codexdj Posted June 1, 2014 Posted June 1, 2014 Which means that JDM belta which has the same engine should respond too!! Quote
sharky Posted June 1, 2014 Posted June 1, 2014 Which means that JDM belta which has the same engine should respond too!! Hobdrive did work with the 1krfe engine on the vitz, I guess if the same engine is on the belta it should work. Btw. the OBD protocol used with these JDM versions is Toyota CAN21, I have also seen it being mentioned as JOBD(Japanese-OBD?) Quote
Davy Posted June 2, 2014 Posted June 2, 2014 Tried several times on my CS3 with Torque and Scanator and it just doesn't pick up the ECU. :S Hi guys, Just my two cents, I have been using a cheapo elm327 on my JDM vitz ksp90, None of the conventional software worked (i.e. Torque & all the windows programs), but I came across Hobdrive for android https://play.google.com/store/apps/details?id=hobd.android . It works like a charm, it has different vehicle profiles, included is the passo, just tweak around with the vehicle weight, fuel tank capacity and it will work on the vitz. It'll scan for engine DTCs give fuel consumption and other goodies. Maybe you guys can check it out? Thanks! This I will try. Which means that JDM belta which has the same engine should respond too!! Unfortunately, The Belta is no longer within my reach anymore. It was my brother in law's car, and he sold it a couple of months back. Quote
Genting Posted June 13, 2014 Posted June 13, 2014 I have tried Tachyon in several Toyota vehicles and as they have claimed, it was working with all of Toyota JDMs. vehicles incluede: Corolla 121 2004 IST 2008 Vitz 2008 Premio 2014 Corolla 2014 (US) Allion 240/260 I got the Blutooth verion with Android app http://www.tachyontechtools.com/?product=obd-ii-t100-bt-toyota/ Quote
E L N I N O Posted June 16, 2014 Posted June 16, 2014 Guys! Anyone tried this with an N16 ? Didn't try this. But I tried Torque with an N16 but it didn't pick up the ECU. Just FYI. Quote
NRX Posted June 16, 2014 Posted June 16, 2014 Didn't try this. But I tried Torque with an N16 but it didn't pick up the ECU. Just FYI. Thanks, was trying to find out whether these cheap scanners work with N16. Weird, I thought they work with export variants (Non JDM) of vehicles. Quote
Madcat23 Posted July 30, 2014 Posted July 30, 2014 my vanguard is a JDM - a cheap EM327 works great coupled with torque. i`m now ordered a slightly expensive scanner (google OBDlink LX) as the chinese one can be easily hacked into (i know low chance of that happening but imagine the headache that will cause if it happens) also if kept plugged in for a long time since these scanners continuously try to pair bluetooth therefore there is a chance that they can run down the battery. however there are ones with on/off switches now on ebay. Quote
The Don Posted July 30, 2014 Posted July 30, 2014 my vanguard is a JDM - a cheap EM327 works great coupled with torque. i`m now ordered a slightly expensive scanner (google OBDlink LX) as the chinese one can be easily hacked into (i know low chance of that happening but imagine the headache that will cause if it happens) also if kept plugged in for a long time since these scanners continuously try to pair bluetooth therefore there is a chance that they can run down the battery. however there are ones with on/off switches now on ebay. Thought you bought it brand new? Quote
Madcat23 Posted August 15, 2014 Posted August 15, 2014 (edited) Thought you bought it brand new? yeah it is ! the user manual is all Japanese - luckily i found a translated version online. a have another question. does the ECU report the exact fuel consumption or is it off by factors like our fuel quality, octane value etc.. cause according to this i`m doing 10.7 Kmpl - having driven around 300kms using this wa wa wa wonder ... Edited August 15, 2014 by Madcat23 Quote
Madhawa Habarakada Posted November 16, 2014 Posted November 16, 2014 Great post. I was to order one from ebay several days ago. but didn't knew clearly how to use or get it to work. I just ordered one from ebay. Thanks for this great tutorial. Quote
HenryP Posted July 9, 2015 Posted July 9, 2015 Hi Guys Just got on the forum today. I love to mess around with my car and wanted to get a basic diagnostic tool. I was told that Launch scanners are very good but they are very expensive. I just saw this DIY model and wanted to know if anyone has any experience or info on it. Launch CRP 229 scanner. There is a company selling it on #### http://####/en/ad/launch-scanner-crp-229-for-sale-colombo-2. Would appreciate some feed back on whether its worth it. Thanks Quote
Rumesh88 Posted July 9, 2015 Posted July 9, 2015 (edited) Hi Guys Just got on the forum today. I love to mess around with my car and wanted to get a basic diagnostic tool. I was told that Launch scanners are very good but they are very expensive. I just saw this DIY model and wanted to know if anyone has any experience or info on it. Launch CRP 229 scanner. Would appreciate some feed back on whether its worth it. Thanks Good to see someone willing to mess around with his car . If you are looking for a scanner you must check its compatibility with the protocol of your car's OBD port. There are several protocols like EOBD, JOBD etc., although most of protocol issues can be address at a software level, others need compatibility with hardware as well. What the car in question BTW? Edited July 9, 2015 by Rumesh88 1 Quote
asanka_rg Posted July 22, 2018 Posted July 22, 2018 Hi all, This is regarding the bluetooth ODB II scanner tool ELM 327. I purchased on Ebay and tried with android app. but cant access to the ECU.Β my car is suzuki swift 2003 HT51s. have you ever tried this please let me know? thanks. Β Β Quote
Davy Posted July 22, 2018 Posted July 22, 2018 4 hours ago, asanka_rg said: Hi all, This is regarding the bluetooth ODB II scanner tool ELM 327. I purchased on Ebay and tried with android app. but cant access to the ECU.Β my car is suzuki swift 2003 HT51s. have you ever tried this please let me know? thanks. Β Β Merged your thread with this one as this is discussed extensively on this thread.Β Some JOBD vehicles don't work with ELM327.Β Quote
asanka_rg Posted July 22, 2018 Posted July 22, 2018 3 hours ago, Davy said: Merged your thread with this one as this is discussed extensively on this thread.Β Some JOBD vehicles don't work with ELM327.Β thanks davy. by the way guys please comment if anybody ever tried this with a swift. Quote
kmeeg Posted July 23, 2018 Posted July 23, 2018 On 7/22/2018 at 8:05 AM, asanka_rg said: thanks davy. by the way guys please comment if anybody ever tried this with a swift. Β On 7/22/2018 at 8:05 AM, asanka_rg said: thanks davy. by the way guys please comment if anybody ever tried this with a swift. Haven't try on a swift, but just wanted to check the app you tried. Is this the one you tried? Also that ELM327 only work on Androids. Does not work for iPhone (Atleast the one I bought from ebay didn't work on iPhone) Β Quote
Davy Posted July 23, 2018 Posted July 23, 2018 52 minutes ago, kmeeg said: Also that ELM327 only work on Androids. Does not work for iPhone (Atleast the one I bought from ebay didn't work on iPhone) Β There are versions that work on Android, iOS, Windows and Mac. These adaptors are made by many different companies, so you just need to check before buying.Β Quote
kmeeg Posted July 23, 2018 Posted July 23, 2018 14 minutes ago, Davy said: There are versions that work on Android, iOS, Windows and Mac. These adaptors are made by many different companies, so you just need to check before buying.Β I forgot to say the bluetoothΒ ELM327ο»Ώ Β When I searched a bit I saw that bluetooth one is only for Android and the same one with wifi support iPhone. But yes, as you said there may be other brands that might work over bluetooth with iphone.Β Anyways, I think forΒ asanka_rg'sΒ should loan someone else's OBD scanner and phone with a working app and check if it works or not. (I guess) Quote
asanka_rg Posted July 25, 2018 Posted July 25, 2018 (edited) Hi Kmeeg, I am using android and I tried around 20 apps which can be found on the internet. Both cracked and free versions. ECU connection was established for none. One more thing I tried with a Nissan cefiro 2000 same issue is there.Β Note that this scanner is called elm 327 ver 2.1. thanks. Β Β Edited July 25, 2018 by asanka_rg Quote
JayZ Posted July 25, 2018 Posted July 25, 2018 ELM 321 v2.1 has some compatibility issues. V1.5 works fine. Most sellers on Al*Ex advertise this note now. 1 Quote
