Jbreak Posted December 23, 2017 Share Posted December 23, 2017 (edited) Guys, Any idea what this symbol is about? It’s in my friends 2015 Aqua Edited December 23, 2017 by Jbreak Quote Link to comment Share on other sites More sharing options...
iRage Posted December 23, 2017 Share Posted December 23, 2017 Service required indicator. The most common reason it seems to come on (according to user manual) is when the Hybrid system's cooling system has an issue. It could be as simple as the vents for the battery getting clogged. So look around a bit and then take it to a proper Hybrid service center or the agents. The error was discussed before on the forums...perhaps you can dig it up again ? 1 Quote Link to comment Share on other sites More sharing options...
Jbreak Posted December 23, 2017 Author Share Posted December 23, 2017 On 12/23/2017 at 1:45 PM, iRage said: Service required indicator. The most common reason it seems to come on (according to user manual) is when the Hybrid system's cooling system has an issue. It could be as simple as the vents for the battery getting clogged. So look around a bit and then take it to a proper Hybrid service center or the agents. The error was discussed before on the forums...perhaps you can dig it up again ? Expand Thanks IRage.To be honest I searched it but didn’t come across anything related to this.Anyways appreciate ya help! Quote Link to comment Share on other sites More sharing options...
iRage Posted December 23, 2017 Share Posted December 23, 2017 Check the user manual. Page 344 to be exact. That is where I found it the first time someone asked it on the forum and on FB. The description is in Japanese but you can use the Google translator phone app to translate it. 1 Quote Link to comment Share on other sites More sharing options...
Jbreak Posted December 23, 2017 Author Share Posted December 23, 2017 On 12/23/2017 at 2:30 PM, iRage said: Check the user manual. Page 344 to be exact. That is where I found it the first time someone asked it on the forum and on FB. The description is in Japanese but you can use the Google translator phone app to translate it. Expand Thanks a lot for the info mite Quote Link to comment Share on other sites More sharing options...
SalmanAhmedKhan Posted July 2, 2018 Share Posted July 2, 2018 Toyota Aqua 2015 showing this sign and the engine sign. Any know what dose this mean? Quote Link to comment Share on other sites More sharing options...
Crosswind Posted July 2, 2018 Share Posted July 2, 2018 On 7/2/2018 at 3:25 PM, SalmanAhmedKhan said: Toyota Aqua 2015 showing this sign and the engine sign. Any know what dose this mean? Expand This has been discussed http://autolanka.com/forums/topic/17074-dashboard-warning-light/?do=findComment&comment=280219 Quote Link to comment Share on other sites More sharing options...
SalmanAhmedKhan Posted July 2, 2018 Share Posted July 2, 2018 On 7/2/2018 at 3:25 PM, SalmanAhmedKhan said: Toyota Aqua 2015 showing this sign and the engine sign. Any know what dose this mean? Expand Quote Link to comment Share on other sites More sharing options...
Jbreak Posted July 4, 2018 Author Share Posted July 4, 2018 On 7/2/2018 at 6:47 PM, SalmanAhmedKhan said: Expand On 7/2/2018 at 6:47 PM, SalmanAhmedKhan said: Expand Hi Salman, The indicator shows that you need attention with Hybrid battery. Take the car to a proper technician and run a scan on battery. You will be able to get an idea how many cells needs replacement. (Toyota Aqua 2012 has 20 cells in its hybrid battery and as per what i was told by the tech guy we can replace cells if the replacement is for less than 10 cells, More than that he recommended to replace the full battery. This is never recommended by the agent and they would ask you to replace the battery with new one.) I also have a 2012 and 6 months ago i too had the same problem (Found many Aqua's having the same issue once it pass 5 year mark or 100,000 mileage in common) . I replaced 7 cells in the battery and driving my car for past 6 months without an issue. I know its not a permanent solution but so far it has worked. 1 Quote Link to comment Share on other sites More sharing options...
Quiet Posted July 5, 2018 Share Posted July 5, 2018 I saw an advertisement. Toyota Lanka is doing Hybrid Battery replacement. Cant remember the prices though. Quote Link to comment Share on other sites More sharing options...
Jbreak Posted July 11, 2018 Author Share Posted July 11, 2018 (edited) On 7/4/2018 at 4:12 AM, Jbreak said: Hi Salman, The indicator shows that you need attention with Hybrid battery. Take the car to a proper technician and run a scan on battery. You will be able to get an idea how many cells needs replacement. (Toyota Aqua 2012 has 20 cells in its hybrid battery and as per what i was told by the tech guy we can replace cells if the replacement is for less than 10 cells, More than that he recommended to replace the full battery. This is never recommended by the agent and they would ask you to replace the battery with new one.) I also have a 2012 and 6 months ago i too had the same problem (Found many Aqua's having the same issue once it pass 5 year mark or 100,000 mileage in common) . I replaced 7 cells in the battery and driving my car for past 6 months without an issue. I know its not a permanent solution but so far it has worked. UPDATE 11th July 2018: Had the same issue on Friday, 6th July 2018 and replaced four cells again the following day.First repair in Nov,2017 cost me Rs.58,000 (Rs.7000/- a cell + Rs.9000 for tech charges which was done manually.). This time the cost was Rs.49,000 at Rs.8500 /- a cell + Rs.15,000 (For electronically balancing the battery). I've been using the car since Aug, 2015 and do regular services with the agents. This was the only problem i had in 3 years and unfortunately for me its the battery. Expand Edited July 11, 2018 by Jbreak Quote Link to comment Share on other sites More sharing options...
Crosswind Posted July 11, 2018 Share Posted July 11, 2018 So, @Jbreak what you say is you have replaced cells for the second time in 6 months? Is that right? Also how many other users do you think are affected like this? Quote Link to comment Share on other sites More sharing options...
Jbreak Posted July 11, 2018 Author Share Posted July 11, 2018 On 7/11/2018 at 8:36 AM, Crosswind said: So, @Jbreak what you say is you have replaced cells for the second time in 6 months? Is that right? Also how many other users do you think are affected like this? Expand Hi @Crosswind Yes, You are right. I have basically replaced 11 cells of my battery.There are two others i know who has the same problem with their 2012 & 2014 YOM's. With the recent post published here there's four including myself Quote Link to comment Share on other sites More sharing options...
zarrar Posted September 24, 2018 Share Posted September 24, 2018 On 7/11/2018 at 7:35 AM, Jbreak said: thank u i have the same problem Expand Quote Link to comment Share on other sites More sharing options...
Jamshaid Posted December 15, 2018 Share Posted December 15, 2018 What does these signs mean? Please help. Quote Link to comment Share on other sites More sharing options...
Davy Posted December 15, 2018 Share Posted December 15, 2018 On 12/15/2018 at 4:33 PM, Jamshaid said: What does these signs mean? Please help. Expand The one on top is a "Check Engine" indicator. Usually means that the ECU has detected a problem and a diagnostic scan needs to be done to find out the error code(s) and address them. The far right one has already been discussed on this thread. EV system error. The one on the far left is too bright for me to see what it is, so not sure. The yellow and red ones that look alike are brake system indicators. The red one is a parking brake active indicator while the yellow one is a brake system warning. Usually with ABS. In your case, it might be with the regenerative braking system due to the car being a hybrid. If you see these indicators after the car has been started, then take it to a hybrid expert or Toyota Lanka itself and have a diagnostic scan done. Quote Link to comment Share on other sites More sharing options...
Jamshaid Posted December 16, 2018 Share Posted December 16, 2018 (edited) Thanks a lot! I took it the expert today. It doesn’t seem to be a serious problem. We ran the scan and it said “replace hybrid battery pack”. The other guy said there’s nothing wrong with the battery. I’m not sure why the lights turned on. He refreshed the codes and so far it’s all good. Edited December 16, 2018 by Jamshaid Quote Link to comment Share on other sites More sharing options...
Davy Posted December 17, 2018 Share Posted December 17, 2018 On 12/16/2018 at 6:53 PM, Jamshaid said: Thanks a lot! I took it the expert today. It doesn’t seem to be a serious problem. We ran the scan and it said “replace hybrid battery pack”. The other guy said there’s nothing wrong with the battery. I’m not sure why the lights turned on. He refreshed the codes and so far it’s all good. Expand Hmm. When a car shows an error indicator, it doesn't usually mean that there's "nothing wrong". Anyway, was a repair done on your car recently? Quote Link to comment Share on other sites More sharing options...
Hyaenidae Posted December 17, 2018 Share Posted December 17, 2018 On 12/16/2018 at 6:53 PM, Jamshaid said: He refreshed the codes and so far it’s all good. Expand Most probably it will return... On 11/7/2017 at 3:01 PM, Aslam86 said: I recently purchase a Toyota Aqua 2013 model which has done 62000Km Couple of days later the 'Check hybrid system' and 'Check Engine' indicators were shown. After taking to Toyota Lanka, I got a system scan done and the error code was P0A80, which is for Replace Hybrid battery pack. They identified the issue to be a voltage drop in one of the battery cell. They recommended to do a battery service, but while removing the battery they found the battery has already been serviced as well. For the moment I have temporarily got the code deleted. This is temporary and the error will appear again (I got it twice). The recommended solution is to replace the battery pack. Agent price is extremely expensive, but few other places said it would cost around 200,000. I wanted to know if replacing the problematic cell would be a good option? has anyone done this? if so what are the good places which this can be done. I spent 4 Million for the car and don't have another 200K at the moment. Anyone got any solution? Expand Quote Link to comment Share on other sites More sharing options...
KSM Posted January 10, 2019 Share Posted January 10, 2019 To remove the spanner alarm clean the hybrid battery vents. Quote Link to comment Share on other sites More sharing options...
Saheed Posted February 27, 2019 Share Posted February 27, 2019 Toyota Aqua 2013. Anyone knw the symbols? Check Engine Warning Master Waring Slip Indicator Warning Break Warning But Battery seems good. Quote Link to comment Share on other sites More sharing options...
Davy Posted February 27, 2019 Share Posted February 27, 2019 On 2/27/2019 at 7:06 PM, Saheed said: Toyota Aqua 2013. Anyone knw the symbols? Check Engine Warning Master Waring Slip Indicator Warning Break Warning But Battery seems good. Expand Why not get a diagnostic scan done (preferably at the agent)? That way you know what the actual error codes are. Quote Link to comment Share on other sites More sharing options...
iRage Posted February 28, 2019 Share Posted February 28, 2019 Well the error message says you Hybrid System needs a check and that you should park the car in a safe manner (to seek technical assistance). So in essence it is telling you to stop using the car as soon as possible and go get the Hybrid system checked. So like Davy said...go get it scanned. Quote Link to comment Share on other sites More sharing options...
Ahmed Naahidh Posted December 31, 2020 Share Posted December 31, 2020 On 12/23/2017 at 12:10 PM, Jbreak said: Guys, Any idea what this symbol is about? It’s in my friends 2015 Aqua Expand Quote Link to comment Share on other sites More sharing options...
