iRage Posted December 26, 2019 Posted December 26, 2019 AT fluid filters for quite sometime have been non serviceable items for very high mileages. The metal filter is typically cleaned by magnetizing the unit and dragging out any metal shavings. However, this also means the fluid needs to be changed using one of those machine thingies....It is just that in Sri Lanka the way the fluid was replaced was by actually dismantling the unit from the bottom which means the filter also comes out. Since it is out...it is good practice to replace it if the transmission has seen high miles.Β Quote
trinity Posted December 26, 2019 Author Posted December 26, 2019 1 hour ago, Hyaenidae said: @trinityΒ could you remember how many ltrs of transmission fluid was used?Β Exactly five liters of Mitsubishi Β Diaqueen ATF SP3 Β (Price Rs.8,252.15ο»Ώ) 1 Quote
Hyaenidae Posted December 26, 2019 Posted December 26, 2019 1 hour ago, trinity said: Exactly five liters of Mitsubishi Β Diaqueen ATF SP3 Β (Price Rs.8,252.15ο»Ώ) But according to the workshop manual it should be about 9 liters ne http://mmc-manuals.ru/manuals/lancer_x/online/Service_Manual/2015/23/html/M123100100054400ENG.HTM @Sampath GunasekeraΒ had mentioned thatΒ he boughtΒ 10 liters for his CSΒ http://autolanka.com/forums/topic/18754-my-new-ride-mistubishi-lancer-cs1-glx-at-yom-2007/?do=findComment&comment=304459 Β Quote
K.o.N.o.S Posted December 26, 2019 Posted December 26, 2019 2 hours ago, Hyaenidae said: But accordingο»Ώ to the workshop manual it should be about 9 liters neο»Ώ Just seeing this. I got mine changed at my first service.It was 5 liters for me as well. However user manual states 7.7 liters Quote
Hyaenidae Posted December 26, 2019 Posted December 26, 2019 (edited) 1 hour ago, K.o.N.o.S said: Just seeing this. I got mine changed at my first service.It was 5 liters for me as well. However user manual states 7.7 liters That's the capacity of the transmission. The workshop manual states the same: http://mmc-manuals.ru/manuals/lancer_x/online/Service_Manual/2015/23/html/M123100040094700ENG.HTM I guessΒ the additionalΒ 1.3 liters is added (andΒ replaced) inΒ order to ensure a complete fluid replacement Edited December 26, 2019 by Hyaenidae Quote
Davy Posted December 26, 2019 Posted December 26, 2019 6 hours ago, Hyaenidae said: Butο»Ώ ο»Ώaccording to the workshop manual it should be about 9 litersο»Ώ ne That's for two drains. Drain a total of 5.5L (2L + 3.5L). Then fill 5.5L. Do another drain of 3.5L and fill 3.5L. Also, although the capacity of the transmission is 7.7L, the required amount of oil for a manual drain and refill is less than that, because not all oil is drained from the transmission. Some of it is left inside. That's why the instructions in the workshop manual takes you through multiple drains and fills.Β The only transmission that has an external oil filter on the CY is probably the twin clutch SST that comes on the RalliArt and Evolution.Β 1 Quote
Hyaenidae Posted December 26, 2019 Posted December 26, 2019 3 hours ago, Davy said: That's for two drains. Drain a total of 5.5L (2L + 3.5L). Then fill 5.5L. Do another drain of 3.5L and fill 3.5L. Also, although the capacity of the transmission is 7.7L, the required amount of oil for a manual drain and refill is less than that, because not all oil is drained from the transmission. Some of it is left inside. That's why the instructions in the workshop manual takes you through multiple drains and fills.Β The only transmission that has an external oil filter on the CY is probably the twin clutch SST that comes on the RalliArt and Evolution.Β Wonder why Unimo doesn't heed the instructions on the workshop manual issued by the manufacturer... that, too, for CY lancers apparently: they performed the fluid replacement as per the instructions on theΒ workshop manual on @Sampath Gunasekera's CS Quote
Hyaenidae Posted December 26, 2019 Posted December 26, 2019 12 hours ago, iRage said: It is just that in Sri Lanka the way the fluid was replaced was by actually dismantling the unit from the bottom which means the filter also comes out. Since it is out...it is good practice to replace it if the transmission has seen high miles.Β The oil pan is mounted sideways so dismantling the oil panΒ from the bottom is impossible ? even if the oil pan is removed sonehow there is no filter underneath: apparantly Mitsu deleted the external filter of these transmissions back in 1999.Β The internalΒ filter cannot be accessed without removing the torque converter housing. Quote
iRage Posted December 27, 2019 Posted December 27, 2019 8 hours ago, Hyaenidae said: The oil pan is mounted sideways so dismantling the oil panΒ from the bottom is impossible ? even if the oil pan is removed sonehow there is no filter underneath: apparantly Mitsu deleted the external filter of these transmissions back in 1999.Β The internalΒ filter cannot be accessed without removing the torque converter housing. Well....these "external" filters have been gone for a long time.Β They were all internal in a concealed unit irrespective of location. Even if it was on the bottom above the little pan...it was "internal" and did not require replacing until 10 years or something.Β Typically a metal mesh in a casing. It is that in the past..because of the positioning of this filter...the filter came out when the bottom pan was removed as the only way we could remove the fluid was by taking off the bottom cover since we did not have the proper equipment for a suction removal (most garages still do not). So people replaced it..and in some cases the manufacturer recommends replacing the filter if it ever comes out (manufacturers recommend even the replacement of washes when a nut and bolt is taken off). Quote
Hyaenidae Posted December 27, 2019 Posted December 27, 2019 5 hours ago, iRage said: Well....these "external" filters have been gone for a long time.Β They were all internal in a concealed unit irrespective of location. Even if it was on the bottom above the little pan...it was "internal" and did not require replacing until 10 years or something.Β Β Yeah thatΒ Β "external" filter which Mitsu decided redundant was at the bottom of the oil pan, going by their workshop guidesΒ (linked above)Β Β Quote
Davy Posted December 27, 2019 Posted December 27, 2019 5 hours ago, Hyaenidae said: Yeah thatΒ Β "external" filter which Mitsu decided redundant was at the bottom of the oil pan, going by their workshop guidesΒ (linked above)Β Β Pretty sure the CVT still has the mesh filter at the bottom of the oil pan which is on the underside of the car and not vertical like the conventional auto.Β Quote
Hyaenidae Posted December 27, 2019 Posted December 27, 2019 53 minutes ago, Davy said: Pretty sure the CVT still has the mesh filter at the bottom of the oil pan which is on the underside of the car and not vertical like the conventional auto.Β Yeah Mitsu deletedΒ that filter from F4A4 automatic transmissions, CVTs belong to a different series of transmissions Quote
K.o.N.o.S Posted December 30, 2019 Posted December 30, 2019 Guys quick clarification, MyΒ service is very near and I am planning to put the car to UNIMO for the first time. The issue is that my car has been using Mobil 15W40 engine oil for the last 5 years. UNIMO people are using Valvoline. Will there be an issue if I switch to Val? @HyaenidaeΒ @DavyΒ @trinity Quote
Hyaenidae Posted December 30, 2019 Posted December 30, 2019 3 hours ago, K.o.N.o.S said: Guys quick clarification, MyΒ service is very near and I am planning to put the car to UNIMO for the first time. The issue is that my car has been using Mobil 15W40 engine oil for the last 5 years. UNIMO people are using Valvoline. Will there be an issue if I switch to Val? @HyaenidaeΒ @DavyΒ @trinity I'm no oil expert but I don't think switching the brandΒ once or twice would cause much of an issue, I've heardΒ doing it often could lead toΒ sludging 'causeΒ different oil manufacturers use different additives even if the specs are similar Do you have any idea which oil was usedΒ before 5 years? whatΒ was the reason for the switch to 15W40? I've been using 10W30 (conventional) starting from the first service as per the recommendation of UNIMO, I'm guessing yours was using it too (atleast in the warranty period). Quote
K.o.N.o.S Posted December 30, 2019 Posted December 30, 2019 50 minutes ago, Hyaenidae said: Do youο»Ώ have any idea whο»Ώich oil waο»Ώs usedΒ beο»Ώforeο»Ώ 5 yeο»Ώarο»Ώsο»Ώο»Ώ?ο»Ώο»Ώ It was Mobil as well. I am the 3rd owner and TheΒ previous owner (Elnino) was reluctant to switch to a different engine oil. So he also hasΒ continued with Mobil throughoutΒ his ownership. Quote
Hyaenidae Posted December 30, 2019 Posted December 30, 2019 10 minutes ago, K.o.N.o.S said: It was Mobil as well. I am the 3rd owner and TheΒ previous owner (Elnino) was reluctant to switch to a different engine oil. So he also hasΒ continued with Mobil throughoutΒ his ownership. I meant the viscosity: since UNIMO recommends 10W30 I'm guessing the first owner used 10W30 instead of 15W40?Β Maybe the first owner switched to 15W40 when he quitΒ getting the car serviced by UNIMO. It wouldn't matter switching to Val from Mobil but I think it'dΒ be Β better if youΒ continue with 15W40 since it has been used for years. I guessΒ UNIMO would suggest you to switchΒ to 10W30 - it's their recommended viscosity for the Lancer Quote
K.o.N.o.S Posted December 30, 2019 Posted December 30, 2019 (edited) 21 minutes ago, Hyaenidae said: 34 minutes ago, K.o.N.o.S said: Β ο»Ώ Iο»Ώ meantο»Ώο»Ώο»Ώ the viscosityο»Ώ: sinο»Ώce UNIMO recommends 10W30 I'm guessing the first owο»Ώnerο»Ώ used 10W30 instead of 15W40? You are correct. May be the first owner stopped regularΒ servicing at UNIMO for some reason.Β I actually went through theΒ huge file which consists of service records for the lastΒ 7 years or so. It was Mobil 15W40 throughout.IΒ Could not find a single regular service record withΒ UNIMO. Of course there were routine maintenance records with them. Edited December 30, 2019 by K.o.N.o.S Quote
Hyaenidae Posted December 30, 2019 Posted December 30, 2019 YeahΒ the 3rd party workshop must have made theΒ switch to thicker oil... you'llΒ have to specifically request UNIMO to use 15W40 instead of 10W30 Quote
trinity Posted January 2, 2020 Author Posted January 2, 2020 On 12/30/2019 at 5:52 PM, K.o.N.o.S said: Guys quick clarification, MyΒ service is very near and I am planning to put the car to UNIMO for the first time. The issue is that my car has been using Mobil 15W40 engine oil for the last 5 years. UNIMO people are using Valvoline. Will there be an issue if I switch to Val? @HyaenidaeΒ @DavyΒ @trinity Hi machang, seeing this now, when I bought my Lancer CS, I didnt know what oil was used and I opted for Mobil first. Then after few years I switched to Valvoline as recommended by the agent and used it until I sold the car. But did not change the viscosity at that time. It was changed to 20W50 from 10W30 Β when the car reached 120,000kms as Β recommended by my mechanic. There was no issue whatsoever with the engine when the car was sold at 225,000kms.Β I'm using Valvoline 10W30 for the Lancer EX now. The car has run 135,000kms and I'm still using the same viscosity as I was told there's no requirement of changing it at this mileage. I'm no expert but i believe changing from Mobil to Valvoline wont be an issue but you gonna have to be mindful about the viscosity. Better to take agents advise on it. Β 1 Quote
K.o.N.o.S Posted January 2, 2020 Posted January 2, 2020 56 minutes ago, trinity said: Hi machang, seeing this now, when I bought my Lancer CS, I didnt know what oil was used and I opted for Mobil first. Then after few years I switched to Valvoline as recommended by the agent and used it until I sold the car. But did not change the viscosity at that time. It was changed to 20W50 from 10W30 Β when the car reached 120,000kms as Β recommended by my mechanic. There was no issue whatsoever with the engine when the car was sold at 225,000kms.Β I'm using Valvoline 10W30 for the Lancer EX now. The car has run 135,000kms and I'm still using the same viscosity as I was told there's no requirement of changing it at this mileage. I'mο»Ώο»Ώ noο»Ώο»Ώ expert buο»Ώt i ο»Ώbelieveο»Ώ changing from Mobil to Valvoline wont be an issuο»Ώe but you gο»Ώonna have to be mindful about the viscosity. Better to taο»Ώke agents advise on it.ο»Ώ Β Thanks for theΒ advice Machan. From what I have learned so far Car has been running with 15W40 for almost 7 years. So I believe changing the viscosity suddenly will create unnecessary issues in the long run(at least in my mind paranoia will kick the best out of me) so yeahΒ letβs see what the UNIMO people has to say Quote
K.o.N.o.S Posted January 12, 2020 Posted January 12, 2020 (edited) Greetings gents, So I got my ABS issue sorted today. It took longer than I expected as the package got caught in the Christmas season rush.Β Finally the sensor arrived last week and got it fixed at my local mechanic.Β A very big thanks to @HyaenidaeΒ for finding this sensor online.Β And also @trinityΒ for your valuable advices as always. If it wasnβt for you guys I would have spent a thumping amount for a tiny sensor.Β So the timeline of finding the sensor Unimo- quoted 32k Place inΒ pitakotte-25k Place in panadura-15k Ebay-6k (with shipping) Β Finally took a risk and settled with eBay seller for an OEM sensor ( Mitsubishi part no- 4670A576) and have to say that the risk payed off. No more ABS indicators and ABS kicks in as expected. Happy happy..Managed to grab some pics. Β Edited January 12, 2020 by K.o.N.o.S 5 Quote
trinity Posted January 12, 2020 Author Posted January 12, 2020 6 hours ago, K.o.N.o.S said: Greetings gents, So I got my ABS issue sorted today. It took longer than I expected as the package got caught in the Christmas season rush.Β Finally the sensor arrived last week and got it fixed at my local mechanic.Β A very big thanks to @HyaenidaeΒ for finding this sensor online.Β And also @trinityΒ for your valuable advices as always. If it wasnβt for you guys I would have spent a thumping amount for a tiny sensor.Β So the timeline of finding the sensor Unimo- quoted 32k Place inΒ pitakotte-25k Place in panadura-15k Ebay-6k (with shipping) Β Finally took a risk and settled with eBay seller for an OEM sensor ( Mitsubishi part no- 4670A576) and have to say that the risk payed off. No more ABS indicators and ABS kicks in as expected. Happy happy..Managed to grab some pics. Β Glad you got it sorted out this way. Thatβs a big relief isnβt it? Happy to be of assistance ?.Β Cheers! 1 Quote
Hyaenidae Posted January 12, 2020 Posted January 12, 2020 Nice!Β ? Next up: Routine maintenance service 1 Quote
Hyaenidae Posted January 18, 2020 Posted January 18, 2020 (edited) The ultimate repair/ moderate upgrade 4A91 1500CC engine swapped with 4B11 2000CC non-turbo engine. I don't know the owner - just a random reg number look-upΒ Edited January 18, 2020 by Hyaenidae Quote
trinity Posted January 18, 2020 Author Posted January 18, 2020 13 hours ago, Hyaenidae said: The ultimate repair/ moderate upgrade 4A91 1500CC engine swapped with 4B11 2000CC non-turbo engine. I don't know the owner - just a random reg number look-upΒ I know a place where thereβs a 4B11 for sale with complete wire harness and all ?. Quote
