July 29, 201412 yr Blue is a nice colour. You just need to restore the paint work. White was very common in Starlets and most were white sometimes with stickets. Its funny how preferences for colour changes over time. When we got our first white car, everybody wanted metallic paint and white was unfasionable. They called it a comercial colour, but now everyone wants white and wine read. Tomorrow it will be another colour. Personally I won't bother changing the colour of a car bought on a budget. The whole process is long, and sometimes the quality of the new paint is not the same as original.
July 29, 201412 yr Author Today I went to do the wheel alignment and it seems like there is a slight power steering oil leak. and it have effected to one of the front side bush too. Is it good to put p/s rack seal set and mend it or replace the entire rack with a good recondition one. recondition one will cost like 14k. Any comments on that ? White is too good but not planing to go for white. But It will cost less compered to other colors. While i was hunting for a car, I saw "Yellow-green metallic opal" car and "Light blue metallic" one. they look very very nice to me. Think they are original colors (http://www.cars-directory.net/specs/toyota/starlet/1997_12/4656/ ) The current color is faded. and there are scratches and some other marks all over the body. Its clearly visible the original state of the paint is preserved under the ducky door. which is dark blue metallic and it too beautiful. Im going to light blue metallic because no need to worry about RMV and Its too nice. Still even hadn't had time to do the cut and polish. Alloys will come little later like in next year. Currently i'm happy with the new rim cups. This one have 175 size tires, in next tire change going to put 155/80R13 which is manufacturer rerecorded. But if budget allows I'm going to put glanza front buffer with fog lamps it adds a entire new look in front.
July 29, 201412 yr For the power steering rack, the better option would be to get the current rack repaired if the only issue is an oil leak. Get a good mechanic to do the job and you'll be fine. Replacing the rack is just an unnecessary overhead IMO. On paint, I agree with The Don and think you should keep the original colour. Even if its a different shade of the same colour (I.e. light blue as you've said) or a completely different colour (i.e. White), the correct process of re-painting will still be the same if you're not re-painting to match the existing colour. Your car will need to be dismantled totally to do a perfect job. Remember that even the engine bay and hard to reach areas such as under the dashboard and inside the door panels are painted in the stock colour. As for changing the tire size, I think you will be disappointed after switching from 175 to 155 because your car will start to look like a starlet with tires from a Bajaj Pulsar. :S Wide tires look better and I think you should continue to use them if the previous owner has not changed the profile of the tire (height of the sidewall). My two cents...
July 29, 201412 yr Author As for changing the tire size, I think you will be disappointed after switching from 175 to 155 because your car will start to look like a starlet with tires from a Bajaj Pulsar. :S Lol. Thanks mate. My concern is will the leak will be ok for few years after its repaired. do you now how the cost will be roughly for the kit. Edited July 29, 201412 yr by hiru555
July 29, 201412 yr If the paint you have is completely Sh*t, repaint it with the same colour, it will be a lot cheaper as it saves you from removing the internals of the car, After the things are removed and refitted things won't be the same again, plastics will start to rattle like hell, and you will have to keep it parked for a long time in the garage and the whole thing will be a "Koti walge", So i sugest you keep the original colour, do a complete respray with the same colour and from the money you saved buy a set of rims
July 30, 201412 yr What clarkson says is true. Even if is a lighter blue, still colour change is a big deal. And unless yo fully strip the car it will be a half assed job. I went from blue to white and process took about 3 months, and estimated cost for my car was 162,000. Tis was a complete strip down, so that you can't tell it was blue earlier. Even the floorboard was resprayed for authenticity. Like I said, a good cut and polish will help. If not, spray again fully in the same colour. That should be arond 60-80,000 depending on what paints and lacquers you use.
July 30, 201412 yr +1 clarkson. Experienced a total colour change on a corona AT 190 from black to white few years back. process took more than 5 weeks at a local garage. and the paint was superb with low heat inside the cabin on daytime due to white paint. but there were rattles from plastics everywhere,especially from dash which we were unable to locate nor rectify.which were quite annoying on uneven roads. my best bet is to not change colours. repaint the original colour. you may save time money an probable rattles. Edited July 30, 201412 yr by chan5
July 30, 201412 yr Since this is your first car expending too much on it will not be a good idea. Get a cut and polish done. Fix the leaks and minor things . Run for some time. If you are happy with it think of big work like respraying then. I've used an EP91 for almost 9 years. The biggest problem I had was seats getting stains from the inside. Not enough legroom for rear passengers comparing with the other hatches of the same class.
