Hey folks, posting an update here after a long hiatus (three and half years).
The last update I've posted about a maintenance is the replacement of tires back in May 2021.  The new tires that went in that time have worn out to the level you just can't see any threads on them currently. Owing to the covid times and fuel crisis, the regular running of the car was little bit lower now and some of the non critical maintenance was also put on hold due to the economic crisis.
However, currently I have lined up to do those overdue maintenance at one go. Before updating those, I'll try to continue the repairs carried out until now from 2021 in order to maintain the continuation.
Here it goes.
12 replacing the Radiator Cap
The repair was carried out on 02-09-2022.
Mileage - 190,000kms
I exactly can't remember how I identified that the existing cap was leaking. I believe it was most probably during a routine service. The radiator cap comes as a whole unit, I bought it from Unit#d Mot#rs and had them installed it there also. Fairly a quick job.
Part No. 1350A043 - Rs.18,722/22
Labour Cost - Rs.1,250/-
Total cost with taxes - Rs.22,968/05
Edited by trinity
13 Replacing Brake Pads, Brake Shoes and Rear Brake Cylinders
The repair was carried out on July 2023.
Mileage - 206,000kms (Approx)
Previously I had changed the brake pads on September 2020. The mileage should be 155,000kms at at time. You can read about it here.
So after another 50,000kms, the front brake pads as well as the rear brake shoes were due for being replaced. Mind you, the rear brake shoes had lasted 206,000kms and 12 years. Last time, the the brake pads were replaced at the agent and the cost was comparatively low.
But this time, the prices had gone over the moon as the agent quoted something around Rs.75,000/- for the brake pads set and something around Rs.45,000/- for the rear brake shoes. And my brake cylinders were leaking for the third second time. I did not bother to ask them about the prices of those at that moment.
So I searched for substitutes. Fortunately our fellow member @Sampath Gunasekera told me that the OEM brand for the  genuine pads that comes for lancer is 'Akebono'. So I went ahead and bought a set from 'Srikanth Motors' at Panchikawatte. They didn't have the rear brake shoes with them from that brad though. So I had bought a shoe set Branded 'MK' (Japan) from Wimal Motors as per my records.
The prices were as follows,
Akebono Brake Pads - Part No D6108 / PN3469 Rs. 13,615/-
MK Brake shoes - Rs.17,500/-
The calliper seal kit also had to be replaced. Those were bought from the Unit#d Mot#rs.
Part No. 4605B982 - Rs. 19,304.34 (Rs. 9,652.17 per seal) total cost with taxes Rs. 21,089/99
Unfortunately, these were not it, I had to buy the brake cylinders as well. This time I bought two used ones that had been imported from Japan. Bought them from a gentleman called Chathoosha who sells Lancer parts on FB. Both cylinders cost me Rs.20,000/-
So the entire thing had cost me around Rs.78,000/- for parts, labour and phasing of rear drums.
Unfortunately, the rear cylinders did not last even a year. Will tell you guys about it later.
No photos available of these parts.
P.S found a photo of the seal kit.
Edited by trinity
14 Replacing the cabin AC blower motor
The timing of this could not have been worst. After spending nearly 80k for the brake replacement, the AC blower went out on the same month after about a week or two.
The replacement was carried out on 27-07-2023.
Had to settle for a Taiwanese made motor considering the cost factor. Price was Rs.18,250/-
This was the old motor.
And this is the only photo I have of the new one.
15 Replacement of the rear wheel bearing.
Replaced around August 2023.
By this time, I was running with a humming noise that emitted from the rear left wheel of the car. It was there for about two months and gradually started to increase. I knew it was the bearing but drove the car anyways given I had spent about Rs.100k for the aforementioned repairs.
Anyways, I managed to find a second hand bearing that had been removed from a car that had not run a much (Imported part). Bought it from Nethush who does Lancer Modifications and supplies spares specially for Lancer CY as well as CS models.
Price. Rs.17,000/- (If I remember correctly)
No photos.
16 Installation of the rear Spoiler.
September 2023,
Though its not a rear, thought to mention it here for records.
Found a brand new ABS Plastic GT spoiler for Rs.20,000/- from 'Dai Lanka Auto Traders' at Pepiliyana.
Cost me another 6,000/- to paint and instal it.
Total cost Rs.26,000/-
Here's a photo taken after few weeks of installation.
3 hours ago, trinity said:
Ha ha you are still here.. wait wait.. have many to update, very difficult to find a free time. I might be able to post few updates tonight.
Hope you still have the Lancer and she is doing fine.
Of course she's still with me, who else is she gonna be with ❤
15 minutes ago, trinity said:
Looking pristine as always 👍🏻
Wanted to switch to Liqui Moly synthetic 5W30 this time onwards but UNIMO refused to use oil sourced from a third party
Will make the switch from June (or when I hit 5K kms). For now she's still on Valvoline Conventional 10W30
Edited by Hyaenidae
Any particular reason for the switch? I’m still using Valvoline 10W30 conventional. Mileage is 229,000kms. Not that going synthetic crossed my mind. But I didn’t bother about it thereafter.
Because both cost about the same, Liqui Moly Molygen 5W30 costs about 14K from Daraz (sold by the authorized agent) with credit card discounts and daraz discounts, Valvoline conventional costs about 13K from UNIMO
  • 1 month later...
CY2 GLS (1500CC, 4A91) converted to a CY3 GT (1800CC, 4B10), Conventional auto transmission replaced with a CVT and all the bells and whistles transplanted, wonder why they didn't bother to update the CR though
CY = Lancer EX
2 = 4A91 1500CC Engine
A = Passenger car
S = 4 Door Sedan
R = 4A/T (Transmission)
M = GLS (Trim level)
H =MIVEC
R = RHD
Edited by Hyaenidae
  • 4 weeks later...
Stumbled across these photos from 2022 while tidying up my hard drive. Not sure I've already posted these somewhere else but thought I should leave these here for posterity
Guy who went to inspect a Lady driven second owner 2015 registered Lancer EX came across this:
The battery tray's all bent out of shape because the battery's too big.
Pretty sure the battery holders too are at an angle and grab onto the battery awkwardly. The battery not being properly secured caused an acid spill OR stress from its angled mounting led to a cracked battery housing, resulting in severe corrosion in the engine compartment.
Here's a comparison shot of my 2014 Lancer's engine bay in the same spot.
It seems the tray is designed to reduce potential metal-acid contact by containing and diverting accidental spills/leaks of battery acid.
Who would've thought that installing a slightly bigger battery could cause such a mess? :sad-smiley-067:
Edited by Hyaenidae
See..bigger is not always better.
This sadly is a common issue in SL. Seen quite a few cars with a similar fate. Due to lack of availability, maka baas advice, installing way too many accessories, etc...there are plenty of cars with large batteries in them. Which is fine, but sadly they are not mounted properly. So battery fluid gets out and over time starts corroding around the place.
Yeah should give a shout out to Amaron as well. The factory fitted Hitachi battery conked out after 5 years (2014-2019),  this Amaron has been going strong for 5.5 years (and counting).
Indians showing up Japanese for once, another "who would've thought!" 😁
Been there!  Here's a post I made when I swapped my battery back in 2019:
On 7/24/2019 at 10:56 AM, Hyaenidae said:
Thanks for the responses, everyone.
@K.o.N.o.S @Crosswind Couldn't find a battery shop which carries Yuasa or Global... Only choices  I have are Exide, Amaron, and Lucas.
Battery shop guys swear left and right that Amaron battery returns are practically zero and they've never had complaints of battery explosion, which is my biggest worry.
The  Exide 65Ah battery could be fitted by removing the battery tray (suggested by the battery shop) which I don't think is a good idea. The purpose of the tray I think is to prevent possible fluid spills reaching the metal parts of the engine bay, the battery could be fitted with the battery holder without the tray in place. Not going to do it anyway.
Edited by Hyaenidae
  • 3 weeks later...
I have no clue what happened, but a while ago when vacuuming the interior I found out that 2 of the 4 plastic rear seat anchor covers were just hanging there like loose tooth. Someone had snapped the clip that secures it to the seat.
My guess is it was probably the shop that put on my seat covers or some place I got my interior cleaned from.
The clip should be pinched before pulling it off, but someone just ripped it out 😶
Luckily replacement trim bits are quite cheap, even the original costs something like $5 apiece but the shipping cost from Japan is too high so gave up on Japanese and went with Chinese
There it goes, nice and snug again. Total cost around $10 for both pieces
Heyyyy.. I’m also having the same issue. Could you please share the link of the site you’ve bought these from. Need to order two for my car as well. Hope they have the beige color parts also.
Didn't see beige color trim pieces in his store but maybe you could send a message to the seller to see if he has them?
Here are the links for parts I replaced :
COVER,FRONT SEAT ANCHOR LH REAR-L https://a.aliexpress.com/_oDTQcOe
COVER,FRONT SEAT ANCHOR RH REAR-R https://a.aliexpress.com/_oEwIHts
If he doesn't sell the parts in beige you could replace all floor anchor trim pieces with black ones :
COVER #2,FRONT SEAT ANCHOR RH REAR-L https://a.aliexpress.com/_ooBvjei
COVER #2,FRONT SEAT ANCHOR LH REAR-R https://a.aliexpress.com/_oBLieB0
Front Cover set:
COVER,FRONT SEAT ANCHOR RH-L https://a.aliexpress.com/_oBgkgXC
COVER,FRONT SEAT ANCHOR LH FRONT-R https://a.aliexpress.com/_oFZSkDy
COVER #2,FRONT SEAT ANCHOR LH FRONT-L https://a.aliexpress.com/_ooUBtgA
 COVER #2,FRONT SEAT ANCHOR RH-R https://a.aliexpress.com/_oDuoYu6
I see the free shipping option is no longer offered, but if you order multiple trim pieces in one order the shipping cost will be significantly reduced per trim piece. The paid shipping option (Aliexpress Standard Shipping) will deliver the items within 2 weeks compared to 1-2 month delivery time of the free shipping option (Cainiao Super Economy)
Make sure to order through the mobile app and not the browser - prices are sometimes inflated when ordering through the browser, no idea why.
Here are the OEM part numbers for above trim pieces:
Swap out "X" with "Y" for beige.
Edited by Hyaenidae
  • 3 months later...
Replaced the battery after 6 years of maintenance-free service. The plates inside were shattered and swimming in the electrolyte, when connected to a battery analyzer it read 189 CCA (New battery read 590 despite the label saying 320), had a SOH of 14% when I swapped it - despite the readings, it still managed to start the car with no complaints. Impressive performance for a battery made in India.
10/10 recommend, would buy again.
Part # : Amaron ESL-GO-0BH55D23L
Total cost :
30,400LKR exclusive of used battery trade in. 27,000LKR If the old battery is returned.
Back in 2019 the cost was 16,000 LKR with the trade in of the old battery.
Installed it myself because why not :P
  • 2 months later...
7 hours ago, Hyaenidae said:
Apparently the 1.5L Lancer engine runs quite happily with honey as a substitute for engine oil. Who knew?
Since honey never expires and goes bad...does that mean owners can fill it up with honey once and that will be it for eternity ?
Do you think kithul honey will work just as well ? Bee honey can get a bit pricey.
  • Haha 1
Engine oil doesn’t go bad on its own too ne it’s the combustion byproducts + fuel dilution + moisture and other contaminants that cause engine oil to "go bad" when used in an engine
I reckon the same would happen to honey as well :action-smiley-060:
...And no, you shouldn't substitute bee honey with Kithul honey. It's a Mitsubishi engine, it deserves premium stuff :D
Edited by Hyaenidae
Green
  • Haha 1
