Komisiripala Posted February 25, 2013 Author Posted February 25, 2013 Great minds mate. Need I complete that sentence??
Komisiripala Posted February 28, 2013 Author Posted February 28, 2013 so after a long pause, work begins again. the engine's out for the rebuild. so glad to see SOMETHING happening at indikas! and the best yet i've got P72 pistons in there as is. which is a wonderful find. P72's have a slight hemispherical curvature on its surface, to allow for a compresison ratio of 10,8:1. another little JDM gem that japan decided to keep for themselves! looks like i can look away from the datto for a little while now!
The Don Posted February 28, 2013 Posted February 28, 2013 So what is the rebuild you have planned. A partial rebuild with rings and port and polish or a full rebuild? I understand your frustration with garages. These guys sadly can't spend their entire time with one customer project as they need to keep their other customers happy as well, but this causes unnecessary delays in big projects.
Komisiripala Posted February 28, 2013 Author Posted February 28, 2013 Near complete. Keeping the pistons, rods and crankshaft. Everything else is getting replaced. Cams and valve springs by Brian crower. Bearings by ACL
Komisiripala Posted March 1, 2013 Author Posted March 1, 2013 Machan, because compression already highest in the b18 range with p72 pistons. Raise up to 11:1 and I might not be able to run 95 octane, or worse yet might get valve knock. 1
shanX Posted March 1, 2013 Posted March 1, 2013 Hmm seems like they are almost same as P73s, so yeah seems fine for your setup. But you can run 95 wit 11-11.5 range i think. As i have heard 12.+ is the range you should worry about
Komisiripala Posted March 1, 2013 Author Posted March 1, 2013 Since cams are high lift I worry about valve knock as well. In a whole new level of hot shizz if that happens. No no shanx enough parts now! I don't want to know how much I've spent already! Need to collect up for a hondata to cap it all off and I'm done!!
shanX Posted March 1, 2013 Posted March 1, 2013 (edited) Ohh you meant valve piston contact, lol again that could be checked too afaik. Haha anyway yeah can understand that you have spent a lot already. What about port n polish? Edited March 1, 2013 by shanX
JadeyBlitzen Posted March 1, 2013 Posted March 1, 2013 Since cams are high lift I worry about valve knock as well. In a whole new level of hot shizz if that happens.No no shanx enough parts now! I don't want to know how much I've spent already! Need to collect up for a hondata to cap it all off and I'm done!! How aggressive are the cams compared to stock? are you gonna run them on stock ecu or going for an aftermarket? I seem to have developed a massive interest in high lift cams lately. So care to shed some light on this komi?
Komisiripala Posted March 1, 2013 Author Posted March 1, 2013 How aggressive are the cams compared to stock? are you gonna run them on stock ecu or going for an aftermarket? I seem to have developed a massive interest in high lift cams lately. So care to shed some light on this komi? machan check page one of this thread. i've discussed the BC stage 2's vs stock GSR automatic cams in detail. they're supposed to be the next best thing to a turbo, or rather as radical as you can take an NA engine. suffice to say Zackie did a double take when i told him about the cams! i'm running them on stock ECU for the moment. planning on going for a Hondata s300 EMS. its my last great white elephant of an expense, and i'm putting it off for some time. 1
JadeyBlitzen Posted March 2, 2013 Posted March 2, 2013 That's mighty aggressive. your engine will sound like a race engine when you are done. but running on stock ecu idling might get pretty lumpy. Also may I suggest throwing in a knife edged crank while the engines apart considering the high rev limit?
Komisiripala Posted March 2, 2013 Author Posted March 2, 2013 yeah idling will be an issue til i get the ECU sorted out. i've read a bit about this. its what BC coyly describes as "a gentle lope at idle" gentle lope my left nut. balamu ithin. its all a precarious standoff between how long i can wait to afford the ECU and how long i can put up with it!
JadeyBlitzen Posted March 2, 2013 Posted March 2, 2013 I'd say running the car on the stock ecu after all the hard work you've do on the engine is a bit of a shame. I bet there are 50 new horses in that engine with the revs hitting 10k rpm. but with the stock ecu with its lower rev limiter I doubt you'll see a major difference other than response. If I was in this position I'd sell my organs to raise money for an aftermarket.
Komisiripala Posted March 3, 2013 Author Posted March 3, 2013 I'd say running the car on the stock ecu after all the hard work you've do on the engine is a bit of a shame. I bet there are 50 new horses in that engine with the revs hitting 10k rpm. but with the stock ecu with its lower rev limiter I doubt you'll see a major difference other than response. If I was in this position I'd sell my organs to raise money for an aftermarket. i say why didn't i think of that before? i can probably do a kidney deal or something and sort it out. trust me, JB, this car is not staying on stock ECU for long. you have my word. praveen i saw your car there again. what's up? mine is still waiting for the final coat of paint. they took the motor out to rebuild it. stripped to nuts and bolts. now have to wait til indika goes to tech motors and buys the rebuild kit... sticking with the P72 pistons. the sleeves are worn but the pistons are fine.
prvnrox Posted March 3, 2013 Posted March 3, 2013 yup i saw the engine "mas karala". they seem to take forever noh? mine was in cuz i had to replace the front shock bush.saw the strut bars and anti-roll bars from ultra racing..nice!
H.C Posted March 4, 2013 Posted March 4, 2013 Are you replacing T belt and waterpump with the rebuild . .Machan do you have that eg compatible strut bar with you or sold it?
Komisiripala Posted March 4, 2013 Author Posted March 4, 2013 Nope still have it. and yes it's up for grabs. PM me for details
Komisiripala Posted March 4, 2013 Author Posted March 4, 2013 front and rear upper and lower strut bars. 4 in total
H.C Posted March 5, 2013 Posted March 5, 2013 <blockquote class='ipsBlockquote'data-author="Komisiripala" data-cid="234267" data-time="1362373684"><p> Nope still have it. and yes it's up for grabs. PM me for details</p></blockquote> PMed!
Hoonigan Posted March 5, 2013 Posted March 5, 2013 i say why didn't i think of that before? i can probably do a kidney deal or something and sort it out. trust me, JB, this car is not staying on stock ECU for long. you have my word. Hold on to your kidneys man, no one really 'finishes' a mod job. You will run out of stuff to sell long before you say "I think I'm done!!!"
shanX Posted March 6, 2013 Posted March 6, 2013 (edited) front and rear upper and lower strut bars. 4 in total Btw ITR comes with a 23mm rear anti-roll bar. Get one, worth it, i has one too Edited March 6, 2013 by shanX
Komisiripala Posted March 6, 2013 Author Posted March 6, 2013 Rear anti roll (and front) already on the car. Came spec on the gsr trim!
