Watchman Posted April 18, 2006 Share Posted April 18, 2006 Hey! There’s been a couple of posts asking members how efficient various vehicles are on fuel. And with the prices going up by Rs.8/= and with news in the air that it will go up again by another Rs.3/= soon, its getting even more important… So what do you say we post the following details Vehicle : Transmission Type : Engine Capacity : Fuel : Km per Ltr (city/long distance) : 1 Quote Link to comment Share on other sites More sharing options...
0 Jor-el Posted March 13, 2015 Share Posted March 13, 2015 You guys didn't get it. Actually he meant AC is Off. Quote Link to comment Share on other sites More sharing options...
0 kmeeg Posted March 13, 2015 Share Posted March 13, 2015 (edited) On 3/13/2015 at 6:04 AM, Jor-el said: You guys didn't get it. Actually he meant AC is Off. I'm not sure about that J, but generally when you set to 30C doesn't the heater starts? (unless the inside temperature is higher inside). Otherwise could have mention A/C Off right? Edited March 13, 2015 by kmeeg Quote Link to comment Share on other sites More sharing options...
0 Davy Posted March 15, 2015 Share Posted March 15, 2015 (edited) dhanuFB15 said: Car: Nissan FB15Year : 2000 Engine Capacity : 1.5L Fuel : 92 octane petrol Transmission : Auto Fuel Economy Colombo city : 8-9kmpl Highway : 12-13kmpl (At 80kmph) Outstation - Upcountry : 9-10kmpl Outstation - Flat roads : 11-13kmpl Tyre pressure : 35psi Tyre air type : Normal Driving strategy : Light acceleration, moderate speeds & Air conditioning at 30C . As the others have already pointed out, your tyre pressure is way too high. It should be somewhere around 28 - 30. While you might be saving a few cents off fuel, you are wearing out the suspension of your car faster - that's a repair that will cost you far more than what you will be saving on fuel. Also, your tyres will wear out much faster. You might want to consider all that and inflate your tyres to the recommended pressure. It should be printed on and attached to the B pillar of your car - driver's side. As for the AC, I don't think I have the right to decide what's the right temperature for you, but I believe 30C is way beyond the comfort zone of an average human being. Plus, you might want to try and wrap your head around this to determine if you are really saving money on AC: If your AC is manual, and if you have your temperature dial set a bit towards the warm side from the "max cold" position, the AC is still working the exact same way to how it would work if you set the dial to "max cold". Most manual AC systems reduce the cold by activating the heater and mixing the hot and cold air so that the air reaches a "less cold" temperature. Again, this is on most manual AC systems and I believe it's the same case for you as well. If this is the case, your passengers (and you) are suffocating for no actual gain. Edited March 15, 2015 by Davy 1 Quote Link to comment Share on other sites More sharing options...
0 NRX Posted March 16, 2015 Share Posted March 16, 2015 I guess he has a climate control AC system, (If the car is a Super Saloon) Otherwise he couldn't have known the set temperature. In that case the compressor should be disengaged most of the time. Quote Link to comment Share on other sites More sharing options...
0 tinyman Posted March 16, 2015 Share Posted March 16, 2015 On 3/15/2015 at 11:53 PM, Davy said: As the others have already pointed out, your tyre pressure is way too high. It should be somewhere around 28 - 30. While you might be saving a few cents off fuel, you are wearing out the suspension of your car faster - that's a repair that will cost you far more than what you will be saving on fuel. Also, your tyres will wear out much faster. You might want to consider all that and inflate your tyres to the recommended pressure. It should be printed on and attached to the B pillar of your car - driver's side. As for the AC, I don't think I have the right to decide what's the right temperature for you, but I believe 30C is way beyond the comfort zone of an average human being. Plus, you might want to try and wrap your head around this to determine if you are really saving money on AC: If your AC is manual, and if you have your temperature dial set a bit towards the warm side from the "max cold" position, the AC is still working the exact same way to how it would work if you set the dial to "max cold". Most manual AC systems reduce the cold by activating the heater and mixing the hot and cold air so that the air reaches a "less cold" temperature. Again, this is on most manual AC systems and I believe it's the same case for you as well. If this is the case, your passengers (and you) are suffocating for no actual gain. I keep the air pressure at 32, is it ok. the reason I don't keep the air pressure at 28-30 is thinking that it will result in even less ground clearance. Quote Link to comment Share on other sites More sharing options...
0 The Stig Posted March 16, 2015 Share Posted March 16, 2015 (edited) On 3/15/2015 at 11:53 PM, Davy said: As the others have already pointed out, your tyre pressure is way too high. It should be somewhere around 28 - 30. While you might be saving a few cents off fuel, you are wearing out the suspension of your car faster - that's a repair that will cost you far more than what you will be saving on fuel. Also, your tyres will wear out much faster. You might want to consider all that and inflate your tyres to the recommended pressure. It should be printed on and attached to the B pillar of your car - driver's side. As for the AC, I don't think I have the right to decide what's the right temperature for you, but I believe 30C is way beyond the comfort zone of an average human being. Plus, you might want to try and wrap your head around this to determine if you are really saving money on AC: If your AC is manual, and if you have your temperature dial set a bit towards the warm side from the "max cold" position, the AC is still working the exact same way to how it would work if you set the dial to "max cold". Most manual AC systems reduce the cold by activating the heater and mixing the hot and cold air so that the air reaches a "less cold" temperature. Again, this is on most manual AC systems and I believe it's the same case for you as well. If this is the case, your passengers (and you) are suffocating for no actual gain. Well i dont know what type of AC he has but there is a very common issue in the fb15/n16/y11 series cars with auto climate control (not the ac unit with the dials but the one with push button and green colour indicators on top). The temperature is not properly calibrated on these, on cars with this unit even if you set it to 30c it's still cold as hell. IE at 30 the heater doesn't enguage and 30 feels more like 24c. And 30 is the lowest you can go. This might actually be the reason. Edit - This model https://img03.carview.co.jp/trade/img06/cars/540015/15379835/japan%20car/2002+nissan+sunny/09.jpg Edited March 16, 2015 by The Stig Quote Link to comment Share on other sites More sharing options...
0 Davy Posted March 16, 2015 Share Posted March 16, 2015 (edited) On 3/16/2015 at 3:41 AM, The Stig said: Well i dont know what type of AC he has but there is a very common issue in the fb15/n16/y11 series cars with auto climate control (not the ac unit with the dials but the one with push button and green colour indicators on top). The temperature is not properly calibrated on these, on cars with this unit even if you set it to 30c it's still cold as hell. IE at 30 the heater doesn't enguage and 30 feels more like 24c. And 30 is the lowest you can go.This might actually be the reason. Really? That just might be it then! On 3/16/2015 at 3:30 AM, tinyman said: I keep the air pressure at 32, is it ok. the reason I don't keep the air pressure at 28-30 is thinking that it will result in even less ground clearance. Depends on the manufacturer specification for your car. What does the information card on the B pillar say? And are you running on the stock rim size and tyre size? I really doubt that 2 - 3PSI is going to give you significant ground clearance. Edited March 16, 2015 by Davy Quote Link to comment Share on other sites More sharing options...
0 NRX Posted March 16, 2015 Share Posted March 16, 2015 On 3/16/2015 at 3:41 AM, The Stig said: Well i dont know what type of AC he has but there is a very common issue in the fb15/n16/y11 series cars with auto climate control (not the ac unit with the dials but the one with push button and green colour indicators on top). The temperature is not properly calibrated on these, on cars with this unit even if you set it to 30c it's still cold as hell. IE at 30 the heater doesn't enguage and 30 feels more like 24c. And 30 is the lowest you can go.This might actually be the reason. Edit - This model https://img03.carview.co.jp/trade/img06/cars/540015/15379835/japan%20car/2002+nissan+sunny/09.jpg What you mention here is a classic symptom of blocking the heater core by our maka basses I guess. Quote Link to comment Share on other sites More sharing options...
0 Magnum Posted March 29, 2015 Share Posted March 29, 2015 (edited) Vehicle : Toyota Hiace KDH 206( automatic AWD)Transmission Type : AutomaticEngine Capacity : 3000cc VG TurboFuel : Super DieselFuel Economy; City : 7-8km/l with A/C mostly on eco mode without turbo kicking in Out Station(flat roads) : 10km/l, heavy footed driving with dual A/C and 5 people on-board Edited March 29, 2015 by Magnum Quote Link to comment Share on other sites More sharing options...
0 bgayan84 Posted September 13, 2015 Share Posted September 13, 2015 ey guys im thinking about to buy a toyoto HARRIER jeep which were registered in year 2000-2002 with the budget of 25laks....since i do not have any previous experience in suv jeep, ur most welcome for the comments...or any other suv jeep within that budget............ 01) about the fuel consumption 02) condition 03) spare parts 04) Manual or Auto 05) Engine capacity Quote Link to comment Share on other sites More sharing options...
0 AdeZ Posted November 21, 2015 Share Posted November 21, 2015 Vehicle : Nissan N 17Transmission Type : ManualEngine Capacity : 1300 CCFuel : Petrol with SoltronKm per Ltr (city/long distance) : 10-11/13-14 Vehicle : GWM Voleex C10 Transmission Type : Auto/CVTEngine Capacity :1500 CCFuel : Petrol-95Km per Ltr (city/long distance) : 11-13/15-16 Vehicle : Toyota Prius 3rd Gen 2013 Transmission Type : AutoEngine Capacity : 1800 CCFuel : Petrol/EVKm per Ltr (city/long distance) : 29.1 Quote Link to comment Share on other sites More sharing options...
0 Kasun Tharaka Posted December 11, 2015 Share Posted December 11, 2015 Vehicle : Toyota Hilux Vigo Transmission Type : ManualEngine Capacity : 3000 CC VN TurboFuel : Super DieselKm per Ltr (city/long distance) : 10-11/13-14 Quote Link to comment Share on other sites More sharing options...
0 osanda19 Posted December 14, 2015 Share Posted December 14, 2015 (edited) Vehicle :Toyota Vitz(SCP10) Year :2001 Transmission Type :Auto Engine Capacity :1000 CC Fuel :95 octane petrol Km per Ltr CITY :12-15kmpl OUT :18-21kmpl Edited December 14, 2015 by osanda19 Quote Link to comment Share on other sites More sharing options...
0 osanda19 Posted December 14, 2015 Share Posted December 14, 2015 Vehicle :HONDA FIT(GP5) Year :2014 Transmission Type :Auto Engine Capacity :1500 CC Fuel :95 octane petrol Km per Ltr CITY :15-19kmpl OUT :24-31kmpl Quote Link to comment Share on other sites More sharing options...
0 osanda19 Posted December 14, 2015 Share Posted December 14, 2015 Vehicle :SUZUKI EVERY(DA64V) Year :2010 Transmission Type :MANUAL Engine Capacity :660 CC Fuel :95 octane petrol Km per Ltr CITY :10-13kmpl OUT :15-18kmpl Quote Link to comment Share on other sites More sharing options...
0 osanda19 Posted December 14, 2015 Share Posted December 14, 2015 Vehicle :Toyota Corolla(NZE 121) Year :2004 Transmission Type :Auto Engine Capacity :1500 CC Fuel :95 octane petrol Km per Ltr CITY :10-13kmpl OUT :16-20kmpl Quote Link to comment Share on other sites More sharing options...
0 osanda19 Posted December 14, 2015 Share Posted December 14, 2015 Vehicle :Toyota Allion(260) Year :2007 Transmission Type :Auto Engine Capacity :1500 CC Fuel :95 octane perol Km per Ltr CITY :7-10kmpl OUT :11-13kmpl Quote Link to comment Share on other sites More sharing options...
0 NRA95 Posted March 1, 2016 Share Posted March 1, 2016 Vehicle : Honda CR-V 2013 Transmission Type : Automatic Engine Capacity : 2000CC Fuel Type : 95 Octane Km per Ltr (city/long distance) : 6Km/L-7Km/L city & 12Km/L-13Km/L outstation Quote Link to comment Share on other sites More sharing options...
0 Supra_Natural Posted March 31, 2016 Share Posted March 31, 2016 Vehicle: 2014 Mazda 6 2.0 L Transmission : 6 Speed Auto Engine Capacity : 2000CC I4 Fuel: 95 Octane Consumption : City - 7.5-10 KM/L (depending on driver), Highway - 12.5-13 KM/L (Not very light footed driving) Quote Link to comment Share on other sites More sharing options...
0 Hoonigan Posted March 31, 2016 Share Posted March 31, 2016 Vehicle: 2004 BMW E46 Transmission : Manual Engine Capacity : 2000CC 4 pot Fuel: 95 Octane Consumption : City - 7-8 KM/L (in heavy traffic and with AC of course), Outstation - 10-12 KM/L (throttle happy) Highway - Yet to calculate Quote Link to comment Share on other sites More sharing options...
0 lkRaven Posted March 31, 2016 Share Posted March 31, 2016 Vehicle: 2011 Hyundai Elantra Transmission : Auto Engine Capacity : 1600cc Fuel: 95 Octane Consumption: City - 7-8 km/l (in heavy traffic with climate control on), Outstation - 14-15 km/l (As indicated on trip computer) Actual combined cycle hits somewhere around 11-12 km/l. I never topped up immediately after a long distance trip to get the exact value. Usually the trip computer value is around 1km/l optimistic than the actual. Quote Link to comment Share on other sites More sharing options...
0 fiatLife Posted April 1, 2016 Share Posted April 1, 2016 Vehicle: 1996 Fiat Bravo MK1 Transmission : 5 Speed Manual Engine Capacity : 1400cc 12v Fuel: 95 Octane Consumption : City - 5.5 - 9 KM/L (depending on the driver and also the fuel needle placement), Highway - above 10 km/l all figures are not light footed driving Quote Link to comment Share on other sites More sharing options...
0 AdeZ Posted May 22, 2016 Share Posted May 22, 2016 (edited) TOYOTA AXIO 2016 G GRADE Hybrid 1500 CC 25 to 27km/L Approx speed 40-80 Edited June 13, 2016 by AdeZ Quote Link to comment Share on other sites More sharing options...
0 Crosswind Posted May 22, 2016 Share Posted May 22, 2016 On 5/22/2016 at 11:33 AM, AdeZ said: TOYOTA AXIO 2016 G GRADE Hybrid1500 CC Long distance 30Km/L Normal 25Km/L< Still mileage below 1000.. Approx speed 50> Out of curiosity, how many wheels does your 'car' have? Does it have the following badge in addition to the Axio and hybrid synergy drive badges? 6 Quote Link to comment Share on other sites More sharing options...
0 mission Posted May 26, 2016 Share Posted May 26, 2016 Vehicle :Nissan - March (K12)Year :2003Transmission Type :AutoEngine Capacity :1000 CCFuel :normal petrolCITY :12-13kmplOUT :? Quote Link to comment Share on other sites More sharing options...
Watchman
Hey!
Vehicle :
Transmission Type :
Engine Capacity :
Fuel :
Top Posters For This Question
20
18
14
8
Popular Days
Apr 18
50
Apr 20
11
Mar 27
9
Jul 13
9
Magnum 20 posts
Watchman 18 posts
Andrew_GTR 14 posts
sathyajithj99 8 posts
Popular Days
Apr 18 2006
Apr 20 2006
Mar 27 2014
Jul 13 2012
Popular Posts
Crosswind
Thts because there's one giant snake in your premio. It comes factory fitted with most premio owners.
SubZero
All fuel economy conscious drivers, Please be kind enough to maintain a sane distance with the vehicle in front of you. You might save on fuel, true. But other drivers behind you will burn more tryi
Crosswind
348 answers to this question
