My car is having a strange idling issue and the exact problem is as follows.
After starting the car (when it is cold), rpm settles around 1300 and rpm doesn't get lower after engine got to the operating temperature. No matter how long the car runs, it stays around 1300. Few weeks ago this system was working fine. cold start rpm was around 1300 and after few mins it settles around 800-700. Now it doesn't work like that, but if I turn off the car and start it againwhen hot, then rpm settles around 800. If I leave the car for few hours to cool down and then start it, again rpm get stuck around 1300.
So the issue is cold start rpm get stuck around 1300 and it doesn't get lower unless restart the car. If I restart the car when it is hot, then rpm settles around 800.
Is this could be a possible ECU failure ? Any expert ideas ?
Nissan is bringing in the Primera nameplate back. I hope it's not going to be some boring crossover but a car that will have superb handling, good responsive reliable motor like the Primeras of pre 2000. I also do hope they don't go under and the Primera becomes their saviour.
https://carbuzz.com/nissan-trademarks-primera-name/
Hey Guys,
Sorry for the downtime over the past two days! We’ve been migrating servers and upgrading the site. You might still experience occasional outages as we fine-tune things.
Thanks for your patience! 🙌
dev89
Hi All,
After starting the car (when it is cold), rpm settles around 1300 and rpm doesn't get lower after engine got to the operating temperature. No matter how long the car runs, it stays around 1300. Few weeks ago this system was working fine. cold start rpm was around 1300 and after few mins it settles around 800-700. Now it doesn't work like that, but if I turn off the car and start it again when hot, then rpm settles around 800. If I leave the car for few hours to cool down and then start it, again rpm get stuck around 1300.
Toyota Carina Ti 1997 MT ( 220000 kms )
Thanks in advance.
Edited by dev89Link to comment
16 answers to this question
