sira Posted November 10, 2015 Posted November 10, 2015 Dear Friends I'm planing to replace my EK3 head light bulbs with HID or LED. can you all let me know what is the best HID kits and Price of them I checked the Philips got good stuff and looks they are expensive - http://www.ebay.com.au/itm/Genuine-PHILIPS-H4-Hi-Lo-Beam-6000K-HID-CANBUS-Conversion-Kit-/262081036086 Also now LED Head lights are available. how about them ? are they more efficient then HID Please advice Sira Quote
0 terrabytetango Posted November 15, 2015 Posted November 15, 2015 (edited) HIDs have no filament. There's an arc of electricity flowing between two electrodes, which illuminates the gas inside the bulb, a la standard "tube light" style. You can't change the shape of an arc, so the light dispersion pattern is changed by a solenoid operating a metal cover that blocks a portion of the light. It is because the light is in an arc, rather than a straight filament, that HIDs are incompatible with Halogen reflectors. Edited November 15, 2015 by terrabytetango Quote
0 Magnum Posted November 15, 2015 Posted November 15, 2015 I have tried those bi-xenon H4 HID, wasnt great! Like terrabytetango mentioned HID doesn't have filament. When you switch on the high beam the bulb just moves upwards pointing the light at the distance which leaves out the road close to the vehicle dark. and of course it doesnt focus the light properly, it sends the light upwards and towards the sides reducing the amount of light focused on the road. Quote
0 The Stig Posted November 16, 2015 Posted November 16, 2015 HIDs have no filament. There's an arc of electricity flowing between two electrodes, which illuminates the gas inside the bulb, a la standard "tube light" style. You can't change the shape of an arc, so the light dispersion pattern is changed by a solenoid operating a metal cover that blocks a portion of the light. It is because the light is in an arc, rather than a straight filament, that HIDs are incompatible with Halogen reflectors. My bad, i meant arcs I have tried those bi-xenon H4 HID, wasnt great! Like terrabytetango mentioned HID doesn't have filament. When you switch on the high beam the bulb just moves upwards pointing the light at the distance which leaves out the road close to the vehicle dark. and of course it doesnt focus the light properly, it sends the light upwards and towards the sides reducing the amount of light focused on the road. There are dual arc variants, but most common is the shield moving type you are referring to (FYI bulb doesnt move, the shielding does). Quote
0 Magnum Posted November 16, 2015 Posted November 16, 2015 My bad, i meant arcsThere are dual arc variants, but most common is the shield moving type you are referring to (FYI bulb doesnt move, the shielding does). I assume those dual arc ones are expensive Quote
0 Schiffer Posted November 18, 2015 Posted November 18, 2015 So my father was complaning with the Narva 100/90w bulbs its hard to drive in the rain at night, which is the case these days. i didnt wanted to switch back to 100/90W bulbs too So decided to go for a set of 60/55w Koito Whitebeams. Koito's Equalant to the Osram Nightbreakers, and they are really good * Note the pictures doenst do much justice to the actual color temp.. Also: even though it seems theres a difference in color temp when comparing.. you will not notice any difference once both are installed. 3 Quote
0 Schiffer Posted November 18, 2015 Posted November 18, 2015 That does look quite good! They are indeed Quote
0 whmsujith Posted November 19, 2015 Posted November 19, 2015 They are indeed Machan, where did you buy those from? Ebay? Quote
0 Schiffer Posted November 19, 2015 Posted November 19, 2015 Machan, where did you buy those from? Ebay? From a shop in kandy, ive seen these in panchikwatta shops too Quote
0 amilaart Posted November 19, 2015 Posted November 19, 2015 Hi How I identify correct type of Light which match my car Thanks Amila Quote
0 whmsujith Posted November 20, 2015 Posted November 20, 2015 HiHow I identify correct type of Light which match my car Thanks Amila Pls take a sample bulb when you go to shop. From a shop in kandy, ive seen these in panchikwatta shops too Thanks Schiffer. Quote
0 amilaart Posted November 21, 2015 Posted November 21, 2015 Thanks whmsujith If I need to order from Ebay ? Quote
0 fiat fan Posted November 21, 2015 Posted November 21, 2015 From a shop in kandy, ive seen these in panchikwatta shops too Mchn the name of the shop? And the price? if you dont mind..thanx Quote
0 Schiffer Posted November 21, 2015 Posted November 21, 2015 Mchn the name of the shop? And the price? if you dont mind..thanx Bought if from a shop called Janatha Motors in kandy. it was 2200/= for both bulbs Quote
0 asrock Posted November 21, 2015 Posted November 21, 2015 Thanks whmsujith If I need to order from Ebay ? The type of the bulb is probably written on the connector, else you can identify it by the shape and size of the bulb, but its little bit difficult because some bulb type may appear very similar. Alternately you can let us know your car model, maybe some member could help you out. Some common bulb types 2 Quote
0 The Stig Posted November 21, 2015 Posted November 21, 2015 HiHow I identify correct type of Light which match my car Thanks Amila Its written on top of the headlight most of the time Quote
0 Magnum Posted November 21, 2015 Posted November 21, 2015 The type of the bulb is probably written on the connector, else you can identify it by the shape and size of the bulb, but its little bit difficult because some bulb type may appear very similar. Alternately you can let us know your car model, maybe some member could help you out.Some common bulb types Its written on top of the headlight most of the time Sometimes you can see the writing from outside through the headlight housing 1 Quote
0 LashNeo Posted November 27, 2015 Posted November 27, 2015 Bought if from a shop called Janatha Motors in kandy. it was 2200/= for both bulbs Got myself a pair of Koito white beams from delkanda for the same price. Extremely happy with the results. Not too much or too little but just the right amount of light to see the road without agitating oncoming traffic. I'd say bang for the buck. Thanks for sharing the details Schiffer. :-) Quote
0 Schiffer Posted November 27, 2015 Posted November 27, 2015 Got myself a pair of Koito white beams from delkanda for the same price. Extremely happy with the results. Not too much or too little but just the right amount of light to see the road without agitating oncoming traffic. I'd say bang for the buck. Thanks for sharing the details Schiffer. :-) Nice, Glad i could help buddy Quote
0 amilaart Posted December 3, 2015 Posted December 3, 2015 The type of the bulb is probably written on the connector, else you can identify it by the shape and size of the bulb, but its little bit difficult because some bulb type may appear very similar. Alternately you can let us know your car model, maybe some member could help you out.Some common bulb types Its written on top of the headlight most of the time Sometimes you can see the writing from outside through the headlight housing Thank you very much for the suggestions I have Lancer CS3 , very recently brought ( only 10 days), As Asroc mention I notice that bulb connector has bulb type embose. My one head light is H4 90/100W but left side light does can not have similar name on bulb connector. Some time bulbs may be different. Even two bulbs have different intensity, Right one which has this H4 90/100 is more brighter than Left side light. Is H4 90/100 is the correct bulb for Lancer CS3 ? If I need change this to Osram Night break do i need to match same watt capacity thanks Amila Quote
0 NRX Posted December 4, 2015 Posted December 4, 2015 Thank you very much for the suggestionsI have Lancer CS3 , very recently brought ( only 10 days), As Asroc mention I notice that bulb connector has bulb type embose. My one head light is H4 90/100W but left side light does can not have similar name on bulb connector. Some time bulbs may be different. Even two bulbs have different intensity, Right one which has this H4 90/100 is more brighter than Left side light. Is H4 90/100 is the correct bulb for Lancer CS3 ? If I need change this to Osram Night break do i need to match same watt capacity thanks Amila It's fairly certain that the previous owner has changed the original bulbs from 55/60W to 90/100W bulbs(bulb). I wonder if the previous owner was an idiot to use the 2 bulbs with different wattages. Get and fix a pair of Osram Night Breaker Unlimited H4 55/60W (If Osram rocks your boat). You can order them from eBay. It usually takes 5 to 15 days to arrive from UK based sellers. I have bought Osrams from these UK sellers http://www.ebay.com/usr/driven2automotive http://www.ebay.com/usr/upgradebulbs Quote
0 asrock Posted December 4, 2015 Posted December 4, 2015 Recently got my Night Breaker HB3 for the high beams, very satisfied with it. 1 Quote
0 terrabytetango Posted December 4, 2015 Posted December 4, 2015 A friend of mine bought a set of Nightbreakers having seen my posts about them here, and was concerned with the colour of the light because it wasn't white like HID or LED. So I'll clear up any doubts about Osrams or Phillips, or any other high end halogen bulbs; they will never provide the colour of HID or LED bulbs. They are simply brighter, have more consistent light spread and will generally maintain at least 80% of their brightness during their life time. The Osram Nightbreakers have an "unofficial" colour temperature of 3900K, which is the closest to white they can do. Quote
0 Magnum Posted December 4, 2015 Posted December 4, 2015 Yes Nightbreakers have a different color, they arent yellow as standard halogen and not white as HID Standard halogen and HID Nightbreaker and HID 1 Quote
0 Twin Turbo Posted December 18, 2015 Posted December 18, 2015 (edited) I've read about drivers getting stopped by our cops who rigged up their own laws when it comes to legal compliance of lighting to the point where cars with factory fitted HID head lights were taken to court. so don't ask for trouble, . unless you've got a good lawyer! When it comes to aftermarket HID kits,reliability is a major issue,.. Sure they look cool , but you want them to work at night when you drive home after a'few too many ! LED's produce comparatively less light - although they have advantages over their HID counter parts. bottom line,.. Reliability above all,.. Edited December 18, 2015 by Twin Turbo 1 Quote
sira
Dear Friends
Please advice
Sira
Top Posters For This Question
10
7
6
6
Popular Days
Nov 11
14
Nov 21
6
Mar 29
6
Nov 13
5
Magnum 10 posts
The Stig 7 posts
terrabytetango 6 posts
sathyajithj99 6 posts
Popular Days
Nov 11 2015
Nov 21 2015
Mar 29 2016
Nov 13 2015
Popular Posts
The Stig
Erm nope, thats not the reason. HIDs also come with dual filament versions called Bi-xenon. They work the same way as any H4 bulb would. The reason HIDs scatter light is because the length of the HID
Schiffer
The Stig
For the 100 millionth time do not fix hid's on a reflector housing. You will be blinding everyone ahead and don't be surprised when people start reacting to it. Just use a good pair of halogens. I
67 answers to this question
