Honda Civic 2018
Can anyone suggest me a good place to do a body wax for civic near Kadawatha area? (I am ok with nearby cities as well ๐Ÿ˜€)
  • Replies 874
  • Views 358.2k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Insedious
    Insedious
    Hi Guys, Having being an avid reader of the AL forum for years, I thought I'd create an account and contribute as I got a 2018 Civic SR for the wifey a couple of weeks back. (Edit: Looks like I h
  • It's been about 3 weeks since I received my 2018 Civic EX (Tech package) from the UK. Paid a bit of a premium for it at 7mn total, however I was keen on the Tech Pack upgrade as I detested the standar
  • Now I've heard it all... a Honda with an insect fetish. This proves your car is a female though. No male car would ever be able to have a second full-blown orgasm within 5 minutes of the first on
Posted Images
I assume you're after a regular wax ? C-re Po-nt Ja Ela - uses meguiars products and my experience has been positive.ย
I keep eyeing for that place (near R--ty P--za) but did not go there yet due to lot of negative and bad reviews in google. However since you had a good personal experience, I will have a visit there as well.ย
Thanks for the suggestion.
  • 4 weeks later...
Auto Glance, Colombo if you can go. Hands down the best place for detailing.
  • 2 months later...
Hey everyone! So Iโ€™m going to speak to the Yakkala chap about swapping the innards of the FK6 to an FK7 with a few under the hood mods. Zero external changes - I canโ€™t stand non-stock stuff ๐Ÿ˜€. Apparently Iโ€™ll have to change nearly every part of the car except the chassis, sunroof, lights and seats as the FK7 is built completely different. They did say it was last done for about 3.5M or so and takes a week after the parts arrive.
Curious to hear any feedback from anyone who has done this. Certainly beats buying a downgraded car in this economy!
I mean mechanicals aside what about legal stuff
But if you're going ahead with this it'd make for a super interesting forum blogย
Keep us posted of the developments!
I have driven a FK6 to FK7 converted car from there and the driving experience is great! :Dย For a moment I was considering changing my RU3 for a FK7 converted Civic lolย
My right side turn signal light in the from headlight panel stopped working last week. Took it to a place in Kohuwala on Saturday. then only realized that somehow the headlight water seal is loosened, water seeped in and ultimately caused the turning signal light to go bust. Apparently, there are people who could clean and repair the water leakage, but not sure the LED light could be replaced or not. As such I'm looking for a right side LED headlight unit. at stafford, its 320k, so recon units are the only option here. so far only managed to come across left side units only. Any help/leads would be highly appreciated.
Well this is an interesting turn of events. The conversion has of course been done before. There was at least one Manual 1.5 L swap done with the Dude in Kadawatha involved. The Yakkala guy also had a swapped one. So I'd say this is not unchartered waters though expect a few speedbumps on the way WRT parts replacements etc.ย
Please please do keep us updated we love these projects and the idea of swapping engines always fascinates me and I'm pretty sure it does for many others on the forum.ย
Should not be a big issue. The rules are that the new engines capacity should not exceed 500 CC from the original which is ok in this scenario and the engine should be from the same brand (a point that has been debated in automotive groups and forums in the past whether this is enforced) the car specifications such as wheel size and color should not be changed (again not a problem in this instance).from what is mentioned in the CR.ย
@misnadย off the top of my mind you need to first write to the DMT requesting permission to do an engine swap. You also need to have a bill for the new engine (the Yakkala Joint should be able to give you one) then you need to take the car to DMT to get weighed and inspected and they provide you the new CR with the updated engine number. Just double check with DMT before you proceed on the required documents etc. Your CR will have an additional note mentioning that the engine was replaced.ย
On an additional note - the doctor who used to mass-swap 2JZs on Mark2's used to advertise that he would do the book updating as well for an additional fee. Given the amount you're spending if your garage is doing it for you at an acceptable priceย  - might be worth it getting done via them than go through the hassle.ย
https://dmt.gov.lk/index.php?option=com_content&view=article&id=42&Itemid=159&lang=en#documents-required-to-be-submitted-for-the-revision-of-information-contained-in-the-registration-certificate
All the best with the conversion, I have no idea how good our mechanics are with this sort of stuff but the 1.5 Turbo should prove to be a far more reliable and engaging proposition over the current setup. Do share pics of the entire progress! One thing though - Iโ€™m guessing the parts are recon- how will you be sure of their mileage and condition?
  • 3 weeks later...
Hey guys, so hereโ€™s an update after getting more info. I decided against the conversion for the following reasons (hope they help anyone else considering it):
1) No guarantee of all parts refitted without minor seal alignment issues, etc. like around the headlights and others.
2) The engine and gearbox may not be from the same car, so I had a concern around verifying the true mileage and condition - Iโ€™ll check if a brand new one can be obtained, but I have my doubts.
3) It looks like the wheel size bumps up to 18โ€, which may be an issue with DMT. Thought the FK7 used the same 17โ€ wheels, but this maybe due to the 2019+ models using the bigger wheels.
4) Suspension components are recon - this would be a waste of my entire suspension overhaul with brand new parts on the FK6 last year. Was really hoping these would at least be brand new.
Considering all this, itโ€™s better to just buy a used FC1 or FK7 outright. Disappointed, but I guess it isnโ€™t easy.
Oh and in other news: I had kept the car dormant for a while during my vacation last month and the steering rack developed a bit of stickiness while turning the wheel on idle. The EPS rack just needed a clean up and re-greasing, which the dealer did for approx 5k. No issues now.
Also got the fuel pump replaced on my account proactively as I didnโ€™t want to wait for a failure. The dealer assured me of refunding it if I submitted the carโ€™s invoice from Honda UK and import papers so they could seek approval (something to do with Honda UK not honoring replacements for grey imports). ย Itโ€™s the low pressure pump near the tank btw and not the high pressure one so it cost far less (55k for the unit and 12k for labor including a tank clean up). Best thing about this is I do not smell any hint of gasoline at all now (used to be a bit prevalent before near the gas slot) and can rest assured!
Going to enjoy the Civic in its current form for this year I guess.
p.s: I saw many negative comments about the FK6 in general on Reddit highlighting that every owner here had issues with leaks, etc. so ppl should stay away from it. Every car has its flaws and while this one may have been a bit more, it still is a very good car thatโ€™s unmatched by crappy Raizes and Corollas. Only the newer FL1 does it better IMHO. Moreover, this thread has quite a lot of detail with an open book about everyoneโ€™s experiences with the 10th gen Civic so we help each other out as a community. Havenโ€™t come across many like this one for other vehicle models. This isnโ€™t a complaint-fest.
Edited by misnad
11 hours ago, misnad said:
Corollas
I don't know....at the risk of sounding bias...I would say the new Corolla is far better than the old Axio in terms of handling and drive. Also, as in one of my previous posts, I have no idea why FK owners like to try to drag against it (the ending of which is quite humorous). So it is not like the 1L Civics are that great of a performer (the Corolla has plenty of flaws on its own). But then, I am referring to the 1.8L Hybrid...the 1.5L Petrol, which is what is there in SL, is too jittery in terms of rear suspension but still packs a decent amount of punch for what it isย :)ย
Yes..the FL is a nice car....sadly overpriced for what it is. Sadly, not doing well at all in Japan. Wanted a manual RS, but then it was quoted for nearly 5mil yen. Considering I got the Type R for 5.2mil yen that just seemed like a rip off. Yes...I owned a FL5 for 24 hrs. Was supposed to be the replacement for the GR Yaris and was to arrive in 2025. But it arrived in 2023. When I got it, I simply could not let go of the Yaris.ย
Well those are some valid concerns. Conversions are never straightforward and are usually messy. Though with the Civic I'd have expected lesser hassle as opposed to say an Evo conversion where a very powerful motor is slapped on a stock garden variety chassis causing distortion and premature wear on the chassis OR an older model getting a new engine where two eras have to come together. In your case it looked more straightforward at least in theory. Oh well...ย ย
I'm inclined to agree. Of all the mainstream 1L turbos we got here this probably has the punchiest engine and yes all that power from a tiny engine - something had to give. It was a well put together car too. While I love the simple crisp engaging drive the Vezel gives (and it's way faster than the civic) I still badly miss the low end torque - the car hugging the ground scurrying along and the needle hitting 100 at just 2000 RPM and how it seemed to cling on to the ground when you take ridiculous bends at high speed. My current car does that in a more grown-up serious way while the Civic - it had some teenage energy to it and that I miss.ย
Edited by matroska
This is exactly why I still love the Civic. Was hoping itโ€™d get even better with a 1.5L conversion, but alas, itโ€™s way too complicated. Have my eyes on an HRV RS as it is a superior vehicle to the FK6 for sure - my only issue with SUVโ€™s is the ride height and floaty feel; I like a grounded vehicle. BTW, did you get your infotainment and dash converted to English on the Vezel? Heard many ZRV owners saying they couldnโ€™t, so thought itโ€™s the same here.
It isnโ€™t the performance alone, but itโ€™s more about the features, space and soft touch materials you get compared to the 1.5L 3cyl Corolla WXB. I actually like the Corolla and it isnโ€™t super slow, but I just couldnโ€™t stand the interior and the rear legroom sacrifice. The Corolla Cross is a different story.
Well....with most of these conversions the issue is the whole mix and matching of the core parts. There really is no knowing or assurance on what the conidtin of the parts are and they need refurbishing. Something which 90% of the convertors don't do. So @misnad's concern is quite valid.
Fair enough. The whole dreary interior is a Toyota thing (probably since the late 2000s). The only time the interiors have any soft refine materials are if you go to the higher end models. Toyota defends it like death stating cost and durability of these cars (market segment wants to use the cars longer and gets used harsher so materials need to be hard). But then all that reasoning falls apart when you look at what (out of nowhere) Mazda (the ironic manufacturer who seems to coast through under the radar without any significant issues). As for the Corolla itself. You can get nicer seats and stuff but comes at a cost. I think the package that comes with the pearly whitish seats are about 200,000yen more ? Oh...and they released the latest facelift (minor change) with static discharging seats! No idea if that makes any difference but appaently reduced driver fatigue.
As for the Corolla Cross. It is an interesting. The higher trim levels are where it is actually not bad. But then those are highly priced as well (makes one wonder if you are gaining that much for the extra money you pay). The new GR Sport trim is actually quite fun with harder suspension and slight EPS and throttle tune up. So it might actually solve your SUV floatiness. But then there are plenty of OEM and 3rd party options to sort that out with the Vezel as well.
EDIT:ย  A bit of useless trivia
In regards to the rear legroom in the Corolla. Did you know that Toyota reduced the wheelbase size of the Corolla for the Japanese market ? The rear door access and legroom is better in the export models (sadly the export models we get in SL are the poverty spec variants). Even the Touring, available only in Europe and Japan. The JDM version has a smaller luggage area (useless usable space compared to the ole elephant back but looks cool) then the Euro version.
Edited by iRage
  • 1 month later...
Update :ย
Replaced a new headlight from New Hewage in Piliyandala. Unfortunately, it also had mist accumulating inside. He provided another unit, which had a burnt low beam. came across a place in Negombo which reseal the headlight units. took there, got it removed, and resealed the whole unit. since then the problem is fully solved.
Apparently, this is a known issue in Civics, and the particular workshop in Negombo is the only one which does some specific kind of the sealing. it goes by the name GT4ME***. hope this helps.
Major update:
After 8+ years of ownership, peaks of enjoyment and troughs of annoyance, Iโ€™ve sold my beautiful Civic. Got a really good new owner for the fellow who fell in love with it the moment he saw it.
The selling experience: There were so many low-ballers, reseller vultures and foxes crying sour grapes. There was one chap who claimed it can never be sold beyond 10M and another who claimed 11.1M was the absolute best I could ever get since theyโ€™d have to modify it to sell it - apparently there is no demand. I stood my ground. The buyer had come via FB, saw it in person on the same day and liked the condition of the car. Bought it the very next day. Sold it for 11.6M, which is ok with me, especially since itโ€™s a retail buyer and not some reseller whoโ€™d seek to make a quick 500k out of it.
I do miss the car and the memories. I do hope this thread has helped the community; I shall miss posting here about its updates, but will certainly stick around to help anyone as needed. Need to create or join a new thread for my new car.
So what did I get? After a long and hard deliberation, I chose an Audi A3 Sportback S-Line 2023. It is a 1L turbo, but seems to pick up more respectably albeit quietly compared to the Civic. I guess itโ€™s due to the DSG transmission. Maintenance expenses may be high in the long term, but Iโ€™m ok with that given Iโ€™ve always looked for an Audi from childhood.
Onwards and beyond!
Congratulations on the new buy!
Had the same experiences when I sold my beloved Mazda an year and 3 months ago - mind you this was the time that imports became readily available and so many were trying to low-ball. But I did the same and gave it away at my price. Still miss the car.
Pics of the new car pleaseย ๐Ÿ˜ƒ
Edited by Izza
editing
On 7/31/2026 at 4:05 PM, misnad said:
Major update:
Honda
Onwards and beyond!
Congratulations on the new car ! Hope to see a detailed post on her :Dย
Congratulations on the new Audi!
This is interesting. I always felt the CVT on the Civic was making it feel less engaging. On paper, the Civic has more HP than the Audi and the weight would be roughly similar.ย  How about the handling aspects of the Audi compared to the FK6?ย
Was this a physically large individual in his 20's who came with his dad?ย
The FK6 with adaptive dampers was snappier and responsive with turns. More grounded. The A3 s-line isnโ€™t that far behind though, as it has stiffer suspension and is lower compared to the other trims. The only drawback of the A3 is the rear (on the 1L only) is a torsion beam as opposed to the multi-link on FK6โ€™s, so it sort of drags along. It isnโ€™t floaty though and handles much better than the civic with adaptive dampers switched off.
Nope, this was a chap who runs a fairly popular detailing business. They were either resellers or friends of resellers - again a big no, since theyโ€™d certainly want open papers.
On 7/31/2026 at 7:05 PM, misnad said:
Major update:
Onwards and beyond!
Congratulations on the new ride. I am sure you will love the Audi S Tronic (I personally love any of the DC boxes)
  • 1 month later...
