March 21, 201610 yr The rear refina? That's not a sticker, those are badges If you are talking about the side sticker near the rear door, it has a different font that the trunk refina font... it seems like its out of place but it's the way it is actually... It was hard to paste them anyway, it sticks on the hand :s Really ?ใThe following is fromใa scan from a catalog..and it is mounted straight....granted that seems more like a badge than a sticker...and a pre-facelift (facelift..)
March 21, 201610 yr Really ?ใThe following is fromใa scan from a catalog..and it is mounted straight....granted that seems more like a badge than a sticker...and a pre-facelift (facelift..) Ah no no I wasn't talking about it being pasted straight,.. I thought NRX was saying the letters pasted seperately looks out of place (which is the font which looks as if the letters are out of place)... I have pasted the entire "refina" sticker in a 45 degrees manner coz, its very hard to paste it straight, the sticker sticks on the hand and if i try to paste it straight i would fail, so pasted it the way it is now... when i bought the car, this badge you are talking was not a badge nor a sticker, it was done with LACQUER...Since its hard to lacquer the font after the new paint, I made a sticker for the side and went with the badges for the rear... with regards to facelifts, yeah the CT2 came with 2 shells... your picture is the first shell (95 model), and then came another bumber lip with the 96,97 ct2's and then finally the refina buffer... even though the one in your picture has a refina sticker, its not a refina, its a 95 model ct2... some ct2 had a side sticker named refina, and no one knows why.. only the crystal light models are known to be refina's...
March 21, 201610 yr Well done! Any before and after pics? don't have any pics before, coz right away i put it to the paint after buying.. but during the painting process and the whole restoration process I took pics.. thought of putting it to the restoration blog and share it.. waiting for a photographer to agree with me to do a shoot coz in my phone camera, the curves and details cannot be seen much... If Pericles is free for a shoot in any location, I'd be happy to do so
March 21, 201610 yr However, there is one thing which I haven't figured out yet... the right tail light, i had previously had a bit of mist after a wash... I thought there must be a leak in the tail light so I bought a new tail light and replaced.. but then again after the wash, even in the new tail light the mist is there... so i assume, the light should be sealed properly maybe after fitting and nothings wrong with the lights?.. coz when i look from above, the left tail light has a sealant kind of thing which water won't go in , whereas in the leaky side, water can directly penetrate in.. so anyone can suggest a good place for me to get it properly sealed or do something where water wont go in? (Somewhere around boralesgamuwa, werahera, pepiliyana or kohuwala would be preferred)
March 21, 201610 yr However, there is one thing which I haven't figured out yet... the right tail light, i had previously had a bit of mist after a wash... I thought there must be a leak in the tail light so I bought a new tail light and replaced.. but then again after the wash, even in the new tail light the mist is there... so i assume, the light should be sealed properly maybe after fitting and nothings wrong with the lights?.. coz when i look from above, the left tail light has a sealant kind of thing which water won't go in , whereas in the leaky side, water can directly penetrate in.. so anyone can suggest a good place for me to get it properly sealed or do something where water wont go in? (Somewhere around boralesgamuwa, werahera, pepiliyana or kohuwala would be preferred) Buy a tube of gasket maker (you can get one to match the colour of the border - I assume it's black). Apply a very thin layer and wipe the excess sealer off and let it dry. That should seal off the light.
March 21, 201610 yr The rear refina? That's not a sticker, those are badges If you are talking about the side sticker near the rear door, it has a different font that the trunk refina font... it seems like its out of place but it's the way it is actually... It was hard to paste them anyway, it sticks on the hand :s The method to paste stickers like this is to first create a soap water solution (mix some car wash/shampoo with water) and spray it on the body where the sticker is to be pasted. Next, peel off the sticker and paste it on the body (yes, on top of the soap water). The soapy water on the body will allow you to slide the sticker on the body and position it exactly as you want it to. After the sticker is in place, you can remove air bubbles if necessary using an old credit card. Once the soap water dries up, the adhesive behind the sticker will stick to the body. The soap water prevents the sticker from sticking to your fingers as well.
March 21, 201610 yr The method to paste stickers like this is to first create a soap water solution (mix some car wash/shampoo with water) and spray it on the body where the sticker is to be pasted. Next, peel off the sticker and paste it on the body (yes, on top of the soap water). The soapy water on the body will allow you to slide the sticker on the body and position it exactly as you want it to. After the sticker is in place, you can remove air bubbles if necessary using an old credit card. Once the soap water dries up, the adhesive behind the sticker will stick to the body. The soap water prevents the sticker from sticking to your fingers as well. Ohh great thanks a lot davy!
March 21, 201610 yr Buy a tube of gasket maker (you can get one to match the colour of the border - I assume it's black). Apply a very thin layer and wipe the excess sealer off and let it dry. That should seal off the light. yes its black.. ok will try that out, thanks again
March 21, 201610 yr Ok so as requested by many, here are the pics of my New Presea... bought this in january and did a full restoration (both interior and exterior) and replaced all faded parts with new parts etc... The restoration steps and everything, I will update in my restoration blog and will post the link one's proper pics are taken from a good camera.. This is a 99 model, 2003 imported one with auto transmission.. Restoration completed today! Congrats bro! Awesome ride, but that meter cluster needs some modifications.
March 21, 201610 yr Congrats bro! Awesome ride, but that meter cluster needs some modifications. thanks machan what sort of? I'd like to keep it original as possible though... that illuminating indigo dash is unique to preseas, where you can reduce and increase the bluish-ness (brightness rather) of the odometer which I like so much
March 21, 201610 yr I prefer the dials like this, dials illuminated with green or white LEDs, probably its same with yours just cant see it clearly from your photo.
March 21, 201610 yr The method to paste stickers like this is to first create a soap water solution (mix some car wash/shampoo with water) and spray it on the body where the sticker is to be pasted. Next, peel off the sticker and paste it on the body (yes, on top of the soap water). The soapy water on the body will allow you to slide the sticker on the body and position it exactly as you want it to. After the sticker is in place, you can remove air bubbles if necessary using an old credit card. Once the soap water dries up, the adhesive behind the sticker will stick to the body. The soap water prevents the sticker from sticking to your fingers as well. Isn't this the same method used to tint the glasses as well?
March 21, 201610 yr The method to paste stickers like this is to first create a soap water solution (mix some car wash/shampoo with water) and spray it on the body where the sticker is to be pasted. Next, peel off the sticker and paste it on the body (yes, on top of the soap water). The soapy water on the body will allow you to slide the sticker on the body and position it exactly as you want it to. After the sticker is in place, you can remove air bubbles if necessary using an old credit card. Once the soap water dries up, the adhesive behind the sticker will stick to the body. The soap water prevents the sticker from sticking to your fingers as well. Congrats on your project and car looks really great !!! I would like to add some point to Davy's method of pasting stickers. (1) First get the sticker design cut. (2) Then peel-off the unnecessary off-cut area from the back-paper of the sticker (leave only the final letters on back- paper which you wish to paste) (3) Get a masking tape (white paper tapes which use in house painting and they are freely available at any hardware shop) and paste on the sticker, to cover the entire sticker. (4) Peel-off the back-paper of the sticker. (5) Then follow Davy''s soap method to paste the sticker to car body and align the sticker properly. (6) Leave sometime to dry up the sticker. (7) Carefully peel-off masking tape. Then all sticker letters will be pasted on the car body same as they were in your original design and no need to align letters one by one. I am sure if you can re-paste those stickers in proper way, you will get original looking back. But sometimes you may need a new set of stickers or better to take it to any sticker guy to remove the sticker carefully, if possible. Edited March 21, 201610 yr by Sampath Gunasekera
March 21, 201610 yr with regards to facelifts, yeah the CT2 came with 2 shells... your picture is the first shell (95 model), and then came another bumber lip with the 96,97 ct2's and then finally the refina buffer... even though the one in your picture has a refina sticker, its not a refina, its a 95 model ct2... some ct2 had a side sticker named refina, and no one knows why.. only the crystal light models are known to be refina's... Well...considering that the picture was taken from a Presea catalog...I tend to go with what the catalog suggests than the local Presea fanboys' deductions What is a Refina buffer anyway ? (sorry just that in the past the VZ-R boys were completely clueless and so are some of the Honda and Toyota fanboys...so..yeah)
March 21, 201610 yr I prefer the dials like this, dials illuminated with green or white LEDs, probably its same with yours just cant see it clearly from your photo. ah its the same as mine, yes the cam in my phone suck, that's why it isnt showing properly
March 21, 201610 yr Congrats on your project and car looks really great !!! I would like to add some point to Davy's method of pasting stickers. (1) First get the sticker design cut. (2) Then peel-off the unnecessary off-cut area from the back-paper of the sticker (leave only the final letters on back- paper which you wish to paste) (3) Get a masking tape (white paper tapes which use in house painting and they are freely available at any hardware shop) and paste on the sticker, to cover the entire sticker. (4) Peel-off the back-paper of the sticker. (5) Then follow Davy''s soap method to paste the sticker to car body and align the sticker properly. (6) Leave sometime to dry up the sticker. (7) Carefully peel-off masking tape. Then all sticker letters will be pasted on the car body same as they were in your original design and no need to align letters one by one. I am sure if you can re-paste those stickers in proper way, you will get original looking back. But sometimes you may need a new set of stickers or better to take it to any sticker guy to remove the sticker carefully, if possible. Ah great, thanks sampath
March 21, 201610 yr Well...considering that the picture was taken from a Presea catalog...I tend to go with what the catalog suggests than the local Presea fanboys' deductions What is a Refina buffer anyway ? (sorry just that in the past the VZ-R boys were completely clueless and so are some of the Honda and Toyota fanboys...so..yeah) No its not the fanboys deductions as you can clearly see, the rear light is not crystal.. which means its a CT2... Refina's are the one's that came with crystals Anyway even though the refina sticker is from the side, in the rear, there is a CT2 badge and not the refina badge, which means its a CT2.. Refinas came with Refina badges in the rear like mine... And a refina buffer is the buffer you can see in my car pic... if the GRILL under the bonnet is not divided into 2 parts (U shape) that means its a refina like mine.. if its divided into 2 parts (H shape) that means its a ct2.. Edited March 21, 201610 yr by PreseaLover
March 21, 201610 yr Really ?ใThe following is fromใa scan from a catalog..and it is mounted straight....granted that seems more like a badge than a sticker...and a pre-facelift (facelift..) No its not the fanboys deductions as you can clearly see, the rear light is not crystal.. which means its a CT2... Refina's are the one's that came with crystals Anyway even though the refina sticker is from the side, in the rear, there is a CT2 badge and not the refina badge, which means its a CT2.. Refinas came with Refina badges in the rear like mine... And a refina buffer is the buffer you can see in my car pic... if the GRILL under the bonnet is not divided into 2 parts (U shape) that means its a refina like mine.. if its divided into 2 parts (H shape) that means its a ct2.. What is Refina exactly? Does Refina has some sub trim levels? In iRage's catalogue it says "Ct.II Refina". Does it go with any dealer option? Edited March 21, 201610 yr by Sampath Gunasekera
March 21, 201610 yr No its not the fanboys deductions as you can clearly see, the rear light is not crystal.. which means its a CT2... Refina's are the one's that came with crystals Anyway even though the refina sticker is from the side, in the rear, there is a CT2 badge and not the refina badge, which means its a CT2.. Refinas came with Refina badges in the rear like mine... And a refina buffer is the buffer you can see in my car pic... if the GRILL under the bonnet is not divided into 2 parts (U shape) that means its a refina like mine.. if its divided into 2 parts (H shape) that means its a ct2.. and I rest my case about the fan boys being misinformed ! I did some reading on the Presea just now and it is contradictory to what you are saying According to the documents...even the pre-facelift has Refina as a sub grades, thus the Refina badge was not put on the rear lid and what was there was Ct. <something>. In fact the pure Refina line up came with the face lift where the base grade was E and then had Refina <some letter> (apparently). Anyway....even the non crystal lights and double bumper lip theory does not hold. And again dude ! That picture is from a Nissan Presea catalog where they call it Ct...Refina. So what you are insinuating is that you know better than all of Nissan regarding their own car ? Edited March 21, 201610 yr by iRage
March 21, 201610 yr What is Refina exactly? Does Refina has some sub trim levels? In iRage's catalogue it says "Ct.II Refina". Does it go with any dealer option? and I rest my case about the fan boys being misinformed !I did some reading on the Presea just now and it is contradictory to what you are saying According to the documents...even the pre-facelift has Refina as a sub grades, thus the Refina badge was not put on the rear lid. In fact the pure Refina line up came with the face lift where the base grade was E and then had Refina <some letter> (apparently). Anyway....even the non crystal lights and double bumper lip theory does not hold. And again dude ! That picture is from a Nissan Presea catalog where they call it Ct...Refina. So what you are insinuating is that you know better than all of Nissan regarding their own car ? Hmm... I don't know man, as far as I know, from what I have read and heard.... I rest my case too coz I don't know 100% but since you have found some info, there must be another clasification to the grades... but yes there are Refina, Refina F, Refina L, and Refina S.... my previous car was Refina F, which has only limited features... Refina S is what comes with 1.8l and 2.0l... Refina L is just another grade which has a normal 1.5l engine.. and Refina which is what I have now comes with additional features such as reading laps, sunshade mirrors. And also if you noticed mine has a rear wiper as well.. I have never seen a presea with a rear wiper in SL before... oh and also Refina S comes with fully loaded all 4 disk brakes as well... As I remember iRage you know about these trim levels better than me, as I learnt them from you back then RIGHT?
March 21, 201610 yr Looking better than Brand new! The good old days when Japanese cars had personality than the Vessels and Priuss now flooding the streets,sigh..But great job for keeping a good looking car in showroom condition!
March 22, 201610 yr Looking better than Brand new! The good old days when Japanese cars had personality than the Vessels and Priuss now flooding the streets,sigh..But great job for keeping a good looking car in showroom condition! Thank you rvigi
March 22, 201610 yr Ok so here you go.... the step by step restoration process, updated in my blog https://presealover.wordpress.com/2016/03/21/project-presea-r11/ Edited March 22, 201610 yr by PreseaLover
March 22, 201610 yr Paint job looks perfect ,did you scratch to the metal? remove doors,bonnet,lights? What is labor cost?
