June 11, 20206 yr 36 minutes ago, trinity said: Guys, Im thinking of lowering the car a bit as those hideous gap in the wheel well is a sore in the eye to me... Suggestions are welcome. @E L N I N Oย is the guy with the experience... wonder if he is still around Granted that lowering and upgrading the wheels would massively improve the looks but are you sure you don't want the extra ground clearance?
June 11, 20206 yr 14 hours ago, Hyaenidae said: That's quite a lot of gunk right there... did they flush your brake fluid too? ย I too was surprised to see that much junk. Yeap they flushed the fluid. Total cost 8k. Further there were some signs of inner wear in the brake cylinder. So they suggested to replace bothย cylinders. I didnโt go with that because of the cost. (17k per cylinder) maybe I will wait until the next service to check if the repair was indeed a success.
June 11, 20206 yr 12 hours ago, trinity said: Guys, Im thinking of lowering the car a bit as those hideous gap in the wheel well is a sore in the eye to me... Suggestions are welcome. Ha ha you are welcome to the Lowlife club..?. Are you planning to do this with coilovers or just by lowering springs?
June 11, 20206 yr 35 minutes ago, K.o.N.o.S said: I too was surprised to see that much junk. Yeap they flushed the fluid. Total cost 8k. Further there were some signs of inner wear in the brake cylinder. So they suggested to replace bothย cylinders. I didnโt go with that because of the cost. (17k per cylinder) maybe I will wait until the next service to check if the repair was indeed a success. 17k? WTH? You could get a Brembo brake cylinder from eBay for 5k! https://www.ebay.com/itm/BREMBO-Wheel-Brake-Cylinder-A-12-397/162695050515 https://www.bremboparts.com/asiapacific/en/catalogue/hydraulic/A_12_397 https://mega.nz/file/m41mWCjD#Pjmznpe42xUPT32wOi8tgxv0X_2G80TML6sj7eN8k1s Edited June 11, 20206 yr by Hyaenidae
June 26, 20206 yr @trinityย @K.o.N.o.Sย @Davyย Guys, I'm going to get my coolant changed for the first time since I bought the car. When you got your coolant replaced, did they use a vacuum suction tool to refill coolant? The workshop manual recommends using one, apparently to ensure there are no air bubbles trapped in the system when refilling the coolant. Do you guys think it is mandatory to use this "LLC Changer" or just a simple refilling would be enough? ย Edited June 26, 20206 yr by Hyaenidae
June 26, 20206 yr 3 hours ago, Hyaenidae said: @trinityย @K.o.N.o.Sย @Davyย Guys, I'm going to get my coolant changed for the first time since I bought the car. When you got your coolant replaced, did they use a vacuum suction tool to refill coolant? The workshop manual recommends using one, apparently to ensure there are no air bubbles trapped in the system when refilling the coolant. Do you guys think it is mandatory to use this "LLC Changer" or just a simple refilling would be enough? ย I assume you are going to get it done at the agents?ย I do not think it is necessary to use a LLC changer. Anyway I am yet to change coolant and I thought this is something which weย can DIY at home.
June 27, 20206 yr 9 hours ago, Hyaenidae said: @trinityย @K.o.N.o.Sย @Davyย Guys, I'm going to get my coolant changed for the first time since I bought the car. When you got your coolant replaced, did they use a vacuum suction tool to refill coolant? The workshop manual recommends using one, apparently to ensure there are no air bubbles trapped in the system when refilling the coolant. Do you guys think it is mandatory to use this "LLC Changer" or just a simple refilling would be enough? ย I did it myself at home. So I didn't use any special tool. Just followed the conventional method of replacing coolant. To bleed out air from the system, the engine was started with the radiator cap off and heater on for about 15 minutes until the thermostat opened up. This causes air bubbles to be pushed through the system and out the radiator filler port. The tool suggested in the manual makes it quick and easy because you don't have to run the engine and just wait until the car does all the bleeding. But it is not mandatory to use it.ย
June 27, 20206 yr 8 hours ago, K.o.N.o.S said: I assume you are going to get it done at the agents?ย I do not think it is necessary to use a LLC changer. Anyway I am yet to change coolant and I thought this is something which weย can DIY at home. ย 2 hours ago, Davy said: I did it myself at home. So I didn't use any special tool. Just followed the conventional method of replacing coolant. To bleed out air from the system, the engine was started with the radiator cap off and heater on for about 15 minutes until the thermostat opened up. This causes air bubbles to be pushed through the system and out the radiator filler port. The tool suggested in the manual makes it quick and easy because you don't have to run the engine and just wait until the car does all the bleeding. But it is not mandatory to use it.ย Thanks guys @K.o.N.o.Sย Please post a DIY thread or post an update here when you do it @Davyย If air bubbles push through the system to the top of the radiator won't those get out through the expansion tank ?ย
June 27, 20206 yr Author 14 hours ago, Hyaenidae said: @trinityย @K.o.N.o.Sย @Davyย Guys, I'm going to get my coolant changed for the first time since I bought the car. When you got your coolant replaced, did they use a vacuum suction tool to refill coolant? The workshop manual recommends using one, apparently to ensure there are no air bubbles trapped in the system when refilling the coolant. Do you guys think it is mandatory to use this "LLC Changer" or just a simple refilling would be enough? ย Mine was done as Davy mentioned. I didnโt ย go to the agent for it though. Got it done at the local service station. No issue at all.ย
June 27, 20206 yr Author On 6/11/2020 at 10:02 PM, K.o.N.o.S said: Ha ha you are welcome to the Lowlife club..?. Are you planning to do this with coilovers or just by lowering springs? Sorry could not reply earlier. Never had time. After carefully considering the pros and cons, I gave up the idea. Also, Iโm nearing the tire replacement which will put a hole in my pocket. Canโt spare money for anything else.ย Ima need to find a spoiler though.ย
June 27, 20206 yr 2 hours ago, Hyaenidae said: @Davyย If air bubbles push through the system to the top of the radiator won't those get out through the expansion tank ?ย Depending on the pressure rating of the radiator cap, coolant (and air) will push it's way out through to the expansion tank eventually. However, this doesn't happen as easily as when the radiator cap is open. By the time the radiator cap's pressure relief valve is ready to open, the coolant is under highย pressure, and it's boiling point has rised above the value at normal atmospheric pressure. So there could be very hot air bubbles still in the system that are unable to escape for quite some time. If the air bubbles are deep within the engine, it can cause hot spots and even damage the block. So it's best to do it it beforehand.ย
June 27, 20206 yr 21 minutes ago, trinity said: Sorry could not reply earlier. Never had time. After carefully considering the pros and cons, I gave up the idea. Also, Iโm nearing the tire replacement which will put a hole in my pocket. Canโt spare money for anything else.ย Ima need to find a spoiler though.ย Aw come on!ย โน๏ธ ย
June 27, 20206 yr 45 minutes ago, trinity said: ย Ima need to find a spoiler though.ย These guys should be able to get one down if they already don't have those in stock http://rainbowpen.lk/product-category/mitsubishi/lancer-ex/ https://www.facebook.com/rainbowPen.lk Edited June 27, 20206 yr by Hyaenidae
June 27, 20206 yr 6 minutes ago, Davy said: Depending on the pressure rating of the radiator cap, coolant (and air) will push it's way out through to the expansion tank eventually. However, this doesn't happen as easily as when the radiator cap is open. By the time the radiator cap's pressure relief valve is ready to open, the coolant is under highย pressure, and it's boiling point has rised above the value at normal atmospheric pressure. So there could be very hot air bubbles still in the system that are unable to escape for quite some time. If the air bubbles are deep within the engine, it can cause hot spots and even damage the block. So it's best to do it it beforehand.ย Ah, that makes sense. The only reason I'm changing coolant is it's past the 5 year mark, the coolant itself and everything looks great with no discoloration or residue-forming... would it be enough if I only get the radiator and expansion tank drained and refilled without draining the engine block and doing a full flush? That way I won't get air bubbles inside the engine block, right?
June 27, 20206 yr 1 hour ago, Hyaenidae said: Ah, that makes sense. The only reason I'm changing coolant is it's past the 5 year mark, the coolant itself and everything looks great with no discoloration or residue-forming... would it be enough if I only get the radiator and expansion tank drained and refilled without draining the engine block and doing a full flush? That way I won't get air bubbles inside the engine block, right? When the radiator is drained, coolant from the engine block will flow into the radiator under gravity anyway. Although your coolant looks good to the eye, over time, coolant loses its pH level and turns slightly acidic and loses its rust prevention properties as well. There are coolant test strips (basically a pH test against a given scale) which is probably an option for you if you want to make sure.ย My advice is to get a regular coolant change (not just the expansion tank) done if you're doing it. Don't worry, if you keep the engine running as explained above, air bubbles will be bled out of the system. If you are concerned, just keep an eye on the temperature gauge for a couple of days. ?
June 27, 20206 yr 2 hours ago, Davy said: There are coolant test strips (basically a pH test against a given scale) which is probably an option for you if you want to make sure.ย ย I did the multimeterย test last week, it didn't exceed 0.09V when engine is not running and 0.1V when the engine is running... they say coolant is good to go as long as it doesn't exceed 0.3-0.4V so based on that I'm guessing that the coolant haven't turned acidic and isn't conducting electricity in harmful levels... but I'll get the engine block drained too in any case, in for a penny in for a pound rite
June 27, 20206 yr 5 minutes ago, K.o.N.o.S said: It is time to do some brainwashing.? Don't tell me you haven't wished for more ground clearance at least once by nowย ?
June 27, 20206 yr Author 6 hours ago, Hyaenidae said: These guys should be able to get one down if they already don't have those in stock http://rainbowpen.lk/product-category/mitsubishi/lancer-ex/ https://www.facebook.com/rainbowPen.lk Man you are like a web genie. ?
June 27, 20206 yr Author 6 hours ago, Davy said: Aw come on!ย โน๏ธ ย Ha ha if only I had a fried close by to help to go through with it.. ha haย 2 hours ago, K.o.N.o.S said: It is time to do some brainwashing.? Hmmm I see, thing is sometime car scrapes even with this height.. I wonder how a lowered one would fare ?
June 27, 20206 yr 2 hours ago, K.o.N.o.S said: It is time to do some brainwashing.? Okay let's see if this works... Convinced yet @trinity? ย Also this is why you need the high spoiler as well. ย ย
June 27, 20206 yr Author 13 minutes ago, Davy said: Okay let's see if this works... Convinced yet @trinity? ย Also this is why you need the high spoiler as well. ย ย Hamme yako.. ?????? she is a stunner isnโt it? Agreed on the high spoiler. Gonna need your bumpers and side skirts as well.. not to mention the wheels..ย
June 27, 20206 yr On 6/27/2020 at 6:21 PM, Davy said: Okay let's see if this works... ย t's like playing NFS MW backย in the day... 2nd pic is buying an entry level car at the start of the game and 1st pic is the car after many visits to the tuning shop, ready to face Razor in his ill-gotten BMW ย Edited May 27, 20224 yr by Hyaenidae
June 27, 20206 yr 3 hours ago, Davy said: Okay let's see if this works... Convinced yet @trinity? ย Also this is why you need the high spoiler as well. ย ย I am also contributing..
June 28, 20206 yr 11 hours ago, Hyaenidae said: ย ย That shine! ?ย Did the chrome side mirror covers come with the car? I doubt they did.ย 8 hours ago, K.o.N.o.S said: Ooh I had forgotten that yours had an Evo spoiler! Love how the wheels fill those arches - just the right amount of low. ? I just noticed that the body coloured moulding that goes across the middle of the doors are missing in mine. Searched local classifieds and found out that none of the cars here have it.ย By the way @Hyaenidae, here's a DIY thread for you if you want to attempt it yourself. Note that a flushing liquid is used here, but you can skip that step. I'm sure you can pull it off. I have lost count of the number of times I've done coolant changes myself - it's that easy.ย Edited June 28, 20206 yr by Davy Added DIY thread link.
