I have Mitsubishi C62A (known as ASP Model 1991). It has 4G15 engine and very powerful. But I'm not happy with the fuel efficiency of this car. And there is a black smoke as well. I just surf the new and found this car does 14km/1ltr (average). But my one is doing nearly 8km/1ltr (without AC).
I was searching a solution through net since I'm really really tired with garages. I took my vehicle to a lot of place to solve this issue. But so far no good result.
I found some instructions from a forum. This is about tuning the engine (4G15). Please check this and let me know your feedback since I'm going to try this on Saturday .
1) Warm up engine first(run 5-10 mins) 2)Shut off engine 3) Back out on the idle speed screw until it justt doesn't touch the throttle linkage. Then screw it in back about 11 turns (what this does mean actually?) 4) Screw in the A/F mixture screw until it stops(do not force tighten) 5) Screw out the A/F mixture screw 2 full turns 6) Start the damn car. It will run like its choking. As long as it's running it's ok. 7) Now turn in the A/F screw until engine dies. If this happens, turn out the A.F screw half turn at a time to bring it back. (try to start the car of coz)(what this does mean?) 8)Continue to turn out the A/F screw at half turns every 3 seconds. Engine will pick up speed. Continue to screw out until the point engine runs worse. When that happens screw back in half turn every 3 secs to the point engine runs smoothest.(do this by ear or watch engine vibration) (what this does mean?) 9) Now set the idle speed. Go on the air conditioner. Watch the tachometer. Turn in the idle speed screw until rpm is around 900 to 1000 rpm. 10) Now it's ready to rumble..
black smoke also caused by KO piston ring (what this does mean?).. check the compression
Guys, please let me know your feedback, is it ok if I follow this to tune my engine? Only problem is my AC is not working. So will it be a problem for me to follow these steps since it says that I need AC to be on during the process. Please advise.
Will this help to get a good fuel efficiency and stop black smoke?
Iroshw
Hi guys,
2)Shut off engine
7) Now turn in the A/F screw until engine dies. If this happens, turn out the A.F screw half turn at a time to bring it back. (try to start the car of coz) (what this does mean?)
Top Posters For This Question
12
7
7
6
Popular Days
Sep 11
9
Feb 27
6
Mar 10
5
Sep 28
5
Rumesh88 12 posts
The Don 7 posts
kusalk 7 posts
PerfMad 6 posts
Popular Days
Sep 11 2013
Feb 27 2015
Mar 10 2015
Sep 28 2013
Popular Posts
Iroshw
Hi guys, I have Mitsubishi C62A (known as ASP Model 1991). It has 4G15 engine and very powerful. But I'm not happy with the fuel efficiency of this car. And there is a black smoke as well. I just sur
trinity
This i highly recommend through my experience.. I was experiencing some what similar issues with my carb and non of the cleaning and using non genuine carb repair kits did work. Ultimately got myself
Rumesh88
<blockquote class="ipsBlockquote" data-author="kusalk" data-cid="272881" data-time="1424708011">Dear Rumesh, <p>I'mm having a Lancer CK2 with 4g15 engine. But the carb of it gives a lot o
55 answers to this question
