Honda Civic 2018
4 hours ago, randika171 said:
Thank you! Oil cap says ACEA C2 which matches with the Mobil 1 ESP so should be good. Did full service, changed all fluids, wheel alignment, interior clean and 12v battery test at the Hub. The battery apparently has 98% health but auto start stop is not working. Not needed anyway.ย
I do hear a small hissing noise and a small fan noise at some times when the a/c is working but noticed the hissing noise goes away with some time. The fan noise is constant (very light but there). I keep the temp at 25 degrees and it seems sufficient. Wondering if I should get it checked.
Btw, I took it to company for a checkup and asked about the oil. They still recommend semi synthetic for some reason and keep telling me how so many civics come to get service done here and they put that oil to everything. I'm gonna stay away from them lol
If itโ€™s a hiss that goes off quickly, thatโ€™s fine for now. May need a charge later though. But also if your spec says r1234yf, itโ€™s best to find out from the previous owner whether it was converted to r134a. Do not mix refrigerant.
On oils: The agent can frankly shove their semi synthetic oils up their exhaust pipes! ๐Ÿ˜€ Follow the book and maintenance minder always.
  • 4 weeks later...
  • Replies 874
  • Views 358.4k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Insedious
    Insedious
    Hi Guys, Having being an avid reader of the AL forum for years, I thought I'd create an account and contribute as I got a 2018 Civic SR for the wifey a couple of weeks back. (Edit: Looks like I h
  • It's been about 3 weeks since I received my 2018 Civic EX (Tech package) from the UK. Paid a bit of a premium for it at 7mn total, however I was keen on the Tech Pack upgrade as I detested the standar
  • Now I've heard it all... a Honda with an insect fetish. This proves your car is a female though. No male car would ever be able to have a second full-blown orgasm within 5 minutes of the first on
Posted Images
Hi, it looks like the Civic Forum is one of the most active among the Hondas in Autolanka. trying to gather some help on a repair of a vezel. the latest post on anything to do with Vezel is from mid-2023.
The 2018 RS vezel returned from Std Motors after regular service yesterday with a list of repairs recommended, including rear hub racer,ย  front brake pads, calipers, brake pistons, air filter, cabin filter etc estimated to be over 200k. (Brake pads alone are 62k)ย
Please let me know if any other places are known to handle Vezel repairs well in and around Colombo.
are you aware if the gas was changed at some point? The car comes with r1234 by default - but it has lower volumetric cooling capacity and causes premature condensor wear. Most have been converted to r134a : but the r1234 needs to be completely removed. Mixing is not the best idea.ย
There is a place in Yakkala managed by an ex-stafrd employee. @Dee Jayย has a vezel RS and might be able to provide more insights.ย
You will be able to change the brake pads at a lower cost if you go with a good quality Japanese brake pads. I also had to do the brake job not all 4 but it cost me 90k at Stafford.
Like @matroska mentioned you'll be able to get the job done at a lower cost from the guys in Yakkala and they are well experienced with the Vezel.. Apart from that there's another place around Arawwala area too run by a Stafford guy..
Guys as myย  civic has approached the 6 year mark and not planning on selling it soon I am thinking of changing the timing belt as per the user manual. I've never serviced at Stafford ,and the garage which has maintained my car has taken good care of it so far.ย
Anyway they quoted 88k for timing belt and balance shaft belt and additional costs for labour.ย
Anyone got this done yet ?
Did you recently ask the same question on a facebook group as well? I remember seeing this.ย
Not me.ย
Ok folks, I was driving around at night and got an oil level warning; found that it was right at the lower marker on the dipstick. Also saw some oil spots in the garage.. I hardly see the floor there as the car is always parked on it. Whatโ€™s worse is that I saw traces of a rat defiling my engine bay once I popped the hood. It had left a lot of droppings and some ball-shaped (pretty big ones!) stuffโ€ฆ guessing it was the ratโ€™s protein balls to keep itself buff.
So I eventually decided to get the oil leak fixed at the agent and let them deal with the cleanup job. Didnโ€™t want anyone else playing with the engine and gearbox.ย Theyโ€™ve also flushed out all the oil and cleaned out the turbo lines. New seals and tappet cover were fixed too. Wheel alignment was included as well. All inclusive charge was 155k including 0w20 oil. Not too bad.
The car drives nicely especially after the realignment. Hope thatโ€™s the end of the oil worries now. As for Mr. Ratty, I need to get some repellent spray. Used to get it off Gr***e M****y before, but theyโ€™re now an online scam portal so thatโ€™s out. Know a place that stocks this stuff?ย
ohh.. the Rats.. i think you better take drastic measures to get rid of 'em rather than Spray them off.. tried, failed!.. so end up placing poison for once and for all.. (I know it's bad but can't help).. to get the Marder spray there are bunch of places which I'm using and these folks do deliver (Courier) as well.. will inbox the places..
Edited by Ruslan
I am on the look out too for some too ! Couldn't find it in most of the usual shops. Even the decent online portals tht used to have it now don't. Had some of the old Pesto spray used that as a temporary measure.
Yes...the repellants are merely a deterrent. I have those sticky pads put all around the parking area. Using poson can be a bit tricky. In the past what happened to me (well my dad) was the cleaner dude at home put rat poison. The rat ate the poson and then went and died in the car. Two of them ! One was under the passenger seat. The other...in the engine may under the manifold cover. Did not see it until the cover was removed to fix some engine issue. By that time the rat was a big black stain embedded in the metal.
My neighbors have not one but six cats, and one of them sleeps under the Civic. I've come to peace with the occasional muddy paw-printย  considering the rat-repellent effect it has.ย
Considering the Agent's costs this is not bad at all.ย
My neighborโ€™s cat happens to sleep on the roof of my car. Paw prints everywhere and an occasional pee stain, however it looks like it has made friends with the rat; theyโ€™re bunk buddies! Either that or the rat chased the cat away!
For the rat problem - The safe way is to use those rat cages, you can buy around 2 or 3 and keep a piece of coconut so they get trapped and can release somewhere else. However, the best is to use rat poison because they breed so fast. We too had a rat problem and poison was the only way to get rid of the whole lot.
For the cat sleeping on the car - Car cover works, but huge hassle to put it on and off. Moth balls crushed and mixed with water and sprayed around helps but again temporary solutions. What eventually worked for me was I made the cat a small bed. I learnt from a cat expert that you need to distract the cat and give it something else to do because scolding doesn't work all the time. Cats love heat and that's why they keep going on the car. So if you can make a small bed with soft wool carpets it will stay there all the time. Mine is on the new bed 90% of the time and never goes on the car now.
Do not poison the rat ! They eat the poison, run inside the car and die. Naturally it would decide to die in some hidden place like behind the dashboard or some little space in the engine compartment.
Yes cages work. So do the sticky pads that make the rat stuck on to the board. Vegetable oil can be used to remove the rat and set it loose.
I use car covers in Japan. I got the plushy kind to prevent cat scratches. The fluffy nature of it made the cat actually use it for scratching. So it can go either way. Alternatively, I followed what my neighbors started doing...placing large water bottles around the car (more or less places the car will use to climb on to the car). Apparently the magnified visibility through the bottle confusses them. A second approach is to stick strong-smelling things like crushed incense (and even some types of flowers)ย around the car (or on the car cover). Cats do not like it.ย ย
Also, if using a car cover you need to be diligent about when to put it off and put in on. Also you would need to get a good quality car cover (i.e. not the cheap shiny chinese ones that build moisture and bake the car).
  • 3 weeks later...
On 8/9/2023 at 1:14 PM, tinyman said:
Guys sad news, my left side mirror lens got stolen last night near Wellawathe Foodcity.ย
Don't know how much it's going to cost, Any ideas?.
Insurance needs a police entry it seems.ย ย
Same thing happened to me. Looks like the whole lens movement assembly was taken too. Just outside the General Hospital near the Cardiac section. Insurance assessor said itโ€™ll be 40k, but I guess itโ€™s going to be more. Blind-spot and heated mirror on the Civic Tech Pack. Some ppl will never change in this country.
Doesnโ€™t the Civic have an alarm that goes off when meddled when locked? Also donโ€™t the mirrors fold in automatically when locked?
keep an eye on the used part sites, the thief might pop up ๐Ÿ˜
Not sure. The car was as it was when I got there and anyway I couldnโ€™t hear the alarm as I was in the hospital. Mirrors were folded so it looks like he had sneakily taken it without opening it up.ย
This is a fairly common occurrence in Colombo. My brother also faced the same issue when he had gone for his little ones parents day. He had parked fairly close to the school in Col 03 and gone, when he came back his drivers side mirror was missing and he had been asked to go to the police to lodge a complaint by the insurance. On going to the police station he had come to know that it was the fourth or fifth complaint the police has got for the day, another parent who had parked a few cars ahead also had come to the police with the same complaint.
I do believe you dont have to change the whole mechanism just the mirror part.
Bad luck; they said I need to change the whole assembly and itโ€™s not in stock. Back orders are 3 months so will have to use a temporary dud lens till then. Cost of replacement is 328k.
The mirror could be lifted with minimal movements without triggering the alarm. In my case, small rings that lock the mirror with the rest of the assembly were there struck with the car, hence I was able to get only the mirror replaced. by the looks of the picture, it appears that the rings also missing in yours causing the assembly to be replaced. I got the replacement unit from Pachikawaththe. Since my one was without sensors and indicators, it only cost 10k, they mentioned if it is for the one with all those, it would be 65k. the location is near RPS, in Bhodiraja Mw. named K.D. Auto Parts. the person named Wajiranga, is reachable on 072798883. Hope this helps
Got the insurance claim shifted to Mag C#ty Nugegoda as they have the parts. Estimate is roughly 100k and he too said the entire assembly should be changed, but theyโ€™ll see if the rubber bushes are available in stock too so they can just fix the lens. Awaiting insurance approval now. Letโ€™s see how this goes.ย
My car's AC is having an issue with gas leak inside the cabin (can sense the gas smell like grass when turning on the AC + a continuous hissing sound when the AC is running), tried refilling the gas once, gas went off in 5 days. it is likely to need the compressor replaced. the unit is apparently way inside the dashboard, which basically would need the whole dashboard to be taken off.ย Agent quoted 185k including the air filter. Alternatively Mistire in Dehiwala could do it for half the price. I'm worried about the whole taking off the dashboard thing. Anyone have any experience with something like this.? any other reliable places to do the job?
No experience with the issue but removing the dashboard in the past to fix things on my previous 2 vehicles (not the Civic) had always lead the dash rattling and in the case of the Toyota the dash started cracking.ย
So for that reason alone I'd stick to the agent because you never know how the other place will do the job.ย
The compressor isnโ€™t inside the dashboard and doesnโ€™t need it removed. Itโ€™s only the evaporator thatโ€™s around that area just inside the firewall. I got my compressor repaired by a known technician and that saved me a very expensive replacement. Switched it to R134a entirely and itโ€™s running fine. Only had a leaky condenser after that. More than the compressor, it sounds like thereโ€™s a leak somewhere along the lines thatโ€™s causing the refrigerant to empty out. Itโ€™s pretty nasty if youโ€™re smelling it in the cabin and I suggest you get it fixed ASAP. Still, theyโ€™ll need to use a dye to figure out where the leak is occurring. If itโ€™s beyond the firewall and near the engine bay, youโ€™re lucky as that can be done up without removing the dashboard. Shall message you my contact. If it requires a dashboard removal though, I suggest going to the agent.
Edited by misnad
