I had to do a clutch and pressure plate replacement for my car so I put it in the garage.
While the mechanic were removing the parts they found cracks on my flywheel.
So he advised me to put in a reconditioned flywheel for the car. I agreed.
So the car now has a reconditioned flywheel, new clutch plate, new pressure plate.
After connecting the entire thing up the gears were not falling in. So this mechanic removes everything again and REMOVES the gearbox!!!
He then tells me that some links and some balls inside the gear box needs to be replaced. What can I do... I had to go ahead with it.
Then after fitting back the whole thing he test drove the car and calls me and says gears 1, 3 and 5 fall in but gears 2 ,4 and reverse grind!
I then visit the garage after work and I found out that this man has gone and bent my gear link ( one of the long links from the gear lever to the gearbox) to try and make the gears fall in.
But still gears 2, 4 and reverse dont fall in.
On top of all the damage above the guy has done some welding at the gear mount (see pic) and due to the heat the rubber mount has broken as well.
I took the vehicle out of the garage immediately. But I need someone who can help me to fix my car!
I have got screwed so badly!!! This was a perfectly working car before this guy touched it!
So for a spirited convo like this old times; ?BYD
My father has gone ninja about getting one, despite being the new hype/fad here these are common across the world and I've seen a few cross 100,000km in Nepal and Australia.
Seal - Looks nice, very premium interior but too low for my applications
Sealion - Very Premium, feels very well built, BUT that 1.5L on that reasonable chunk of car with a measly 18KW battery seems like a recipe for trouble, incase they sink in value at least the fuel economy must justify that (They say it's a BYD engine - though the lore is it is a hyundai engine)
Atto 3 - Most sold from their lot apparently, common af, Seems to be the best bang for buck IMHO, Its electric since BYD is famed for that, Interior is kinda good, the thing is larger than a vezel but not too large like the Sealion, cheap mobility I guess with less things to go wrong
Dolphin, almost a smaller atto and again too car like and not suited for my application.
JK nailed it on the price and distribution but the only guaranteed thing here is the lot are gonna muck up the aftersales. The Kandy center staff behave like the crew from a Govt. post office.
What are your thoughts and opinions? Could this be the next Wagon R or is this a passing fad like the Micros of 2000s-2010s?
I have an empty parking slot at home previously occupied for 6 years by the starlet and 3 months by an AD wagon -what would be a bang-for-the-buck fun shitbox? Preferably auto as I live in a crowded suburb that has sapped the joy of stick shift out of my system.
Iced-T
Help!
Please help!!!
Regards,
Iced-T
spelling error
18 answers to this question
