse but gear has not engaged properly. then start to release the clutch very slowly(this might move your car if gear is engaged, be careful). if gear is not engaged properly it will make a "crrrk" noise, push the clutch fully as quick as possible. and try to shift the gear (to reverse, directly you should try to move the stick to R position, without moving upward ). if gear engaged, then there is a higher probability that problem is there in the "Clutch" or clutch related mechanism like slave , master pumps etc.. 1 Quote Link to comment Share on other sites More sharing options...
0 CJ5 Posted January 9, 2014 Share Posted January 9, 2014 On 1/20/2012 at 4:30 PM, maheshw said: its hard to pick up on 2nd and start jerking I know of an incident in a AE91 Corolla hatchback , where some incompetent makabaas had taken apart the gear box for some repair and had assembled it back. Then the owner ( a friend of mine) had found that it shudders in second gear and struggles to pick up. The problem had been that when assembling the gear box back together the makabaas had made some mistake and when the gear lever seemingly moves into second in fact inside the box the gear wheels were moving into fourth gear and that explained the shuddering and struggle to pickup!! Quote Link to comment Share on other sites More sharing options...
0 MkX Posted January 10, 2014 Share Posted January 10, 2014 I've never .. ever has put in to 1st gear when the vehicle is on move even around 5kmph. may be i've put in to 1st gear around 0.5-1 Kmph in traffic jams. I always had the feeling I shouldn't even try to put in to 1st gear when vehicle is moving Quote Link to comment Share on other sites More sharing options...
0 Grid Posted January 13, 2014 Share Posted January 13, 2014 it might be cuz of shoet gear box ratio... i used downshifting to slow down near corners it is easier to get acceleration out of the corner, im a bit of a speed maniac.. LOL still underage to get my DL though.. :/ Quote Link to comment Share on other sites More sharing options...
FreakSL
Hey guys
21 answers to this question
