Lol shanx some of my nearest and dearest friends/family have actually tried to sabotage project R for the same reasons!!
Well they aren't your nearest or dearest if they're sabotaging your work...Do they have a valid excuse atleast? You're not spending beyond your means or neglecting family obligations cos of this car are you?
Anyways,as long as your wife and parents are ok with it tell the rest they can f**k off...
i have, bro. i have. its really hard to let go of some people but when you know they are your own undoing, its time to cut the moorings
MD, Rossi rides for Yamaha now :) (just noticed your signature)
Yeah didn't get the time to update it.Will do so when I get a moment...you a motogp fan?Don't get many of those around here...
Anything on wheels man :) I would be a fan of motored unicycle racing if such a thing existed!
just had a vision of bears wearing tutus doing that in my head. i think i need help :speechless-smiley-004:
You watched Madagascar 3, didn't you? :P
God that was the funniest sequel ever! The change in Morts and Maurice's expressions when king Julian went down with the truck... And then came up again! Absolutely priceless!!
King Julien (Sacha Baron Cohen) is the biggest reason I watched Madagascar 2 & 3!
Remember the "whistling as a career" bit?! :sport-smiley-004: :sport-smiley-004: :sport-smiley-004:
so kelum is back after being AWOL for 3 days. i was a bit upset, but then seeing this when i went today, couldn't voice a word of protest!
there goes the simota intake and piping. more on kelum, apparently his sister was a navy officer shot in trinco camp due to some mishap. its been an year so the daane bana etc. i heard about this from my friends at trinco hospital. she succumbed to her injuries there. small worls, sri lanka definitely is.
also mounted the engine mounts under the car, those were broken, so replaced.
the new radiator doesn't have screws for the auxiliary fan. need to fabricate those and stick it in
there is is! only the dizzie left to be mounted. the clutch reservoir has its own screws also. its like EVERYTHING in this car was made for a manual gearbox. uncanny!
more happening tomorrow. we'll be fabricating a bracket for the intake piping as well. ignition is not so far away now!
The Blue pipes are really good looking. at first sight i thought it is a photoshop image :speechless-smiley-004:
now THAT's a compliment!! yeah i know they look awesome! its the white engine bay that brings the colours out. my mechanic was not convinced with the color selection then. he is now!
today i come to learn that there is a ceiling on how much work gets done no matter how long i stay there and be a byte. this really is a meditation.
anyhow, the radiator was argon welded and went back in. its HUGE, and we had to trim the fan shroud a little to make it fit. no space to put the header guard tho.
and then clipped all the hoses, and installed the reservoir tank. so that's that.
oh yeah, the belts are all in place too.
now all that's left is to find a place for the blaster coil, and plug in the dizzie. its all done. hopefully finishing that on monday and going into paint. GOD this is taking FOREVER!!
cant seem to understand why your painter has painted the bonnet lock. Hope ul clean it out soon. Otherwise nice job.
drawing that much nearer to completion. fixed the coil in place neatly with a bracket:
also bolted the intake pipe onto the engine. that mount took a better part of the day to fabricate. frustrating, yes, but i'd rather all this be done neatly, and with attention to detail. and this is one example of kelum's devotion to that very quality:
and then all the little hoses and vacuum lines were connected.
and that, gentlemen, is it! tomorrow we wire up the distributor, connect the accelerator cable, fill up the oils and water, fire her up and see what gives! after so long, the wait is over. clearly, i'm losing sleep over it! hooray!!
Yeah I was thinking about that. But I guess that needs the Fiber guy. And at the mo, I'd rather concentrate in finishing this. A cold air box might just work tho, given where the intake is...
Fiber? Won't that end up being heavy? Anyways, I ended up watching
as I was googling for Acura Intregra cold air box kits and heat shields. So you're probably right: The change would be negligible when taking into consideration the need to get the car out where it belongs. Having a car sidelined for months-on-end certainly does suck... Edited by Kavvz
