January 10, 20197 yr @Davy Check this engine cover out! This car was advertised for sale on Autolanka classifieds. Looks like itย has the uppermost firewall lining, but if you look closely at the firewall the bare metal is visible, looks like it doesn't have the firewall heat shield Edited January 10, 20197 yr by Hyaenidae
January 10, 20197 yr 4 hours ago, Hyaenidae said: @Davy Check this engine cover out! This car was advertised for sale on Autolanka classifieds. Looks like itย has the uppermost firewall lining, but if you look closely at the firewall the bare metal is visible, looks like it doesn't have the firewall heat shield Oh this is @E L N I N O's EX. Maybe he can shed some light.ย The engine cover appears to be a different, larger version. Makes the engine look much bigger.ย
January 11, 20197 yr 9 hours ago, Davy said: Oh this is @E L N I N O's EX. 1 That Lancer is a beauty, wonder why he's selling it... @trinityย Can you check whether your LanEX has the topmost soundproofing lining and the black heat shielding on the firewall?
January 12, 20197 yr Author On 1/11/2019 at 11:31 AM, Hyaenidae said: That Lancer is a beauty, wonder why he's selling it... @trinityย Can you check whether your LanEX has the topmost soundproofing lining and the black heat shielding on the firewall? Just took couple of photos, the upper most sound proofing is not there, but the black heat shied lining is available. I just observed, why are those wires kept exposed like that? is it the same with your car as well @Hyaenidae? Also appreciate if you guys could suggest a good and easy product to clean that engine bay..ย
January 12, 20197 yr Yep it's kinda exposed, I had a pic I thinkSent from my Nokia 1100 using AutoLanka.com mobile app powered by Tapatalk
January 12, 20197 yr Sent from my Nokia 1100 using AutoLanka.com mobile app powered by Tapatalk Edited January 12, 20197 yr by Hyaenidae embed image
January 12, 20197 yr Author 11 minutes ago, Hyaenidae said: https://i.imgur.com/ADkCak7l.jpg Sent from my Nokia 1100 using AutoLanka.com mobile app powered by Tapatalk ย hmmm, at least there's more tape on yours.. ha ha. your engine bay looks super clean..ย ย
January 12, 20197 yr 6 minutes ago, trinity said: hmmm, at least there's more tape on yours.. ha ha. your engine bay looks super clean..ย ย UNIMO buggers use pressure washers on the engine bay on routine service, albeit from some distance... that was back in Edit: March 2018 though. After seeingย this thread I've decided to tell them not to clean the engine bay anymore Edited January 12, 20197 yr by Hyaenidae
January 12, 20197 yr Author 4 minutes ago, Hyaenidae said: UNIMO buggers use pressure washers on the engine bay on routine service, albeit from some distance... that was back in Edit: March 2018 though. After seeingย this thread I've decided to tell them not to clean the engine bay anymore Yes, i too have seen them wash the engine bay with pressureย guns, was wondering why they are doing it like that especiallyย when they being the agent. Anyways whats the cost of getting the EX serviced with them?
January 12, 20197 yr 1 minute ago, trinity said: whats the cost of getting the EX serviced with them? ย Here's a list of things I've got done at UNIMO, with the cost: Change engine oils Labour : 894.66 VAL PREMIUM CON 10W30 4L : 4326.00 Oil Filter Assy replacement Labour : 577.20 OIL Filter #MD360935 : 2273.00 Air Cleaner Assy Replacement Labour : 577.20 Air cleaner #MR968274 :ย 6157.00 Body Wash, undercarriage only Labour : 894.66 Vaccum Clean Labour : 548.34 REM/REFIX and CLEANING wiper deck panel Labour : 1154.40 Brake fluid change Labour : 825.24 DOT3 Brake Fluid : 471.00 ย ย ย
January 12, 20197 yr Author 5 minutes ago, Hyaenidae said: Here's a list of things I've got done at UNIMO, with the cost: Change engine oils Labour : 894.66 VAL PREMIUM CON 10W30 4L : 4326.00 Oil Filter Assy replacement Labour : 577.20 OIL Filter #MD360935 : 2273.00 Air Cleaner Assy Replacement Labour : 577.20 Air cleaner #MR968274 :ย 6157.00 Body Wash, undercarriage only Labour : 894.66 Vaccum Clean Labour : 548.34 REM/REFIX and CLEANING wiper deck panel Labour : 1154.40 Brake fluid change Labour : 825.24 DOT3 Brake Fluid : 471.00 ย ย ย Wow, Thanks for the detailed info machang, is viper deck panel removing and cleaning a part of the service or you just had it done additionally? ย
January 12, 20197 yr 1 minute ago, trinity said: Wow, Thanks for the detailed info machang, is viper deck panel removing and cleaning a part of the service or you just had it done additionally? ย It's not a part of the service, just a precaution to prevent drains from clogging with dead leaves and whatnot I get it done once every year.
January 12, 20197 yr Author Just now, Hyaenidae said: It's not a part of the service, just a precaution to prevent drains from clogging with dead leaves and whatnot I get it done once every year. Thats great.. I too should get it done cuz my car is parked near a treeline at the office and sometimes dead leaves get stuck inside the gaps between viper arms and the panel...ย ย
January 14, 20197 yr On 1/11/2019 at 2:01 AM, Davy said: Oh this is @E L N I N O's EX. Maybe he can shed some light.ย The engine cover appears to be a different, larger version. Makes the engine look much bigger.ย Hey Davy, it's been a while.ย Sorry I wasn't active here for a long time. Thanks for dragging me back in About the cover, it's not OEM, I bought it off ebay or Aliexpress (can't remember exactly) after seeing the 4A9 DOHC 16valve lettering on it. I wish it said MIVECย though. It wasn't a direct fit, I had to do some work to get it properly in place. And BTW it didn't come with any heat insulation. On 1/10/2019 at 9:00 PM, Hyaenidae said: Looks like itย has the uppermost firewall lining, but if you look closely at the firewall the bare metal is visible, looks like it doesn't have the firewall heat shield You were right. I checked my engine bay, it has the black heat shield but not the uppermost lining. Probably the brand new imports never came with it, thanks to UMย ? On 1/11/2019 at 11:31 AM, Hyaenidae said: That Lancer is a beauty, wonder why he's selling it...๏ปฟ Thanks for the compliment ย I'm planning to upgrade. I neither have money nor space for two vehiclesย so have to let her go, sadly.
January 20, 20197 yr @Trinity did you receive the last PM I sent? It seems I've lost all my conversations on the app.Sent from my Nokia 1100 using AutoLanka.com mobile app powered by Tapatalk
February 4, 20197 yr Author On 1/20/2019 at 10:50 PM, Hyaenidae said: @Trinity did you receive the last PM I sent? It seems I've lost all my conversations on the app. Sent from my Nokia 1100 using AutoLanka.com mobile app powered by Tapatalk ย Ya machang, if itโs the one with the photos of the seat railing, I received it. Sorry couldnโt reply you as I was dealing with so many things.. still life is very very busy these days.ย
February 4, 20197 yr Author On 1/22/2019 at 8:09 AM, nagaya said: Nice ride trinity Congratulations! Did you sell the CS ? ย ย Thanks nagaya, yes I sold the CS. ?
February 4, 20197 yr Ya machang, if itโs the one with the photos of the seat railing, I received it. Sorry couldnโt reply you as I was dealing with so many things.. still life is very very busy these days.ย Ah, glad to hear it. Somehow the AL app cleared all my messages and didn't allow me to send messages, couldn't check if you received my message until Madz fixed it for meSent from my Nokia 1100 using AutoLanka.com mobile app powered by Tapatalk
December 11, 20196 yr Author Have few small updates on some new additions I made to the car. She didn't have door visors when I bought her and the window tint was badly faded. So got the windows tinted with 3M film and was able to import near genuine looking set of visors thanks to a friend of mine who is also a car addict. Did another small change, the B pillar area of the doors were in the original body colour and I did not like it at all. So got it blacked out as well. Here are the photos. ย Before installing the visors and getting the tint done. The visors and plus the tint. As you can see I didn't go for a dark tint, instead opted for a lighter one which cuts out the heat. Also this way visibility during the night time is also not compromised.ย I removed the seat covers which was there when I bought the car as the were worn out. And got a interior cleaned (there were not much to clean though).ย All these were done during June 2019.
December 11, 20196 yr Car is looking great. Might I suggest bigger wheels for the car? (17โor 18โ)
October 29, 20224 yr Author Look who came to see me today!ย After almost 4 years since we departed I met my ever loving CS today. It was a moment with mixed feelings. I was happy to see her but at the same time was sad to see the state she was in.ย Nevertheless she will forever hold that special place in my heart until the day my eyes are shut for good. Miss you old buddy!ย
November 1, 20224 yr On 10/29/2022 at 4:26 PM, trinity said: Look who came to see me today!ย After almost 4 years since we departed I met my ever loving CS today. It was a moment with mixed feelings. I was happy to see her but at the same time was sad to see the state she was in.ย Nevertheless she will forever hold that special place in my heart until the day my eyes are shut for good. Miss you old buddy!ย Sadly in the current situation people do the bare minimal actions just to make sure the cars run and nothing more - a good many cars are deteriorating due to this.ย P.S : can't help but mention that that particular CS has a timeless design. Oh and since we're on about Lancers mine says hi.ย ย
November 1, 20224 yr Author 15 minutes ago, matroska said: Sadly in the current situation people do the bare minimal actions just to make sure the cars run and nothing more - a good many cars are deteriorating due to this.ย P.S : can't help but mention that that particular CS has a timeless design. Oh and since we're on about Lancers mine says hi.ย ย Completely agreed on this. That never look never get old.ย Glad to see your Lancer as well. This used to be THE car at one point in SL history of cars. Still holds a good demand I think.ย
