Barrel Bbq Build
Ripper
Posting on AL after a long long break :)
I believe making a BBQ grill was discussed a few years back and thought of documenting my build as a build log here so it will hopefully inspire another to do the same. Or at least help to avoid a few issues i face during my shot at this.
As of now, i've complete about 80% of the build. Another two weekends and i should be through to the finish line :)
Simply put...I love beer and grilled meat.
Have a been huge fan for a while and i've been using two grills at home.
One was this large oil drum grill i got made from a weld shop a few years back
36127_403299607343_396846_n_zps89fa8661.
It got the job done beautifully. Have had many great times with friends and family with many cold ones.
The only real complains was that it was really poor in aesthetics, wasn't portable, was prone to rust, fire box wasn't good, and had no way of controlling the heat
312703_10150377805872344_45110666_n_zps9
307256_10150377806992344_91238049_n_zpsb
I had it for good five years and have used it pretty often. But now finally it's started to show age and rust away.
I also have a smaller portable grill that used to go in the truck with me on trips and the likes.
Its store bought... highly portable but quite small in size and flimsy.
522229_10150804562552344_1280016499_n_zp
I do love DIY and consider myself to be a tool addict :)
Over time i've collected a bit of equipment so thought of building a grill myself as a weekend project.
Objective was to fix or at least reduce the issues i had with the large barrel unit.
Make it portable so it can go with me in the truck without taking too much of space etc.
I did fair bit of research online to figure out an easy way to design and build. I couldn't find anything that fitted the bill that matched my requirement and skill set.
So i kinda designed my own thing
964BB0FC-CA88-46DF-A3D2-727EB5E179EA_zps
many sketches later, and running through the building process in my head...i kinda settled for this
B8076521-B0A8-4E52-89B1-243F3D4E0981_zps
In a nutshell...
it's a horizontally placed barrel with an opening flap. It will be ventilated with two adjustable vents. One for intake and one for exhaust
Grill to be made with stainless steel and internal firebox to be fabricated so no coal sit on the barrel surface itself
This whole unit will sit on a collapsible scissor stand made out of square tubing.
The tools u need
Welding unit - i'm using a small AC plant. 250amps on 3phase.
Angle Grinder with grinding and cutting discs, A chop saw will make things faster to cut - mine blew a coil while building this and i was limited only to using the grinders.
Drill - i used a bench drill too but a hand drill will still work
Bench grinder - this will make finishing things faster, angle grinder too will work but more time consuming and harder to control in some cases
G clamps, rivet gun, and misc hand tools like hammers, pliers etc
if adding the wooden side table thing, you'll need some wood working tools as well
Supplies
Barrel, L angle steel, 1.5 sq pipe, 1" and 3/4" metal "pattang"
I used 8mm stainless steel rods to make the grill top.
regular and SS weld rods
plenty of cutting discs for the grinder
It's really important to use safety glasses, gloves, hearing protection when using power tools.
In my case i have a curious 5 year old running around my work area and two rotties so safety becomes even more critical.
All powertools should be disconnected from power the moment you're done with them.
1622764_10151885043382344_699487737_n_zp
Got the barrel from dam street for 1500 bucks
Finding one without dents was really hard
1012061_10151885044322344_1699525908_n_z
this too had a small dent. since it's slightly heave gauge metal, beating this back to shape isn't really easy. especially since i don't have a blow torch to heat things up as yet.
But i did manage to hammer this one out
62376_10151885044207344_211361007_n_zps8
This barrel used to carry chemicals needed to make incense sticks...
bloody thing still has the fragrance...
I will do a full burn before painting the exterior with high heat paint so all traces of the chemicals will be taken out.
1014422_10151885044392344_1577792569_n_z
measured and cut the flap open with the angle grinder
1609840_10151885044832344_1259432489_n_z
this was a new disc . barrel ate it up good
1604577_10151885044567344_1868309410_n_z
steel "pattam" added to strengthen the cut edges. these are riveted to the barrel with pop rivets as my welder can't be used on thin sheet metal.
adding these also take out any risk of cuts from sharp edges of the barrel. I did sand paper the edges with 80grit paper to smoothen them in any case.
1010998_10151885045237344_954195324_n_zp
Making a support frame for the top cover/lid with steel pattam
bending these to shape takes a bit of time. i used just two blocks of wood and a hammer as a simple bender.
1901313_10151908960267344_1484183038_n_z
Top cover frame welded in fully
16614_10151885046502344_1599143394_n_zps
Top cover frame riveted in place to the cut off barrel piece. L iron "stopper" added to the barrel so when the lid is close...it has something to rest on
1604591_10151893682312344_1436118056_n_z
Lid kept on the barrel to check fit
1511446_10151893682832344_305385789_n_zp
Almost a perfect fit.... there was like a 3mm difference on one side. Once the hinges come in i'll try to correct that.
fabricating lift handles out of 1" square pipe
1606985_10151895393312344_387380278_n_zp
cutting 45 angles was a tad hard without the chop saw. these were cut with the grinder. managed to fill the gaps while welding.
I employed a oxy welding steel rod as a filler rod in addition to the weld rod. Saw a pro welder doing this and a nicked it from the guy
Trying to use only metal to fill things and keep fillers away as much as i can.
1901188_10151895393252344_818376635_n_zp
These lift handles need to be perfectly square so did all i could to ensure accuracy.
The barrel base was leveled with a spirit level before each marking or welding job. Used a squares to mark angles
Found a sharpened "concrete nail" to be the best a scribe to mark steel. I got a cheapo chinese scribe tool that doesn't perform nearly as good and hold it's edge.
Took less than five mins to make on the bench grinder
1012267_10151897065627344_646204642_n_zp
handles welded in
1795625_10151895542577344_994608009_n_zp
I used an L iron to hold the handle and weld that into the barrel rim. Barrel rim is thick and strong and can take the heat from an arc welder.
The sheet metal wont be able to take the finished weight of the unit.
Also the plan is to have a sliding in wooden table top bit that goes into this handle.
Adding interior ribs
1926901_10151908959597344_1128526121_n_z
this is to hold the firebox cos i don't want it to sit directly on top of the barrel sheet itself.
The thin metal will weaken due to high heat exposure over long periods.
The plan is to fabricate a firebox that will sit on these ribs.... somehow :) i'm yet to fully figure out that one.
Installing L iron on the internal ribs to hold the grill.
The ribs will be riveted to the barrel and these L iron will hold the grill in place
1623210_10151908960457344_180728118_n_zp
Round steel rods welded in to connect the two L iron pieces from either side
This was to stop from the bottom ribs getting distorted when the heavy grill top moves in. It will also reduce strain on the pop rivets
1898115_10151908959257344_1579058896_n_z
There was a a gap between the two l irons with the barrel sheet metal sandwiched in between. I welded a 1/2 pattam piece to cover that up
1922438_10151908959407344_895463858_n_zp
welds are ugly and need fair bit of grinding to clean up
Starting on the grill...
I ran out of SS steel half way through the build. Bought 3nos 12ft rods but i ended up using a total of 6 rods.
These were the pricey ones with one rod priced at 1200 bucks.
1888606_10151920703312344_508939965_n_zp
With rising power bills, switched to the hacksaw and a high speed blade to cut these and gave the grinders a break
sizes were ok. ground the edges a bit on the bench grinder as the saw cuts left rough edges.
1962602_10151908960592344_607353763_n_zp
Welding the grill was the scariest part as i was told repeatedly by friends how hard SS welding is on an AC welding unit
This was untrue as i found SS welding pretty easy.
Keeping the metal rods in place and making sure everything was true... this was a effing nightmare.
1379968_10151920704027344_63808533_n_zps
I tried making a wooden jig with holes spaced evenly but found drilling holes with a 16mm gap wasn't easy at all even with a bench drill.
Finally used the wooden thing as a frame, placed nails to hold the first few rods in place and use those as a guide for the next rod.
Overall quite happy how it came out. It's a bit on heavy side as rods are 8mm but the thought of not having rust to deal with is pretty awesome
I've added handles to either side but forgot to take a pic of it.
Over this weekend, i plan to finish up the stand and mate the top cover with hinges to the main barrel body.
Also need to drill and fix the grill heat gauge i got off ebay, start on the wooden sliding table top and the firebox
Good Job Man!
Theses Barrels were imported by us to sri lanka.
After Packing all the fragrances, we sell these empty drums at Central Road In Pettah.
Some were distributed to E.B. Creasy.
Thanks mate.
I got the barrel from dam street...there was this large barrel shop that sold everything from half cut barrels to plastic ones.
This was the size i preferred and unlike most used barrels you get...these were relatively dent free.
So you guys bring down the chemicals i'm guessing... Went for these assuming it wasn't hazardous.
Anyway i plan on taking this to a friend who's got a gas blow torch to do a full burn.
To get rid of old paint and any traces of chemicals.
Nice work.. i love BBQ as well.
for the temp control issue, does you pit has vent holes on both sides of the drum. most of the good grills i have seen have those on both sides and they can be closed/opened fully or partially to control the heat.
and as for the rust, what i did when i was using one is to clean the thing tray right after using, wash, dry and apply a baking lub spray.
and if u have time, you can try applying a think coat of high temp paint on it. the paint will hold very well, but i dont know how long it will last :)
Thanks. Re: heat control... i was thinking of having a 6" inch diameter circle with four 40mm holes. It's the standard model you get where when you rotate the wheel you can go from full open position to fully closed position. The barrel will have the 4 holes and the disc that comes on top of it will either fully open or fully close the vents. These will come in either side to have even air flow if i want to or have one side more hot than the other.
The top lid is not fully air tight once it's closed, so moisture, fumes etc will have a way out. But i thought of adding a single vent on one side with four 20mm holes, on the same disc adjusting method.
I checked panchi shops for hole saws and they aint cheap. AC paul quoter 5k something for a 40mm hole saw with the mandrel. i only have woodworking hole saws in my tool chest.
So got one off ebay for less than 2k but the darn thing still didn't show up
As for rust. what happens to me after each bbq session is that i top up quite a bit on beer and others end up having to close shop after a session. So maintaining the grill doesn't quite happen the way it should. And for sanity in all fronts, having the stainless still grill is a huge relief for me. Gotta see how the thing holds up though.
I heard SS tend to buckle easier at higher temps so that's why i went for 8mm rods instead of thinner ones. Also i used them across the shorter gap and ran two rods underneath too.
i read all over not to use any kind of paint inside the unit, certainly not a on the grill. So gonna stick to that
Only going to paint the exterior with high heat paint.
I got some from slave island paint shops...matte black that's intended to be used on exhausts.
Not gonna bother painting the firebox as it will come into direct contact with hot coal and i doubt any paint can hold upto that. And there's a good chance of fumes getting released as the paint breaks down. can't risk that.
I read on other diy forums about how people just clean things up properly and spraying the interior bits with simple vegetable oil. Gonna try that option and see how it goes.
If mild rust shows up, i can always attend to it. And if it's the firebox, re-welding another one after a few years of usage is no biggie.
Gonna do the stand, mount the top lid, firebox and hopefully the woodworking stuff too over the weekend :)
Drilling temp control holes are stalled until the darn hole saw arrives.
Edited by Ripper
Brilliant!...Nice to see these DIY projects done properly.
Thanks MD. And thanks for the support in my queries to find everything from heat paint to ratcheting gears :)
Super work Ripper :action-smiley-033:
Thank you!
Great work there Ripper. Admire your thought through planning and attention to detail.
So when is the grand opening BBQ? :P
Looks like the first usage will be in nuwara eliya. Nothing like good company, cold beer and some grilled meat in a cold place
Good question, Davy! I too support a trial run by the autolankans. I mean who better to test this right?
Heh heh... there's the super special, "bbq chicken wing's at MD's house" group. I doubt this little unit is enough to cater to anything larger than that sadly.
Might have to cut open a tanker truck to serve autolankans
1618553_10151932943902344_1747464699_n_z
Early start. cutting 1.5" square pipe for the stand. 45 degree cuts with the angle grinder is a bit hard. Chop saw is still at the motor shop so no choice but to use the grinder.
603665_10151932944752344_1553280718_n_zp
cuts are not very accurate. gotta fill it up when welding.
1496813_10151932945482344_1278997373_n_z
Drilling a pilot hole for the bench drill to grab onto. Used a punch to guide the smaller bit too.
1426714_10151932946202344_1694888946_n_z
The big boy gets to work
1619240_10151932946377344_198009583_n_zp
Two SS bolts holding it in place.
1622759_10151932946412344_1365192313_n_z
Used some cut off 2x4's from a saw horse project to raise the stand up and tie the legs with rope. This is to get the height right before i weld a support brace in place.
1621860_10151932946542344_623492923_n_zp
1982354_10151932946482344_381220676_n_zp
All levelling up
1510583_10151932946597344_1240560229_n_z
Celebrating little victories. It's great when things fall into place right.
1800304_10151932946712344_1494319768_n_z
Center locking brace clamped in for welding
1966842_10151933407732344_1924892677_n_z
fully welded and folded.
1622779_10151932946777344_1370498531_n_z
Locked in place and more than capable of handling a heavy load
1780796_10151933043592344_510531806_n_zp
Top lid tack welded in with 3 hinges
1506582_10151933043632344_573642888_n_zp
1958478_10151933043782344_1877490888_n_z
Grill with handles welded in. will need to use oven gloves when handling this
1781964_10151933407302344_1204142808_n_z
two weld magnets holding a handle piece
1656051_10151933407407344_831672679_n_zp
bench drill chuck can't hold smaller bits. using a smaller chuck i got off a parts shop to hold smaller bits.
1653914_10151933407587344_252926565_n_zp
Handle welded in place. Plan is to cover the front part of the handle with wood. Two wood strips will have a center groove to allow the steel bit to fit in and hopefully epoxy should hold them together. If that fails, can use a screw...hence the center hole
1795537_10151933407652344_1914728185_n_z
Temp gauge off ebay. test fitted this in. thinking of having a metal surround to this so the dial wont get bust up when transporting etc.
Will have to get in oxy welded in from a shop as my arc can't handle sheet metal.
Gotta wait for the weekend to sort out the rest.
next on the list...
Firebox, vents, top lid holding mechanism, wood working bits, finishing and painting.
looks great man.. by the looks of it i assume that the Damn Hole Saw has no arrived yet. hope it shows up soon.. keep it up..
Thanks mate.
yep...no joy on the hole saw :( If it doesn't arrive within the week, i'm gonna try and use the wood hole saw on a piece of sheet metal and see how it goes. Since these are thinner gauge metal it might go through. I can buy a couple and sacrifice them if need be cos they are cheap. Wanted a nice finish and i feel the metal hole saw would be the best bet though.
Noticed a small error on the handle today morning so gonna have to cut that out and re-weld it in place. It's slightly slanted to one side...by like 3-4mm.
2F5E3F01-3BB6-43B8-8353-A235FC9D1F9E_zps
This turned out to be monumental waste of time.
I wanted the top lid to stay securely held once lifted up and was trying to make two collapsible arms.
96F385F1-39B6-420F-AB79-D2473272447A_zps
made all four pieces with drilling, cutting and grinding but found out it wouldn't work.
i was trying to copy the design that keep the tail gate in place on the truck...but didn't really think how things would be different for two curved pieces.
On the truck it's between two flat panels.
Little frustrations of DIY :)
Gonna now replace it with a stainless steel chain. It wont look the best, but without major surgery i can't see a way out.
198431E9-5052-4517-8068-DEB83F3B6DB4_zps
The handle i welded last weekend was off alignment by 3-4mm. I cut the thing out, made a new one with perfect 90 degree angles and welded the thing in place.
3F57FA4C-621E-474F-88C8-FB13BF1922B0_zps
First time using a chemical paint stripper. Wanted the original paint out so i can put my heat proof paint on it
2A5D13D1-8531-4B64-AAC0-5B119BD70208_zps
This is really strong stuff. i was initially thinking of spraying it but luckily didn't got that route and used a brush.
When you get it on your skin, it really burns. Long gloves, pants, shoes all needed to handle this
It's worth it as it works beautifully
D5ED8559-D9A1-40E3-8B25-6D144EC7B983_zps
Most of the paint out, needs a high pressure wash down
1926653_10151947297727344_1810574277_n_z
After the rain my garage floor had got wet and only then i realized the stand legs sitting on the ground straight might not be the best.
Did a quick shopping run at arpico and got these rubber inserts. 1.5 inch square blocks that loosely go into the 1.5inch square pipe.
I drilled a small hole on the pipe to drive a screw later so it will hold the rubber in place. Will also use epoxy on top of the rubber when i'm installing it into the pipe
these four pieces will get welded onto the bottom bit so it will stand on these rubber blocks
1922302_10151947297852344_1221048523_n_z
These weld magnets are really becoming handy.
Welding the brackets in place on the bottom of the stand
1620619_10151947297912344_1160310864_n_z
Finally starting on the coal tray
The bottom "L" frame will have a full sheet metal cover. This will serve as an ash pan.
The four vertical "L" pieces will be covered from bottom and sides to hold coal.
This should be pretty solid but the draw back is the weight. pointless making it out of thinner gauge material as the heat will eat through it fast.
1888538_10151947298012344_1847977777_n_z
Looking more like a "tray" now.
Once in the barrel, the top of this sits 1.2 inch below the grill surface. The coal can go upto 4 inches deep.
3 layers of briquettes i'm guessing...
Since i chose the smaller barrel, interior space is limited... So i had to ditch the idea of trying to make a coal tray with adjustable height.
Should be able to get some level of heat control within the grill by moving the briquettes to one side
Overall temp can be managed by the two air intakes.
