I bought a nissan n16 bluebird sylphy recently and it started overheating when running normally and then i showed it to a mechanic and he said i need to replace the gasket. Then we started removing the engine and found that the gasket needs replacing and further more the piston rings needs replacing as well. while doing all that the mechanic removed the water pump and was surprised to see the state of the water pump and the blades were all broken and it was like empty inside the water pump. so now decided to replace water pump as well. will doing all this sort my problem and is this the right way to do it..
Appreciate if anyone give there ideas as the engine is removed at the minute and i can do everything the right way..
Nissan is bringing in the Primera nameplate back. I hope it's not going to be some boring crossover but a car that will have superb handling, good responsive reliable motor like the Primeras of pre 2000. I also do hope they don't go under and the Primera becomes their saviour.
https://carbuzz.com/nissan-trademarks-primera-name/
Hey Guys,
Sorry for the downtime over the past two days! We’ve been migrating servers and upgrading the site. You might still experience occasional outages as we fine-tune things.
Thanks for your patience! 🙌
autocruise
22 answers to this question
